2:https://www.amazon.de/clouddrive/share/Ne1btVPv90nTCZj8MU3yuunihwZTeeds4QxWl3GPM1h?ref_=cd_ph_share_link_copy
https://www.amazon.de/clouddrive/share/pgxfKdDgtUW3RkAUASPuD75ZtT48mB8XfA1AIAWFfyV?ref_=cd_ph_share_link_copy
https://www.amazon.de/clouddrive/share/tEm8Ejpfh3rSHRS0uV2AFnHtoiwBLsYq2x6EwzVjKDw?ref_=cd_ph_share_link_copy
ich hoff das reicht so mit den Bildern, sonst muss ich den TV runter nehmen und von hinten Forografieren..
Verkabelung ist zur zeit eh nur provisorisch, das richtige kabel muss ich noch mal neu Löten, ist ein anderes Problem..
3:
# hdmi_force_hotplug=1
dtparam=spi=on4:
// Created with HyperCon V1.02.0 (30.04.2016)
      "rate"     : 1000000,
      "colorOrder" : "rbg"
   ///  * 'channelAdjustment'
   ///  * 'id'   : The unique identifier of the channel adjustments (eg 'device_1')
   ///  * 'leds'   : The indices (or index ranges) of the leds to which this channel adjustment applies
   ///             (eg '0-5, 9, 11, 12-17'). The indices are zero based.
   ///  * 'pureRed'/'pureGreen'/'pureBlue' : The manipulation in the Red-Green-Blue color domain with the
   ///  * 'temperature'
   ///  * 'id'   : The unique identifier of the temperature (eg 'device_1')
   ///  * 'leds'   : The indices (or index ranges) of the leds to which this temperature applies
   ///  * 'red'/'green'/'blue' : The temperature manipulation in the Red-Green-Blue color domain with the
   ///  * 'transform'
   ///  * 'id'   : The unique identifier of the color transformation (eg 'device_1')
   ///  * 'leds' : The indices (or index ranges) of the leds to which this color transform applies
   ///  * 'hsv' : The manipulation in the Hue-Saturation-Value color domain with the following
   ///            - 'luminanceGain'       The gain adjustement of the luminance
               "redChannel"      : 245,
               "blueChannel"      : 10
               "redChannel"      : 180,
               "greenChannel"      : 255,
               "blueChannel"      : 192
            "temperatureValues" :
               "luminanceGain"      : 1.0500
               "gamma"        : 29.4900
               "gamma"        : 2.5100
               "gamma"        : 2.5000
      "threshold" : 0.03,
      "priority" : 990
//    "forwarder" :
//    "framegrabber" :
//       "width" : 64,
//       "height" : 64,
//       "priority" : 890
//    "xbmcVideoChecker" :
//       "grabVideo" : true,
//       "grabAudio" : true,
//       "grabMenu" : true,
//    "boblightServer" :
//       "port" : 19333,
//       "priority" : 900
      "sizeDecimation" : 8,
      "priority" : 900,
      "cropLeft" : 3,
      "cropRight" : 5,
      "cropTop" : 4,
      "cropBottom" : 5,
      "redSignalThreshold" : 0.2,
      "greenSignalThreshold" : 0.2,
      "blueSignalThreshold" : 0.2
https://www.amazon.de/clouddrive/share/qMi8r2USYR1iQKMGi4gBDVUtTnCMt25PxP77cYTPbKY?ref_=cd_ph_share_link_copy
6: Unten mitte rechts
7: nicht getestet
8:
.json
Hyperion Ambilight Deamon
        Version   : V1.02.0 (brindosch-f4162eb/2d45d51-1462453507
        Build Time: May  5 2016 06:07:47
HYPERION INFO: ColorTransform 'default' => [0; 91]
HYPERION INFO: ColorCorrection 'default' => [0; 91]
HYPERION INFO: ColorAdjustment 'default' => [0; 91]
        "colorOrder" : "rbg",
BLACKBORDER INFO: threshold set to 0.03 (8)
V4L2GRABBER INFO: pixel format=UYVY
V4L2GRABBER INFO: signal threshold set to: {51,51,51}
V4L2GRABBER INFO: started
V4L2GRABBER ERROR: Frame too small: 828830 != 829440
V4L2GRABBER ERROR: Frame too small: 828514 != 829440
BORDER SWITCH REQUIRED!!
V4L2GRABBER INFO: stopped
V4L2GRABBER ERROR: Frame too small: 828580 != 829440
V4L2GRABBER ERROR: Frame too small: 828812 != 829440
V4L2GRABBER ERROR: Frame too small: 828670 != 829440
V4L2GRABBER ERROR: Frame too small: 828282 != 829440
V4L2GRABBER ERROR: Frame too small: 828168 != 829440
V4L2GRABBER ERROR: Frame too small: 828210 != 829440
V4L2GRABBER ERROR: Frame too small: 826080 != 829440
V4L2GRABBER ERROR: Frame too small: 827936 != 829440
V4L2GRABBER ERROR: Frame too small: 828322 != 829440
V4L2GRABBER ERROR: Frame too small: 828854 != 829440
V4L2GRABBER ERROR: Frame too small: 828338 != 829440
V4L2GRABBER ERROR: Frame too small: 828430 != 829440
V4L2GRABBER ERROR: Frame too small: 828284 != 829440
V4L2GRABBER ERROR: Frame too small: 828750 != 829440
V4L2GRABBER ERROR: Frame too small: 825812 != 829440
V4L2GRABBER ERROR: Frame too small: 828136 != 829440
V4L2GRABBER ERROR: Frame too small: 827808 != 829440
V4L2GRABBER ERROR: Frame too small: 828172 != 829440
V4L2GRABBER ERROR: Frame too small: 827848 != 829440
V4L2GRABBER ERROR: Frame too small: 828736 != 829440
V4L2GRABBER ERROR: Frame too small: 828218 != 829440
V4L2GRABBER ERROR: Frame too small: 828644 != 829440
V4L2GRABBER ERROR: Frame too small: 828182 != 829440
V4L2GRABBER ERROR: Frame too small: 828848 != 829440
V4L2GRABBER ERROR: Frame too small: 828844 != 829440
V4L2GRABBER ERROR: Frame too small: 828246 != 829440
V4L2GRABBER ERROR: Frame too small: 827268 != 829440
V4L2GRABBER ERROR: Frame too small: 825564 != 829440
V4L2GRABBER ERROR: Frame too small: 828148 != 829440
V4L2GRABBER ERROR: Frame too small: 828270 != 829440
V4L2GRABBER ERROR: Frame too small: 828788 != 829440
V4L2GRABBER ERROR: Frame too small: 828228 != 829440
V4L2GRABBER ERROR: Frame too small: 828822 != 829440
V4L2GRABBER ERROR: Frame too small: 828668 != 829440
V4L2GRABBER ERROR: Frame too small: 828690 != 829440
V4L2GRABBER ERROR: Frame too small: 827626 != 829440
V4L2GRABBER ERROR: Frame too small: 827930 != 829440
V4L2GRABBER ERROR: Frame too small: 828238 != 829440
V4L2GRABBER ERROR: Frame too small: 828276 != 829440
V4L2GRABBER ERROR: Frame too small: 828714 != 829440
V4L2GRABBER ERROR: Frame too small: 824762 != 829440
V4L2GRABBER ERROR: Frame too small: 828746 != 829440
V4L2GRABBER ERROR: Frame too small: 828560 != 829440
V4L2GRABBER ERROR: Frame too small: 828346 != 829440
V4L2GRABBER ERROR: Frame too small: 828704 != 829440
V4L2GRABBER ERROR: Frame too small: 828464 != 829440
V4L2GRABBER ERROR: Frame too small: 828544 != 829440
V4L2GRABBER ERROR: Frame too small: 828624 != 829440
V4L2GRABBER ERROR: Frame too small: 828702 != 829440
V4L2GRABBER ERROR: Frame too small: 828782 != 829440
V4L2GRABBER ERROR: Frame too small: 828862 != 829440
V4L2GRABBER ERROR: Frame too small: 828942 != 829440
V4L2GRABBER ERROR: Frame too small: 828712 != 829440
V4L2GRABBER ERROR: Frame too small: 828222 != 829440
V4L2GRABBER ERROR: Frame too small: 827780 != 829440
V4L2GRABBER ERROR: Frame too small: 827924 != 829440
V4L2GRABBER ERROR: Frame too small: 827270 != 829440
V4L2GRABBER ERROR: Frame too small: 827580 != 829440
V4L2GRABBER ERROR: Frame too small: 828522 != 829440
V4L2GRABBER ERROR: Frame too small: 828602 != 829440
V4L2GRABBER ERROR: Frame too small: 828752 != 829440
V4L2GRABBER ERROR: Frame too small: 828832 != 829440
V4L2GRABBER ERROR: Frame too small: 828910 != 829440
V4L2GRABBER ERROR: Frame too small: 828236 != 829440
V4L2GRABBER ERROR: Frame too small: 827334 != 829440
V4L2GRABBER ERROR: Frame too small: 828376 != 829440
V4L2GRABBER ERROR: Frame too small: 828416 != 829440
V4L2GRABBER ERROR: Frame too small: 827488 != 829440
V4L2GRABBER ERROR: Frame too small: 828856 != 829440
V4L2GRABBER ERROR: Frame too small: 828358 != 829440
V4L2GRABBER ERROR: Frame too small: 828454 != 829440
V4L2GRABBER ERROR: Frame too small: 828748 != 829440
V4L2GRABBER ERROR: Frame too small: 828484 != 829440
V4L2GRABBER ERROR: Frame too small: 828530 != 829440
V4L2GRABBER ERROR: Frame too small: 828260 != 829440
V4L2GRABBER ERROR: Frame too small: 828344 != 829440
V4L2GRABBER ERROR: Frame too small: 828820 != 829440
V4L2GRABBER ERROR: Frame too small: 828398 != 829440
V4L2GRABBER ERROR: Frame too small: 828104 != 829440
V4L2GRABBER ERROR: Frame too small: 828114 != 829440
V4L2GRABBER ERROR: Frame too small: 826032 != 829440
V4L2GRABBER ERROR: Frame too small: 828154 != 829440
V4L2GRABBER ERROR: Frame too small: 827382 != 829440
V4L2GRABBER ERROR: Frame too small: 827500 != 829440
V4L2GRABBER ERROR: Frame too small: 827724 != 829440
V4L2GRABBER ERROR: Frame too small: 827174 != 829440
V4L2GRABBER ERROR: Frame too small: 828868 != 829440
V4L2GRABBER ERROR: Frame too small: 828570 != 829440
V4L2GRABBER ERROR: Frame too small: 828418 != 829440
V4L2GRABBER ERROR: Frame too small: 828498 != 829440
V4L2GRABBER ERROR: Frame too small: 828918 != 829440
V4L2GRABBER ERROR: Frame too small: 828900 != 829440
V4L2GRABBER ERROR: Frame too small: 827694 != 829440
V4L2GRABBER ERROR: Frame too small: 827978 != 829440
V4L2GRABBER ERROR: Frame too small: 828438 != 829440
V4L2GRABBER ERROR: Frame too small: 828290 != 829440
V4L2GRABBER ERROR: Frame too small: 828300 != 829440
V4L2GRABBER ERROR: Frame too small: 827292 != 829440
V4L2GRABBER ERROR: Frame too small: 828350 != 829440
V4L2GRABBER ERROR: Frame too small: 828476 != 829440
V4L2GRABBER ERROR: Frame too small: 828632 != 829440
V4L2GRABBER ERROR: Frame too small: 828866 != 829440
V4L2GRABBER ERROR: Frame too small: 828524 != 829440
V4L2GRABBER ERROR: Frame too small: 828364 != 829440
V4L2GRABBER ERROR: Frame too small: 827624 != 829440
V4L2GRABBER ERROR: Frame too small: 828654 != 829440
V4L2GRABBER ERROR: Frame too small: 828588 != 829440
V4L2GRABBER ERROR: Frame too small: 828036 != 829440
V4L2GRABBER ERROR: Frame too small: 827348 != 829440
V4L2GRABBER ERROR: Frame too small: 828824 != 829440
V4L2GRABBER ERROR: Frame too small: 828374 != 829440
V4L2GRABBER ERROR: Frame too small: 828622 != 829440
V4L2GRABBER ERROR: Frame too small: 828770 != 829440
V4L2GRABBER ERROR: Frame too small: 827960 != 829440
V4L2GRABBER ERROR: Frame too small: 824794 != 829440
V4L2GRABBER ERROR: Frame too small: 828922 != 829440
V4L2GRABBER ERROR: Frame too small: 828318 != 829440
V4L2GRABBER ERROR: Frame too small: 828204 != 829440
V4L2GRABBER ERROR: Frame too small: 828780 != 829440
V4L2GRABBER ERROR: Frame too small: 827630 != 829440
V4L2GRABBER ERROR: Frame too small: 828578 != 829440
V4L2GRABBER ERROR: Frame too small: 827672 != 829440
V4L2GRABBER ERROR: Frame too small: 828404 != 829440
V4L2GRABBER ERROR: Frame too small: 828380 != 829440
V4L2GRABBER ERROR: Frame too small: 828730 != 829440
V4L2GRABBER ERROR: Frame too small: 827424 != 829440
V4L2GRABBER ERROR: Frame too small: 828370 != 829440
V4L2GRABBER ERROR: Frame too small: 828450 != 829440
V4L2GRABBER ERROR: Frame too small: 828600 != 829440
V4L2GRABBER ERROR: Frame too small: 828272 != 829440
V4L2GRABBER ERROR: Frame too small: 828126 != 829440
V4L2GRABBER ERROR: Frame too small: 826716 != 829440
V4L2GRABBER ERROR: Frame too small: 828658 != 829440
V4L2GRABBER ERROR: Frame too small: 828732 != 829440
V4L2GRABBER ERROR: Frame too small: 827100 != 829440
V4L2GRABBER ERROR: Frame too small: 828316 != 829440
V4L2GRABBER ERROR: Frame too small: 828740 != 829440
V4L2GRABBER ERROR: Frame too small: 828328 != 829440
V4L2GRABBER ERROR: Frame too small: 828094 != 829440
V4L2GRABBER ERROR: Frame too small: 828616 != 829440
V4L2GRABBER ERROR: Frame too small: 825826 != 829440
V4L2GRABBER ERROR: Frame too small: 828840 != 829440
V4L2GRABBER ERROR: Frame too small: 827920 != 829440
V4L2GRABBER ERROR: Frame too small: 828638 != 829440
V4L2GRABBER ERROR: Frame too small: 828896 != 829440
V4L2GRABBER ERROR: Frame too small: 828724 != 829440
V4L2GRABBER ERROR: Frame too small: 828944 != 829440
V4L2GRABBER ERROR: Frame too small: 827628 != 829440
V4L2GRABBER ERROR: Frame too small: 827418 != 829440
V4L2GRABBER ERROR: Frame too small: 828518 != 829440
V4L2GRABBER ERROR: Frame too small: 828526 != 829440
V4L2GRABBER ERROR: Frame too small: 828014 != 829440
V4L2GRABBER ERROR: Frame too small: 828646 != 829440
V4L2GRABBER ERROR: Frame too small: 828348 != 829440
V4L2GRABBER ERROR: Frame too small: 828756 != 829440
V4L2GRABBER ERROR: Frame too small: 828762 != 829440
V4L2GRABBER ERROR: Frame too small: 828252 != 829440
V4L2GRABBER ERROR: Frame too small: 828934 != 829440
V4L2GRABBER ERROR: Frame too small: 828310 != 829440
V4L2GRABBER ERROR: Frame too small: 827026 != 829440
V4L2GRABBER ERROR: Frame too small: 828818 != 829440
V4L2GRABBER ERROR: Frame too small: 828190 != 829440
V4L2GRABBER ERROR: Frame too small: 826544 != 829440
V4L2GRABBER ERROR: Frame too small: 828908 != 829440
V4L2GRABBER ERROR: Frame too small: 828232 != 829440
V4L2GRABBER ERROR: Frame too small: 828890 != 829440
V4L2GRABBER ERROR: Frame too small: 828420 != 829440
V4L2GRABBER ERROR: Frame too small: 825440 != 829440
V4L2GRABBER ERROR: Frame too small: 828472 != 829440
V4L2GRABBER ERROR: Frame too small: 828552 != 829440
V4L2GRABBER ERROR: Frame too small: 827498 != 829440
V4L2GRABBER ERROR: Frame too small: 828546 != 829440
V4L2GRABBER ERROR: Frame too small: 828842 != 829440
V4L2GRABBER ERROR: Frame too small: 825456 != 829440
V4L2GRABBER ERROR: Frame too small: 828680 != 829440
V4L2GRABBER ERROR: Frame too small: 826198 != 829440
V4L2GRABBER ERROR: Frame too small: 828630 != 829440
V4L2GRABBER ERROR: Frame too small: 828118 != 829440
V4L2GRABBER ERROR: Frame too small: 828194 != 829440
V4L2GRABBER ERROR: Frame too small: 828274 != 829440
V4L2GRABBER ERROR: Frame too small: 824802 != 829440
V4L2GRABBER ERROR: Frame too small: 825982 != 829440
V4L2GRABBER ERROR: Frame too small: 825388 != 829440
V4L2GRABBER ERROR: Frame too small: 828502 != 829440
V4L2GRABBER ERROR: Frame too small: 826632 != 829440
V4L2GRABBER ERROR: Frame too small: 827932 != 829440
V4L2GRABBER ERROR: Frame too small: 828878 != 829440
V4L2GRABBER ERROR: Frame too small: 827622 != 829440
V4L2GRABBER ERROR: Frame too small: 827958 != 829440
V4L2GRABBER ERROR: Frame too small: 828586 != 829440
V4L2GRABBER ERROR: Frame too small: 828716 != 829440
V4L2GRABBER ERROR: Frame too small: 828582 != 829440
V4L2GRABBER ERROR: Frame too small: 828092 != 829440
V4L2GRABBER ERROR: Frame too small: 828292 != 829440
V4L2GRABBER ERROR: Frame too small: 825450 != 829440
V4L2GRABBER ERROR: Frame too small: 828408 != 829440
V4L2GRABBER ERROR: Frame too small: 828488 != 829440
V4L2GRABBER ERROR: Frame too small: 828442 != 829440
V4L2GRABBER ERROR: Frame too small: 828676 != 829440
V4L2GRABBER ERROR: Frame too small: 828836 != 829440
V4L2GRABBER ERROR: Frame too small: 827434 != 829440
V4L2GRABBER ERROR: Frame too small: 827578 != 829440
V4L2GRABBER ERROR: Frame too small: 828084 != 829440
V4L2GRABBER ERROR: Frame too small: 828510 != 829440
V4L2GRABBER ERROR: Frame too small: 828596 != 829440
V4L2GRABBER ERROR: Frame too small: 828362 != 829440
V4L2GRABBER ERROR: Frame too small: 828718 != 829440
V4L2GRABBER ERROR: Frame too small: 828914 != 829440
V4L2GRABBER ERROR: Frame too small: 828754 != 829440
V4L2GRABBER ERROR: Frame too small: 825212 != 829440
V4L2GRABBER ERROR: Frame too small: 828784 != 829440
V4L2GRABBER ERROR: Frame too small: 827734 != 829440
V4L2GRABBER ERROR: Frame too small: 828244 != 829440
V4L2GRABBER ERROR: Frame too small: 828490 != 829440
V4L2GRABBER ERROR: Frame too small: 828402 != 829440
V4L2GRABBER ERROR: Frame too small: 828482 != 829440
V4L2GRABBER ERROR: Frame too small: 827484 != 829440
V4L2GRABBER ERROR: Frame too small: 828692 != 829440
V4L2GRABBER ERROR: Frame too small: 826812 != 829440
V4L2GRABBER ERROR: Frame too small: 827996 != 829440
V4L2GRABBER ERROR: Frame too small: 828512 != 829440
V4L2GRABBER ERROR: Frame too small: 828916 != 829440
V4L2GRABBER ERROR: Frame too small: 825972 != 829440
V4L2GRABBER ERROR: Frame too small: 824460 != 829440
V4L2GRABBER ERROR: Frame too small: 828816 != 829440
V4L2GRABBER ERROR: Frame too small: 827408 != 829440
V4L2GRABBER ERROR: Frame too small: 828912 != 829440
V4L2GRABBER ERROR: Frame too small: 828884 != 829440
V4L2GRABBER ERROR: Frame too small: 827572 != 829440
V4L2GRABBER ERROR: Frame too small: 828672 != 829440
V4L2GRABBER ERROR: Frame too small: 824046 != 829440
V4L2GRABBER ERROR: Frame too small: 828394 != 829440
V4L2GRABBER ERROR: Frame too small: 828504 != 829440
V4L2GRABBER ERROR: Frame too small: 828584 != 829440
V4L2GRABBER ERROR: Frame too small: 828662 != 829440
V4L2GRABBER ERROR: Frame too small: 828744 != 829440
V4L2GRABBER ERROR: Frame too small: 828072 != 829440
V4L2GRABBER ERROR: Frame too small: 823368 != 829440
V4L2GRABBER ERROR: Frame too small: 828150 != 829440
V4L2GRABBER ERROR: Frame too small: 828758 != 829440
V4L2GRABBER ERROR: Frame too small: 827496 != 829440
V4L2GRABBER ERROR: Frame too small: 828634 != 829440
V4L2GRABBER ERROR: Frame too small: 827246 != 829440
V4L2GRABBER ERROR: Frame too small: 828728 != 829440
V4L2GRABBER ERROR: Frame too small: 828432 != 829440
V4L2GRABBER ERROR: Frame too small: 828326 != 829440
V4L2GRABBER ERROR: Frame too small: 828406 != 829440
V4L2GRABBER ERROR: Frame too small: 825576 != 829440
V4L2GRABBER ERROR: Frame too small: 828088 != 829440
V4L2GRABBER ERROR: Frame too small: 828440 != 829440
V4L2GRABBER ERROR: Frame too small: 828340 != 829440
V4L2GRABBER ERROR: Frame too small: 828500 != 829440
V4L2GRABBER ERROR: Frame too small: 825860 != 829440
V4L2GRABBER ERROR: Frame too small: 828620 != 829440
V4L2GRABBER ERROR: Frame too small: 828598 != 829440
V4L2GRABBER ERROR: Frame too small: 828540 != 829440
V4L2GRABBER ERROR: Frame too small: 828628 != 829440
V4L2GRABBER ERROR: Frame too small: 827640 != 829440
V4L2GRABBER ERROR: Frame too small: 826648 != 829440
V4L2GRABBER ERROR: Frame too small: 827942 != 829440
V4L2GRABBER ERROR: Frame too small: 827126 != 829440
V4L2GRABBER ERROR: Frame too small: 827892 != 829440
V4L2GRABBER ERROR: Frame too small: 828664 != 829440
V4L2GRABBER ERROR: Frame too small: 828902 != 829440
V4L2GRABBER ERROR: Frame too small: 828278 != 829440
V4L2GRABBER ERROR: Frame too small: 828700 != 829440
V4L2GRABBER ERROR: Frame too small: 827376 != 829440
V4L2GRABBER ERROR: Frame too small: 827988 != 829440
V4L2GRABBER ERROR: Frame too small: 828686 != 829440
V4L2GRABBER ERROR: Frame too small: 827938 != 829440
V4L2GRABBER ERROR: Frame too small: 828932 != 829440
V4L2GRABBER ERROR: Frame too small: 828888 != 829440
V4L2GRABBER ERROR: Frame too small: 828696 != 829440
V4L2GRABBER ERROR: Frame too small: 828938 != 829440
V4L2GRABBER ERROR: Frame too small: 828800 != 829440
V4L2GRABBER ERROR: Frame too small: 828682 != 829440
V4L2GRABBER ERROR: Frame too small: 828288 != 829440
V4L2GRABBER ERROR: Frame too small: 828574 != 829440
V4L2GRABBER ERROR: Frame too small: 828898 != 829440
V4L2GRABBER ERROR: Frame too small: 828604 != 829440
V4L2GRABBER ERROR: Frame too small: 827832 != 829440
V4L2GRABBER ERROR: Frame too small: 828008 != 829440
V4L2GRABBER ERROR: Frame too small: 827426 != 829440
V4L2GRABBER ERROR: Frame too small: 828594 != 829440
V4L2GRABBER ERROR: Frame too small: 828674 != 829440
V4L2GRABBER ERROR: Frame too small: 828834 != 829440
V4L2GRABBER ERROR: Frame too small: 827142 != 829440
V4L2GRABBER ERROR: Frame too small: 828656 != 829440
V4L2GRABBER ERROR: Frame too small: 827238 != 829440
V4L2GRABBER ERROR: Frame too small: 824992 != 829440
V4L2GRABBER ERROR: Frame too small: 826728 != 829440
V4L2GRABBER ERROR: Frame too small: 828268 != 829440
V4L2GRABBER ERROR: Frame too small: 828920 != 829440
V4L2GRABBER ERROR: Frame too small: 828534 != 829440
V4L2GRABBER ERROR: Frame too small: 828936 != 829440
V4L2GRABBER ERROR: Frame too small: 828738 != 829440
V4L2GRABBER ERROR: Frame too small: 828880 != 829440
V4L2GRABBER ERROR: Frame too small: 828296 != 829440
V4L2GRABBER ERROR: Frame too small: 828264 != 829440
V4L2GRABBER ERROR: Frame too small: 828852 != 829440
V4L2GRABBER ERROR: Frame too small: 828864 != 829440
V4L2GRABBER ERROR: Frame too small: 828188 != 829440
V4L2GRABBER ERROR: Frame too small: 828196 != 829440
V4L2GRABBER ERROR: Frame too small: 828304 != 829440
V4L2GRABBER ERROR: Frame too small: 826610 != 829440
V4L2GRABBER ERROR: Frame too small: 828860 != 829440
V4L2GRABBER ERROR: Frame too small: 823742 != 829440
V4L2GRABBER ERROR: Frame too small: 828564 != 829440
V4L2GRABBER ERROR: Frame too small: 828642 != 829440
V4L2GRABBER ERROR: Frame too small: 827632 != 829440
V4L2GRABBER ERROR: Frame too small: 828428 != 829440
V4L2GRABBER ERROR: Frame too small: 828508 != 829440
V4L2GRABBER ERROR: Frame too small: 828444 != 829440
V4L2GRABBER ERROR: Frame too small: 828020 != 829440
V4L2GRABBER ERROR: Frame too small: 828352 != 829440
V4L2GRABBER ERROR: Frame too small: 828332 != 829440
V4L2GRABBER ERROR: Frame too small: 828412 != 829440
V4L2GRABBER ERROR: Frame too small: 828124 != 829440
V4L2GRABBER ERROR: Frame too small: 828354 != 829440
V4L2GRABBER ERROR: Frame too small: 828434 != 829440
V4L2GRABBER ERROR: Frame too small: 827712 != 829440
V4L2GRABBER ERROR: Frame too small: 828794 != 829440
V4L2GRABBER ERROR: Frame too small: 828360 != 829440
V4L2GRABBER ERROR: Frame too small: 828446 != 829440
V4L2GRABBER ERROR: Frame too small: 828774 != 829440
V4L2GRABBER ERROR: Frame too small: 828368 != 829440
V4L2GRABBER ERROR: Frame too small: 828314 != 829440
V4L2GRABBER ERROR: Frame too small: 828548 != 829440
V4L2GRABBER ERROR: Frame too small: 828764 != 829440
V4L2GRABBER ERROR: Frame too small: 827736 != 829440
V4L2GRABBER ERROR: Frame too small: 828248 != 829440
V4L2GRABBER ERROR: Frame too small: 828480 != 829440
V4L2GRABBER ERROR: Frame too small: 828342 != 829440
V4L2GRABBER ERROR: Frame too small: 828366 != 829440
V4L2GRABBER ERROR: Frame too small: 827998 != 829440
V4L2GRABBER ERROR: Frame too small: 828422 != 829440
V4L2GRABBER ERROR: Frame too small: 828026 != 829440
V4L2GRABBER ERROR: Frame too small: 827326 != 829440
V4L2GRABBER ERROR: Frame too small: 828234 != 829440
V4L2GRABBER ERROR: Frame too small: 828384 != 829440
V4L2GRABBER ERROR: Frame too small: 825672 != 829440
V4L2GRABBER ERROR: Frame too small: 828666 != 829440
V4L2GRABBER ERROR: Frame too small: 828240 != 829440
V4L2GRABBER ERROR: Frame too small: 828576 != 829440
V4L2GRABBER ERROR: Frame too small: 828170 != 829440
V4L2GRABBER ERROR: Frame too small: 828330 != 829440
V4L2GRABBER ERROR: Frame too small: 828520 != 829440
V4L2GRABBER ERROR: Frame too small: 828554 != 829440
V4L2GRABBER ERROR: Frame too small: 828220 != 829440
V4L2GRABBER ERROR: Frame too small: 828572 != 829440
V4L2GRABBER ERROR: Frame too small: 828212 != 829440
V4L2GRABBER ERROR: Frame too small: 827526 != 829440
V4L2GRABBER ERROR: Frame too small: 828626 != 829440
V4L2GRABBER ERROR: Frame too small: 828420 != 829440das geht dann immer so weiter bis zum Sanktnimmerleinstag, hab den Pi dann "ausgeschaltet"
Jetzt zum Problem,
Meiner meinung nach ist die Verkabelung in ordung, Hab so auch schon über das Farbrad im SSH Tab problemlos alle Farben einstellen können.
Wenn ich jetzt aber ein Viedeosignal über den Grabber einspeise, funktioniert es nicht, die LED bleiben einfach aus.
Das Problem ist warscheinlich der schwarze rand um das bild das vom Grabber kommt?
https://www.amazon.de/clouddrive/share/7tHLp8IhrIYgXljoshvEtfOhlE8lluSbd5TeG87Oik9?ref_=cd_ph_share_link_copy
Daher dann schön die Pixel gemessen, die weg sollen. Dann im Hyperion entsprechend eingegeben, auf den Pi geladen und siehe da.. Nix, schwarze Balken immer noch da.
Hab jetzt schon ne weile gesucht, aber außer aussagen man soll doch im Google nach dem Problem suchen nix gefunden..
Jetzt hoffe ich voll und ganz auf eure Hilfe, bin jedem Dankbar der mich weiter bringt, ich seh inzwischen glaub den Wald vor lauter Bäume nimmer..
