Ich habe mir jetzt den Grabber bestellt.
Alles verkabelt und kann die LEDs über Handy und Hyperion steuern.
Dennoch funtioniert es nicht das Ambilight nicht.
Das Videosignal kommt an. Getestet mit Rechklick in der Hyperrion.
Habe mich jetzt viel belesen, finde aber den Fehler nicht.
Könnte bitte jemand auf meine Hyperion Config schauen ?
"name" : "MyHyperionConfig",
"type" : "apa102",
"colorOrder" : "bgr"
"redChannel" : 255,
"greenChannel" : 0,
"blueChannel" : 0
"redChannel" : 0,
"greenChannel" : 255,
"blueChannel" : 0
"redChannel" : 0,
"greenChannel" : 0,
"blueChannel" : 255
"red" : 255,
"green" : 255,
"blue" : 255
"luminanceGain" : 1.0000,
"luminanceMinimum" : 0.0000
"gamma" : 2.5000
"gamma" : 2.5000
"gamma" : 2.5000
"updateFrequency" : 20.0000,
// NO V4L2 GRABBER CONFIG
// FRAME GRABBER CONFIG
"threshold" : 0.0,
// NO KODI CHECK CONFIG
"vscan" : { "minimum" : 0.4839, "maximum" : 0.5161 }
"vscan" : { "minimum" : 0.4516, "maximum" : 0.4839 }
"vscan" : { "minimum" : 0.4194, "maximum" : 0.4516 }
"vscan" : { "minimum" : 0.3871, "maximum" : 0.4194 }
"vscan" : { "minimum" : 0.3548, "maximum" : 0.3871 }
"vscan" : { "minimum" : 0.3226, "maximum" : 0.3548 }
"vscan" : { "minimum" : 0.2903, "maximum" : 0.3226 }
"vscan" : { "minimum" : 0.2581, "maximum" : 0.2903 }
"vscan" : { "minimum" : 0.2258, "maximum" : 0.2581 }
"vscan" : { "minimum" : 0.1935, "maximum" : 0.2258 }
"vscan" : { "minimum" : 0.1613, "maximum" : 0.1935 }
"vscan" : { "minimum" : 0.1290, "maximum" : 0.1613 }
"vscan" : { "minimum" : 0.0968, "maximum" : 0.1290 }
"vscan" : { "minimum" : 0.0645, "maximum" : 0.0968 }
"vscan" : { "minimum" : 0.0323, "maximum" : 0.0645 }
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0323 }
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0167 },
"hscan" : { "minimum" : 0.0167, "maximum" : 0.0333 },
"hscan" : { "minimum" : 0.0333, "maximum" : 0.0500 },
"hscan" : { "minimum" : 0.0500, "maximum" : 0.0667 },
"hscan" : { "minimum" : 0.0667, "maximum" : 0.0833 },
"hscan" : { "minimum" : 0.0833, "maximum" : 0.1000 },
"hscan" : { "minimum" : 0.1000, "maximum" : 0.1167 },
"hscan" : { "minimum" : 0.1167, "maximum" : 0.1333 },
"hscan" : { "minimum" : 0.1333, "maximum" : 0.1500 },
"hscan" : { "minimum" : 0.1500, "maximum" : 0.1667 },
"hscan" : { "minimum" : 0.1667, "maximum" : 0.1833 },
"hscan" : { "minimum" : 0.1833, "maximum" : 0.2000 },
"hscan" : { "minimum" : 0.2000, "maximum" : 0.2167 },
"hscan" : { "minimum" : 0.2167, "maximum" : 0.2333 },
"hscan" : { "minimum" : 0.2333, "maximum" : 0.2500 },
"hscan" : { "minimum" : 0.2500, "maximum" : 0.2667 },
"hscan" : { "minimum" : 0.2667, "maximum" : 0.2833 },
"hscan" : { "minimum" : 0.2833, "maximum" : 0.3000 },
"hscan" : { "minimum" : 0.3000, "maximum" : 0.3167 },
"hscan" : { "minimum" : 0.3167, "maximum" : 0.3333 },
"hscan" : { "minimum" : 0.3333, "maximum" : 0.3500 },
"hscan" : { "minimum" : 0.3500, "maximum" : 0.3667 },
"hscan" : { "minimum" : 0.3667, "maximum" : 0.3833 },
"hscan" : { "minimum" : 0.3833, "maximum" : 0.4000 },
"hscan" : { "minimum" : 0.4000, "maximum" : 0.4167 },
"hscan" : { "minimum" : 0.4167, "maximum" : 0.4333 },
"hscan" : { "minimum" : 0.4333, "maximum" : 0.4500 },
"hscan" : { "minimum" : 0.4500, "maximum" : 0.4667 },
"hscan" : { "minimum" : 0.4667, "maximum" : 0.4833 },
"hscan" : { "minimum" : 0.4833, "maximum" : 0.5000 },
"hscan" : { "minimum" : 0.5000, "maximum" : 0.5167 },
"hscan" : { "minimum" : 0.5167, "maximum" : 0.5333 },
"hscan" : { "minimum" : 0.5333, "maximum" : 0.5500 },
"hscan" : { "minimum" : 0.5500, "maximum" : 0.5667 },
"hscan" : { "minimum" : 0.5667, "maximum" : 0.5833 },
"hscan" : { "minimum" : 0.5833, "maximum" : 0.6000 },
"hscan" : { "minimum" : 0.6000, "maximum" : 0.6167 },
"hscan" : { "minimum" : 0.6167, "maximum" : 0.6333 },
"hscan" : { "minimum" : 0.6333, "maximum" : 0.6500 },
"hscan" : { "minimum" : 0.6500, "maximum" : 0.6667 },
"hscan" : { "minimum" : 0.6667, "maximum" : 0.6833 },
"hscan" : { "minimum" : 0.6833, "maximum" : 0.7000 },
"hscan" : { "minimum" : 0.7000, "maximum" : 0.7167 },
"hscan" : { "minimum" : 0.7167, "maximum" : 0.7333 },
"hscan" : { "minimum" : 0.7333, "maximum" : 0.7500 },
"hscan" : { "minimum" : 0.7500, "maximum" : 0.7667 },
"hscan" : { "minimum" : 0.7667, "maximum" : 0.7833 },
"hscan" : { "minimum" : 0.7833, "maximum" : 0.8000 },
"hscan" : { "minimum" : 0.8000, "maximum" : 0.8167 },
"hscan" : { "minimum" : 0.8167, "maximum" : 0.8333 },
"hscan" : { "minimum" : 0.8333, "maximum" : 0.8500 },
"hscan" : { "minimum" : 0.8500, "maximum" : 0.8667 },
"hscan" : { "minimum" : 0.8667, "maximum" : 0.8833 },
"hscan" : { "minimum" : 0.8833, "maximum" : 0.9000 },
"hscan" : { "minimum" : 0.9000, "maximum" : 0.9167 },
"hscan" : { "minimum" : 0.9167, "maximum" : 0.9333 },
"hscan" : { "minimum" : 0.9333, "maximum" : 0.9500 },
"hscan" : { "minimum" : 0.9500, "maximum" : 0.9667 },
"hscan" : { "minimum" : 0.9667, "maximum" : 0.9833 },
"hscan" : { "minimum" : 0.9833, "maximum" : 1.0000 },
"vscan" : { "minimum" : 0.5161, "maximum" : 0.5484 }
"vscan" : { "minimum" : 0.5484, "maximum" : 0.5806 }
"vscan" : { "minimum" : 0.5806, "maximum" : 0.6129 }
"vscan" : { "minimum" : 0.6129, "maximum" : 0.6452 }
"vscan" : { "minimum" : 0.6452, "maximum" : 0.6774 }
"vscan" : { "minimum" : 0.6774, "maximum" : 0.7097 }
"vscan" : { "minimum" : 0.7097, "maximum" : 0.7419 }
"vscan" : { "minimum" : 0.7419, "maximum" : 0.7742 }
"vscan" : { "minimum" : 0.7742, "maximum" : 0.8065 }
"vscan" : { "minimum" : 0.8065, "maximum" : 0.8387 }
"vscan" : { "minimum" : 0.8387, "maximum" : 0.8710 }
"vscan" : { "minimum" : 0.8710, "maximum" : 0.9032 }
"vscan" : { "minimum" : 0.9032, "maximum" : 0.9355 }
"vscan" : { "minimum" : 0.9355, "maximum" : 0.9677 }
"vscan" : { "minimum" : 0.9677, "maximum" : 1.0000 }
"index" : 121,
"index" : 122,
"index" : 123,
"index" : 124,
"index" : 125,
"index" : 126,
"index" : 127,
"index" : 128,
"index" : 129,
"index" : 130,
"index" : 131,
"index" : 132,
"index" : 133,
"index" : 134,
"index" : 135,
"index" : 136,
"index" : 137,
"index" : 138,
"index" : 139,
"index" : 140,
"index" : 141,
"index" : 142,
"index" : 143,
"index" : 144,
"index" : 145,
"index" : 146,
"index" : 147,
"index" : 148,
"index" : 149,
"index" : 150,
"index" : 151,
"index" : 152,
"index" : 153,
"index" : 154,
"index" : 155,
"index" : 156,
"index" : 157,
"index" : 158,
"index" : 159,
"index" : 160,
"index" : 161,
"index" : 162,
"index" : 163,
"index" : 164,
"index" : 165,
"index" : 166,
"index" : 167,
"index" : 168,
"index" : 169,
"index" : 170,
"index" : 171,
"index" : 172,
"index" : 173,
"index" : 174,
"index" : 175,
"index" : 176,
"index" : 177,
"index" : 178,
"index" : 179,
"index" : 180,
"index" : 181,
