anbei
[ 0.528331] pci_bus 0000:03: resource 13 [mem 0xfed20000-0xfed9ffff]
[ 0.528373] NET: Registered protocol family 2
[ 0.528674] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.528698] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.528737] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.528781] TCP: reno registered
[ 0.528785] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.528796] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.528875] NET: Registered protocol family 1
[ 0.528897] pci 0000:00:02.0: Video device with shadowed ROM
[ 0.534620] PCI: CLS 64 bytes, default 64
[ 0.534685] Trying to unpack rootfs image as initramfs...
[ 1.265056] Freeing initrd memory: 28872K (f478c000 - f63be000)
[ 1.265217] Simple Boot Flag at 0x7a set to 0x1
[ 1.265494] microcode: CPU0 sig=0x6f6, pf=0x1, revision=0x44
[ 1.265504] microcode: CPU1 sig=0x6f6, pf=0x1, revision=0x44
[ 1.265603] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.265663] Scanning for low memory corruption every 60 seconds
[ 1.266424] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 1.266519] Initialise system trusted keyring
[ 1.266555] audit: initializing netlink subsys (disabled)
[ 1.266585] audit: type=2000 audit(1464622874.264:1): initialized
[ 1.267058] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.271483] zpool: loaded
[ 1.271486] zbud: loaded
[ 1.271605] VFS: Disk quotas dquot_6.5.2
[ 1.271691] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.272811] fuse init (API version 7.23)
[ 1.273143] Key type big_key registered
[ 1.273605] Key type asymmetric registered
[ 1.273609] Asymmetric key parser 'x509' registered
[ 1.273636] bounce: pool size: 64 pages
[ 1.273719] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.273775] io scheduler noop registered
[ 1.273780] io scheduler deadline registered (default)
[ 1.273859] io scheduler cfq registered
[ 1.275132] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.275171] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.275242] vesafb: mode is 1280x1024x32, linelength=5120, pages=0
[ 1.275244] vesafb: scrolling: redraw
[ 1.275247] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 1.275254] mtrr: type mismatch for c0000000,800000 old: write-back new: write-combining
[ 1.275258] mtrr: type mismatch for c0000000,400000 old: write-back new: write-combining
[ 1.275261] mtrr: type mismatch for c0000000,200000 old: write-back new: write-combining
[ 1.275265] mtrr: type mismatch for c0000000,100000 old: write-back new: write-combining
[ 1.275268] mtrr: type mismatch for c0000000,80000 old: write-back new: write-combining
[ 1.275271] mtrr: type mismatch for c0000000,40000 old: write-back new: write-combining
[ 1.275275] mtrr: type mismatch for c0000000,20000 old: write-back new: write-combining
[ 1.275278] mtrr: type mismatch for c0000000,10000 old: write-back new: write-combining
[ 1.275281] mtrr: type mismatch for c0000000,8000 old: write-back new: write-combining
[ 1.275284] mtrr: type mismatch for c0000000,4000 old: write-back new: write-combining
[ 1.275288] mtrr: type mismatch for c0000000,2000 old: write-back new: write-combining
[ 1.275291] mtrr: type mismatch for c0000000,1000 old: write-back new: write-combining
[ 1.275326] vesafb: framebuffer at 0xc0000000, mapped to 0xf8480000, using 5120k, total 5120k
[ 1.275510] Console: switching to colour frame buffer device 160x64
[ 1.275555] fb0: VESA VGA frame buffer device
[ 1.275590] intel_idle: does not run on family 6 model 15
[ 1.275726] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 1.275733] ACPI: Power Button [VBTN]
[ 1.275837] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 1.275840] ACPI: Power Button [PWRF]
[ 1.276137] GHES: HEST is not enabled!
[ 1.276181] isapnp: Scanning for PnP cards...
[ 1.280049] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.300472] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.303639] Linux agpgart interface v0.103
[ 1.303776] agpgart-intel 0000:00:00.0: Intel 965Q Chipset
[ 1.303801] agpgart-intel 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[ 1.304302] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 1.304449] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xc0000000
[ 1.307531] brd: module loaded
[ 1.309073] loop: module loaded
[ 1.309379] ata_piix 0000:00:1f.2: version 2.13
[ 1.309829] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.465018] scsi host0: ata_piix
[ 1.465176] scsi host1: ata_piix
[ 1.465284] ata1: SATA max UDMA/133 cmd 0xfe00 ctl 0xfe10 bmdma 0xfec0 irq 20
[ 1.465290] ata2: SATA max UDMA/133 cmd 0xfe20 ctl 0xfe30 bmdma 0xfec8 irq 20
[ 1.465716] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 1.585861] isapnp: No Plug & Play device found
[ 1.620588] scsi host2: ata_piix
[ 1.620764] scsi host3: ata_piix
[ 1.620873] ata3: SATA max UDMA/133 cmd 0xfe40 ctl 0xfe50 bmdma 0xfed0 irq 20
[ 1.620877] ata4: SATA max UDMA/133 cmd 0xfe60 ctl 0xfe70 bmdma 0xfed8 irq 20
[ 1.621068] libphy: Fixed MDIO Bus: probed
[ 1.621073] tun: Universal TUN/TAP device driver, 1.6
[ 1.621075] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.621161] PPP generic driver version 2.4.2
[ 1.621312] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.621321] ehci-pci: EHCI PCI platform driver
[ 1.621778] ehci-pci 0000:00:1a.7: EHCI Host Controller
[ 1.621788] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 1.621803] ehci-pci 0000:00:1a.7: debug port 1
[ 1.625703] ehci-pci 0000:00:1a.7: cache line size of 64 is not supported
[ 1.625724] ehci-pci 0000:00:1a.7: irq 22, io mem 0xdfdfbc00
[ 1.636035] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.636108] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.636112] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.636116] usb usb1: Product: EHCI Host Controller
[ 1.636119] usb usb1: Manufacturer: Linux 3.19.0-32-generic ehci_hcd
[ 1.636122] usb usb1: SerialNumber: 0000:00:1a.7
[ 1.636378] hub 1-0:1.0: USB hub found
[ 1.636389] hub 1-0:1.0: 4 ports detected
[ 1.637065] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.637073] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 1.637087] ehci-pci 0000:00:1d.7: debug port 1
[ 1.640993] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 1.641013] ehci-pci 0000:00:1d.7: irq 23, io mem 0xff980800
[ 1.652029] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.652090] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.652094] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.652098] usb usb2: Product: EHCI Host Controller
[ 1.652101] usb usb2: Manufacturer: Linux 3.19.0-32-generic ehci_hcd
[ 1.652104] usb usb2: SerialNumber: 0000:00:1d.7
[ 1.652349] hub 2-0:1.0: USB hub found
[ 1.652359] hub 2-0:1.0: 6 ports detected
[ 1.652671] ehci-platform: EHCI generic platform driver
[ 1.652690] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.652697] ohci-pci: OHCI PCI platform driver
[ 1.652723] ohci-platform: OHCI generic platform driver
[ 1.652740] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.653170] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.653178] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 1.653186] uhci_hcd 0000:00:1a.0: detected 2 ports
[ 1.653220] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff20
[ 1.653293] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.653296] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.653299] usb usb3: Product: UHCI Host Controller
[ 1.653302] usb usb3: Manufacturer: Linux 3.19.0-32-generic uhci_hcd
[ 1.653305] usb usb3: SerialNumber: 0000:00:1a.0
[ 1.653518] hub 3-0:1.0: USB hub found
[ 1.653529] hub 3-0:1.0: 2 ports detected
[ 1.654121] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.654129] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 1.654136] uhci_hcd 0000:00:1a.1: detected 2 ports
[ 1.654169] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ff00
[ 1.654235] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.654238] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.654241] usb usb4: Product: UHCI Host Controller
[ 1.654244] usb usb4: Manufacturer: Linux 3.19.0-32-generic uhci_hcd
[ 1.654247] usb usb4: SerialNumber: 0000:00:1a.1
[ 1.654463] hub 4-0:1.0: USB hub found
[ 1.654473] hub 4-0:1.0: 2 ports detected
[ 1.655066] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.655075] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[ 1.655082] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 1.655102] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff80
[ 1.655167] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.655170] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.655173] usb usb5: Product: UHCI Host Controller
[ 1.655176] usb usb5: Manufacturer: Linux 3.19.0-32-generic uhci_hcd
[ 1.655179] usb usb5: SerialNumber: 0000:00:1d.0
[ 1.655392] hub 5-0:1.0: USB hub found
[ 1.655402] hub 5-0:1.0: 2 ports detected
[ 1.655993] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.656011] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 1.656019] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 1.656038] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000ff60
[ 1.656104] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.656107] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.656110] usb usb6: Product: UHCI Host Controller
[ 1.656113] usb usb6: Manufacturer: Linux 3.19.0-32-generic uhci_hcd
[ 1.656116] usb usb6: SerialNumber: 0000:00:1d.1
[ 1.656337] hub 6-0:1.0: USB hub found
[ 1.656347] hub 6-0:1.0: 2 ports detected
[ 1.656940] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.656949] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 1.656956] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 1.656990] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 1.657056] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.657059] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.657062] usb usb7: Product: UHCI Host Controller
[ 1.657065] usb usb7: Manufacturer: Linux 3.19.0-32-generic uhci_hcd
[ 1.657068] usb usb7: SerialNumber: 0000:00:1d.2
[ 1.657283] hub 7-0:1.0: USB hub found
[ 1.657293] hub 7-0:1.0: 2 ports detected
[ 1.657560] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.660412] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.660420] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.660683] mousedev: PS/2 mouse device common for all mice
[ 1.660948] rtc_cmos 00:01: RTC can wake from S4
[ 1.661111] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 1.661138] rtc_cmos 00:01: alarms up to one day, 242 bytes nvram, hpet irqs
[ 1.661158] i2c /dev entries driver
[ 1.661252] device-mapper: uevent: version 1.0.3
[ 1.661392] device-mapper: ioctl: 4.29.0-ioctl (2014-10-28) initialised:
dm-devel@redhat.com[ 1.661441] platform eisa.0: Probing EISA bus 0
[ 1.661446] platform eisa.0: EISA: Cannot allocate resource for mainboard
[ 1.661449] platform eisa.0: Cannot allocate resource for EISA slot 1
[ 1.661453] platform eisa.0: Cannot allocate resource for EISA slot 2
[ 1.661456] platform eisa.0: Cannot allocate resource for EISA slot 3
[ 1.661459] platform eisa.0: Cannot allocate resource for EISA slot 4
[ 1.661463] platform eisa.0: Cannot allocate resource for EISA slot 5
[ 1.661466] platform eisa.0: Cannot allocate resource for EISA slot 6
[ 1.661469] platform eisa.0: Cannot allocate resource for EISA slot 7
[ 1.661473] platform eisa.0: Cannot allocate resource for EISA slot 8
[ 1.661476] platform eisa.0: EISA: Detected 0 cards
[ 1.661499] cpufreq-nforce2: No nForce2 chipset.
[ 1.661513] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.661529] PCCT header not found.
[ 1.661531] ACPI PCC probe failed.
[ 1.661702] TCP: cubic registered
[ 1.661973] NET: Registered protocol family 10
[ 1.662384] NET: Registered protocol family 17
[ 1.662402] Key type dns_resolver registered
[ 1.662744] Using IPI No-Shortcut mode
[ 1.662989] Loading compiled-in X.509 certificates
[ 1.667645] Loaded X.509 cert 'Magrathea: Glacier signing key: 6727a22571c7546e4be91b5c8a96c4bc8c7cc61d'
[ 1.667667] registered taskstats version 1
[ 1.670516] Key type trusted registered
[ 1.675473] Key type encrypted registered
[ 1.675483] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.675488] ima: No TPM chip found, activating TPM-bypass!
[ 1.675522] evm: HMAC attrs: 0x1
[ 1.675918] Magic number: 0:971:690
[ 1.675972] mem mem: hash matches
[ 1.676038] rtc_cmos 00:01: setting system clock to 2016-05-30 15:41:14 UTC (1464622874)
[ 1.676141] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.676143] EDD information not available.
[ 1.676257] PM: Hibernation image not present or could not be loaded.
[ 1.940125] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.096072] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.104457] ata3.00: ATA-7: Hitachi HDS721680PLA380, P21OAB3A, max UDMA/133
[ 2.104462] ata3.00: 156250000 sectors, multi 8: LBA48 NCQ (depth 0/32)
[ 2.120312] ata3.00: configured for UDMA/133
[ 2.132017] usb 3-1: new full-speed USB device number 2 using uhci_hcd
[ 2.204035] usb 7-1: new full-speed USB device number 2 using uhci_hcd
[ 2.208054] usb 1-3: new high-speed USB device number 3 using ehci-pci
[ 2.260083] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.260095] ata1.01: SATA link down (SStatus 4 SControl 300)
[ 2.260210] ata2.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.260224] ata2.01: SATA link down (SStatus 4 SControl 300)
[ 2.260235] ata2.01: link offline, clearing class 3 to NONE
[ 2.264068] tsc: Refined TSC clocksource calibration: 1860.644 MHz
[ 2.268212] ata2.00: ATAPI: _NEC DVD+/-RW ND-3650A, 105C, max UDMA/33
[ 2.268397] ata1.00: ATA-7: SAMSUNG HD160JJ/P, ZM100-34, max UDMA7
[ 2.268401] ata1.00: 312500000 sectors, multi 8: LBA48 NCQ (depth 0/32)
[ 2.280307] ata1.00: configured for UDMA/133
[ 2.280440] scsi 0:0:0:0: Direct-Access ATA SAMSUNG HD160JJ/ 0-34 PQ: 0 ANSI: 5
[ 2.280746] sd 0:0:0:0: [sda] 312500000 512-byte logical blocks: (160 GB/149 GiB)
[ 2.280833] sd 0:0:0:0: [sda] Write Protect is off
[ 2.280837] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.280840] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.280868] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.284173] ata2.00: configured for UDMA/33
[ 2.285734] scsi 1:0:0:0: CD-ROM _NEC DVD+-RW ND-3650A 105C PQ: 0 ANSI: 5
[ 2.293195] sr 1:0:0:0: [sr0] scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray
[ 2.293199] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.293454] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.293571] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.293739] scsi 2:0:0:0: Direct-Access ATA Hitachi HDS72168 AB3A PQ: 0 ANSI: 5
[ 2.294041] sd 2:0:0:0: [sdb] 156250000 512-byte logical blocks: (80.0 GB/74.5 GiB)
[ 2.294108] sd 2:0:0:0: [sdb] Write Protect is off
[ 2.294112] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.294113] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 2.294144] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.300059] usb 6-2: new low-speed USB device number 2 using uhci_hcd
[ 2.300641] sda: sda1 sda2 < sda5 >
[ 2.301221] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.311415] sdb: sdb1
[ 2.311807] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 2.312257] Freeing unused kernel memory: 932K (c1a64000 - c1b4d000)
[ 2.312325] Write protecting the kernel text: 6956k
[ 2.312461] Write protecting the kernel read-only data: 3008k
[ 2.312463] NX-protecting the kernel data: 5332k
[ 2.317091] usb 3-1: New USB device found, idVendor=046d, idProduct=c52b
[ 2.317098] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.317101] usb 3-1: Product: USB Receiver
[ 2.317104] usb 3-1: Manufacturer: Logitech
[ 2.330959] systemd-udevd[117]: starting version 204
[ 2.341648] usb 1-3: New USB device found, idVendor=7392, idProduct=7811
[ 2.341653] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.341657] usb 1-3: Product: 802.11n WLAN Adapter
[ 2.341660] usb 1-3: Manufacturer: Realtek
[ 2.341662] usb 1-3: SerialNumber: 00e04c000001
[ 2.380814] [drm] Initialized drm 1.1.0 20060810
[ 2.396690] pps_core: LinuxPPS API ver. 1 registered
[ 2.396693] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 2.404639] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.428826] PTP clock support registered
[ 2.453262] tg3.c:v3.137 (May 11, 2014)
[ 2.462717] usb 1-4: new high-speed USB device number 4 using ehci-pci
[ 2.471171] usbcore: registered new interface driver usbhid
[ 2.471175] usbhid: USB HID core driver
[ 2.476127] usb 7-1: New USB device found, idVendor=0d8c, idProduct=0102
[ 2.476133] usb 7-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.476136] usb 7-1: Product: USB Sound Device
[ 2.478242] [drm] Memory usable by graphics device = 512M
[ 2.478248] checking generic (c0000000 500000) vs hw (c0000000 10000000)
[ 2.478250] fb: switching to inteldrmfb from VESA VGA
[ 2.478283] Console: switching to colour dummy device 80x25
[ 2.478413] [drm] Replacing VGA console driver
[ 2.495080] tg3 0000:02:00.0 eth0: Tigon3 [partno(BCM95754) rev b002] (PCI Express) MAC address 00:18:8b:2a:4b:86
[ 2.495086] tg3 0000:02:00.0 eth0: attached PHY is 5787 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[ 2.495089] tg3 0000:02:00.0 eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 2.495093] tg3 0000:02:00.0 eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 2.500169] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.500173] [drm] Driver supports precise vblank timestamp query.
[ 2.500274] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 2.519206] usb 6-2: New USB device found, idVendor=413c, idProduct=2003
[ 2.519211] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.519215] usb 6-2: Product: Dell USB Keyboard
[ 2.519218] usb 6-2: Manufacturer: Dell
[ 2.593153] usb 1-4: New USB device found, idVendor=0bda, idProduct=0811
[ 2.593159] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.593162] usb 1-4: Product: 802.11ac WLAN Adapter
[ 2.593165] usb 1-4: Manufacturer: Realtek
[ 2.593168] usb 1-4: SerialNumber: 00e04c000001
[ 2.659809] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1a.0-1/input2
[ 2.661561] input: USB Sound Device as /devices/pci0000:00/0000:00:1d.2/usb7/7-1/7-1:1.3/0003:0D8C:0102.0004/input/input5
[ 2.665853] [drm] initialized overlay support
[ 2.665951] [drm] Initialized i915 1.6.0 20141121 for 0000:00:02.0 on minor 0
[ 2.716281] hid-generic 0003:0D8C:0102.0004: input,hidraw1: USB HID v1.00 Device [USB Sound Device ] on usb-0000:00:1d.2-1/input3
[ 2.716949] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.0/0003:413C:2003.0005/input/input6
[ 2.724086] usb 7-2: new low-speed USB device number 3 using uhci_hcd
[ 2.767136] fbcon: inteldrmfb (fb0) is primary device
[ 2.767181] Console: switching to colour frame buffer device 160x64
[ 2.767231] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 2.767234] i915 0000:00:02.0: registered panic notifier
[ 2.802562] random: lvm urandom read with 78 bits of entropy available
[ 2.833180] hid-generic 0003:413C:2003.0005: input,hidraw2: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:1d.1-2/input0
[ 3.100068] usb 7-2: New USB device found, idVendor=046d, idProduct=c408
[ 3.100074] usb 7-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.100078] usb 7-2: Product: USB Trackball
[ 3.100082] usb 7-2: Manufacturer: Logitech
[ 3.119392] input: Logitech USB Trackball as /devices/pci0000:00/0000:00:1d.2/usb7/7-2/7-2:1.0/0003:046D:C408.0007/input/input7
[ 3.119691] hid-generic 0003:046D:C408.0007: input,hidraw3: USB HID v1.10 Mouse [Logitech USB Trackball] on usb-0000:00:1d.2-2/input0
[ 3.265022] Switched to clocksource tsc
[ 5.440157] floppy0: no floppy controllers found
[ 5.768997] random: nonblocking pool is initialized
[ 6.046787] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[ 19.606083] Adding 2609148k swap on /dev/mapper/mint--vg-swap_1. Priority:-1 extents:1 across:2609148k FS
[ 19.773138] EXT4-fs (dm-0): re-mounted. Opts: errors=remount-ro
[ 19.791601] systemd-udevd[406]: starting version 204
[ 19.916301] lp: driver loaded but no devices found
[ 19.918855] ndiswrapper: module verification failed: signature and/or required key missing - tainting kernel
[ 19.918871] Disabling lock debugging due to kernel taint
[ 19.920076] ndiswrapper version 1.59 loaded (smp=yes, preempt=no)
[ 19.969384] EXT4-fs (sda1): mounting ext2 file system using the ext4 subsystem
[ 19.989000] EXT4-fs (sda1): mounted filesystem without journal. Opts: (null)
[ 20.037706] parport_pc 00:02: reported by Plug and Play ACPI
[ 20.037751] parport0: PC-style at 0x378 (0x778), irq 7, using FIFO [PCSPP,TRISTATE,COMPAT,EPP,ECP]
[ 20.043212] usbcore: registered new interface driver ndiswrapper
[ 20.090696] ppdev: user-space parallel port driver
[ 20.098535] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 20.136925] lp0: using parport0 (interrupt-driven).
[ 20.149133] ACPI Warning: SystemIO range 0x00000828-0x0000082f conflicts with OpRegion 0x0000082a-0x0000082a (\GIC3) (20141107/utaddress-258)
[ 20.149143] ACPI Warning: SystemIO range 0x00000828-0x0000082f conflicts with OpRegion 0x00000828-0x0000082d (\GLBC) (20141107/utaddress-258)
[ 20.149148] ACPI Warning: SystemIO range 0x00000828-0x0000082f conflicts with OpRegion 0x0000082a-0x0000082a (\SACT) (20141107/utaddress-258)
[ 20.149153] ACPI Warning: SystemIO range 0x00000828-0x0000082f conflicts with OpRegion 0x00000828-0x00000828 (\SSTS) (20141107/utaddress-258)
[ 20.149158] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 20.149163] ACPI Warning: SystemIO range 0x000008b0-0x000008bf conflicts with OpRegion 0x000008b9-0x000008b9 (\GHI5) (20141107/utaddress-258)
[ 20.149168] ACPI Warning: SystemIO range 0x000008b0-0x000008bf conflicts with OpRegion 0x000008b8-0x000008b8 (\GHI0) (20141107/utaddress-258)
[ 20.149173] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 20.149175] ACPI Warning: SystemIO range 0x00000880-0x000008af conflicts with OpRegion 0x0000088c-0x0000088c (\GIC2) (20141107/utaddress-258)
[ 20.149180] ACPI Warning: SystemIO range 0x00000880-0x000008af conflicts with OpRegion 0x0000088f-0x0000088f (\GIU3) (20141107/utaddress-258)
[ 20.149185] ACPI Warning: SystemIO range 0x00000880-0x000008af conflicts with OpRegion 0x0000088e-0x0000088e (\GIC1) (20141107/utaddress-258)
[ 20.149190] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 20.149192] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 20.326474] device-mapper: multipath: version 1.7.0 loaded
[ 20.388122] kvm: disabled by bios
[ 20.399148] coretemp coretemp.0: Using relative temperature scale!
[ 20.399170] coretemp coretemp.0: Using relative temperature scale!
[ 20.484161] sound hdaudioC0D0: autoconfig: line_outs=1 (0x5/0x0/0x0/0x0/0x0) type:line
[ 20.484166] sound hdaudioC0D0: speaker_outs=1 (0x7/0x0/0x0/0x0/0x0)
[ 20.484170] sound hdaudioC0D0: hp_outs=1 (0x6/0x0/0x0/0x0/0x0)
[ 20.484173] sound hdaudioC0D0: mono: mono_out=0x0
[ 20.484175] sound hdaudioC0D0: inputs:
[ 20.484179] sound hdaudioC0D0: Mic=0x8
[ 20.484181] sound hdaudioC0D0: Line=0x9
[ 20.488491] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 20.488715] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 20.488921] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 20.489135] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 20.745039] input: Logitech M570 as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1:1.2/0003:046D:C52B.0003/0003:046D:1028.0006/input/input12
[ 20.745344] logitech-hidpp-device 0003:046D:1028.0006: input,hidraw4: USB HID v1.11 Mouse [Logitech M570] on usb-0000:00:1a.0-1:1
[ 20.780071] usb 7-1: current rate 30464 is different from the runtime rate 96000
[ 20.793070] usb 7-1: Warning! Unlikely big volume range (=8065), cval->res is probably wrong.
[ 20.793076] usb 7-1: [9] FU [Mic Playback Volume] ch = 2, val = -6144/1921/1
[ 20.813076] usb 7-1: Warning! Unlikely big volume range (=8065), cval->res is probably wrong.
[ 20.813082] usb 7-1: [11] FU [Line Playback Volume] ch = 2, val = -6144/1921/1
[ 20.838131] usb 7-1: Warning! Unlikely big volume range (=6928), cval->res is probably wrong.
[ 20.838137] usb 7-1: [8] FU [Mic Capture Volume] ch = 2, val = -4096/2832/1
[ 20.846138] usb 7-1: Warning! Unlikely big volume range (=6928), cval->res is probably wrong.
[ 20.846144] usb 7-1: [15] FU [Line Capture Volume] ch = 2, val = -4096/2832/1
[ 20.854072] usb 7-1: Warning! Unlikely big volume range (=6928), cval->res is probably wrong.
[ 20.854079] usb 7-1: [2] FU [PCM Capture Volume] ch = 2, val = -4096/2832/1
[ 20.854535] usbcore: registered new interface driver snd-usb-audio
[ 20.966432] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 21.538780] init: failsafe main process (634) killed by TERM signal
[ 21.633283] Bluetooth: Core ver 2.20
[ 21.633312] NET: Registered protocol family 31
[ 21.633315] Bluetooth: HCI device and connection manager initialized
[ 21.633321] Bluetooth: HCI socket layer initialized
[ 21.633326] Bluetooth: L2CAP socket layer initialized
[ 21.633336] Bluetooth: SCO socket layer initialized
[ 21.657600] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 21.657604] Bluetooth: BNEP filters: protocol multicast
[ 21.657611] Bluetooth: BNEP socket layer initialized
[ 21.672772] Bluetooth: RFCOMM TTY layer initialized
[ 21.672784] Bluetooth: RFCOMM socket layer initialized
[ 21.672791] Bluetooth: RFCOMM ver 1.11
[ 22.249402] init: cups main process (775) killed by HUP signal
[ 22.249420] init: cups main process ended, respawning
[ 23.084063] floppy0: no floppy controllers found
[ 25.536207] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 26.800249] init: samba-ad-dc main process (1149) terminated with status 1
[ 27.360589] tg3 0000:02:00.0 eth0: Link is up at 100 Mbps, full duplex
[ 27.360601] tg3 0000:02:00.0 eth0: Flow control is off for TX and off for RX
[ 27.360624] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 30.754054] init: plymouth-upstart-bridge main process ended, respawning
[ 30.761878] init: plymouth-upstart-bridge main process (1681) terminated with status 1
[ 30.761896] init: plymouth-upstart-bridge main process ended, respawning
[ 71.379425] systemd-hostnamed[2490]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
[ 119.292124] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 119.492164] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 121.024222] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 123.496038] tg3 0000:02:00.0 eth0: Link is up at 100 Mbps, full duplex
[ 123.496050] tg3 0000:02:00.0 eth0: Flow control is off for TX and off for RX
[ 123.496069] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
karsten@karstenb ~ $
und ifconfig
karsten@karstenb ~ $ ifconfig
eth0 Link encap:Ethernet Hardware Adresse 00:18:8b:2a:4b:86
inet Adresse:192.168.178.57 Bcast:192.168.178.255 Maske:255.255.255.0
inet6-Adresse: fe80::218:8bff:fe2a:4b86/64 Gültigkeitsbereich:Verbindung
UP BROADCAST RUNNING MULTICAST MTU:1500 Metrik:1
RX-Pakete:1771 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
TX-Pakete:1381 Fehler:0 Verloren:0 Überläufe:0 Träger:0
Kollisionen:0 Sendewarteschlangenlänge:1000
RX-Bytes:1619577 (1.6 MB) TX-Bytes:226365 (226.3 KB)
Interrupt:16
lo Link encap:Lokale Schleife
inet Adresse:127.0.0.1 Maske:255.0.0.0
inet6-Adresse: ::1/128 Gültigkeitsbereich:Maschine
UP LOOPBACK RUNNING MTU:65536 Metrik:1
RX-Pakete:219 Fehler:0 Verloren:0 Überläufe:0 Fenster:0
TX-Pakete:219 Fehler:0 Verloren:0 Überläufe:0 Träger:0
Kollisionen:0 Sendewarteschlangenlänge:0
RX-Bytes:40410 (40.4 KB) TX-Bytes:40410 (40.4 KB)
Danke
