WS2801
deutliche Fotos deiner Verkabelung, vor allem so das man die Verbindungen vom PI zum Stripe durchgehend (!) erkennen kann
folgt
deine /boot/config.txt
# hdmi_force_hotplug=1
deine hyperion.config.json
"colorOrder" : "rbg"
"luminanceGain" : 1.0000,
"threshold" : 0.1000,
"time_ms" : 100,
// V4L2 GRABBER CONFIG
"width" : 720,
"height" : 480,
"sizeDecimation" : 8,
"priority" : 900,
"cropLeft" : 0,
"cropRight" : 0,
"cropTop" : 0,
"cropBottom" : 0,
"redSignalThreshold" : 0.0,
"greenSignalThreshold" : 0.0,
"blueSignalThreshold" : 0.0
// FRAME GRABBER CONFIG
"threshold" : 0.01,
// KODI CHECK CONFIG
"grabMenu" : false,
"grabPause" : true,
"hscan" : { "minimum" : 0.5000, "maximum" : 0.5385 },
"hscan" : { "minimum" : 0.5385, "maximum" : 0.5769 },
"hscan" : { "minimum" : 0.5769, "maximum" : 0.6154 },
"hscan" : { "minimum" : 0.6154, "maximum" : 0.6538 },
"hscan" : { "minimum" : 0.6538, "maximum" : 0.6923 },
"hscan" : { "minimum" : 0.6923, "maximum" : 0.7308 },
"hscan" : { "minimum" : 0.7308, "maximum" : 0.7692 },
"hscan" : { "minimum" : 0.7692, "maximum" : 0.8077 },
"hscan" : { "minimum" : 0.8077, "maximum" : 0.8462 },
"hscan" : { "minimum" : 0.8462, "maximum" : 0.8846 },
"hscan" : { "minimum" : 0.8846, "maximum" : 0.9231 },
"hscan" : { "minimum" : 0.9231, "maximum" : 0.9615 },
"hscan" : { "minimum" : 0.9615, "maximum" : 1.0000 },
"vscan" : { "minimum" : 0.8125, "maximum" : 0.8750 }
"vscan" : { "minimum" : 0.7500, "maximum" : 0.8125 }
"vscan" : { "minimum" : 0.6875, "maximum" : 0.7500 }
"vscan" : { "minimum" : 0.6250, "maximum" : 0.6875 }
"vscan" : { "minimum" : 0.5625, "maximum" : 0.6250 }
"vscan" : { "minimum" : 0.5000, "maximum" : 0.5625 }
"vscan" : { "minimum" : 0.4375, "maximum" : 0.5000 }
"vscan" : { "minimum" : 0.3750, "maximum" : 0.4375 }
"vscan" : { "minimum" : 0.3125, "maximum" : 0.3750 }
"vscan" : { "minimum" : 0.2500, "maximum" : 0.3125 }
"vscan" : { "minimum" : 0.1875, "maximum" : 0.2500 }
"vscan" : { "minimum" : 0.1250, "maximum" : 0.1875 }
"vscan" : { "minimum" : 0.0625, "maximum" : 0.1250 }
"hscan" : { "minimum" : 0.4615, "maximum" : 0.5000 },
"hscan" : { "minimum" : 0.4231, "maximum" : 0.4615 },
"hscan" : { "minimum" : 0.3846, "maximum" : 0.4231 },
"hscan" : { "minimum" : 0.3462, "maximum" : 0.3846 },
"hscan" : { "minimum" : 0.3077, "maximum" : 0.3462 },
"hscan" : { "minimum" : 0.2692, "maximum" : 0.3077 },
"hscan" : { "minimum" : 0.2308, "maximum" : 0.2692 },
"hscan" : { "minimum" : 0.1923, "maximum" : 0.2308 },
"hscan" : { "minimum" : 0.1538, "maximum" : 0.1923 },
"hscan" : { "minimum" : 0.1154, "maximum" : 0.1538 },
"hscan" : { "minimum" : 0.0769, "maximum" : 0.1154 },
"hscan" : { "minimum" : 0.0385, "maximum" : 0.0769 },
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0385 },
Screenshots des Hyperion GUI Tools womit du deine LEDs konfiguriert hast (von jedem Tab einen)
http://fs5.directupload.net/images/160809/rhuyr7yh.png
http://fs5.directupload.net/images/160809/hy3ig7ik.png
http://fs5.directupload.net/images/160809/yidrwmyh.png
http://fs5.directupload.net/images/160809/3s5lopag.png
http://fs5.directupload.net/images/160809/mu3ngqu7.png
Angabe wo deine erste LED am TV montiert ist (von vorne Betrachtet)
http://fs5.directupload.net/images/160809/temp/eqmidlil.png
1. Led befindet sich unten mittig.
Die Leds sind einmal rundherum, ohne eine LED-Lücke unten.
Angabe ob die Steuerung von Hyperion mit einer der Apps aus Beitrag #3 in diesem Thema funktionieren
Steuerung mittels Hyperion-App funktioniert einwandfrei. Es werden die richtigen Farben dargestellt.
die Ausgabe der nachfolgenden Befehle mittels SSH(Putty)
http://fs5.directupload.net/images/160809/lwxuqb28.png
Sonstiges
Das Bild was beim Raspberry ankommt sieht wie folgt aus:
http://fs5.directupload.net/images/160809/oq67qewz.png
Da Original Bild war dies:
http://fs5.directupload.net/images/160809/r2fz2e9s.jpg
wobei das original Bild weggezoomt wurde, sodass ein schwarzer Rand zu sehen war.
- Regenbogeneffekt beim Starten von Kodi wird richtig dargestellt.
- LEDs leuchten trotz Schwarzwertes vereinzelt weiterhin blau
