Optisch nun dasselbe Ergebnis.
In der Konsole:
OpenELEC:~ # /storage/hyperion/bin/hyperiond.sh /storage/.config/hyperion.config.json
Hyperion Ambilight Deamon
Version : V1.02.0 (brindosch-f4162eb/2d45d51-1462453507
Build Time: May 5 2016 06:07:47
HYPERION INFO: ColorTransform 'default' => [0; 115]
HYPERION INFO: ColorCorrection 'default' => [0; 115]
HYPERION INFO: ColorAdjustment 'default' => [0; 115]
"colorOrder" : "rgb",
KODICHECK INFO: Kodi Message: {"id":668,"jsonrpc":"2.0","result":{"System.ScreenSaverActive":true}}
KODICHECK INFO: Kodi Message: {"jsonrpc":"2.0","method":"GUI.OnScreensaverDeactivated","params":{"data":{"shuttingdown":false},"sender":"xbmc"}}
KODICHECK INFO: Kodi Message: {"jsonrpc":"2.0","method":"Playlist.OnAdd","params":{"data":{"item":{"title":"Ant-Man.mkv","type":"movie"},"playlistid":1,"position":0},"sender":"xbmc"}}
KODICHECK INFO: Kodi Message: {"jsonrpc":"2.0","method":"Player.OnPlay","params":{"data":{"item":{"title":"Ant-Man.mkv","type":"movie"},"player":{"playerid":1,"speed":1}},"sender":"xbmc"}}
KODICHECK INFO: Kodi Message: {"id":666,"jsonrpc":"2.0","result":[{"playerid":1,"type":"video"}]}
KODICHECK INFO: switching to VIDEO mode
KODICHECK INFO: Kodi Message: {"id":667,"jsonrpc":"2.0","result":{"item":{"file":"/var/media/Netti-Stick/Ant-Man/Ant-Man.mkv","label":"Ant-Man.mkv","type":"unknown"}}}
KODICHECK INFO: Kodi Message: {"id":669,"jsonrpc":"2.0","result":{"stereoscopicmode":{"label":"Deaktiviert","mode":"off"}}}
BORDER SWITCH REQUIRED!!
KODICHECK INFO: Kodi Message: {"jsonrpc":"2.0","method":"Player.OnPause","params":{"data":{"item":{"title":"Ant-Man.mkv","type":"movie"},"player":{"playerid":1,"speed":0}},"sender":"xbmc"}}
