Ja, wie im ersten Post geschrieben.
Die Fehlermeldung hat sich jetzt auch erledigt.
OpenELEC:~/.config # killall hyperiond
hyperion-v4l2:
version : V1.03.2 (brindosch-99d9396/d3713a8-1469452981
build time: Jul 25 2016 06:54:40
V4L2GRABBER ERROR: Cannot identify '/dev/video0' ERROR 2, No such file or directory
OpenELEC:~/.config # /storage/hyperion/bin/hyperiond.sh /storage/.config/hyperio
n.config.json
Hyperion Ambilight Deamon (805)
HYPERION INFO: ColorTransform 'default' => [0; 101]
HYPERION INFO: ColorCorrection 'default' => [0; 101]
HYPERION INFO: ColorAdjustment 'default' => [0; 101]
"colorOrder" : "rbg",
[code]SSH Traffic:
ssh connected
ssh in: Hyperion Ambilight Deamon (328)
ssh in: Version : V1.03.2 (brindosch-99d9396/d3713a8-1469452981
ssh in: Build Time: Jul 25 2016 06:54:40
ssh in: HYPERION INFO: ColorTransform 'default' => [0; 101]
ssh in: HYPERION INFO: ColorCorrection 'default' => [0; 101]
ssh in: HYPERION INFO: ColorAdjustment 'default' => [0; 101]
ssh in: {
ssh in: "colorOrder" : "rbg",
ssh in: "rate" : 1000000,
ssh in: "type" : "ws2801"
ssh in: }
ssh in: HYPERION (CS) INFO: Created linear-smoothing(interval_ms=50;settlingTime_ms=200;updateDelay=0
ssh in: BLACKBORDER INFO: threshold set to 0.01 (3)
ssh in: started
ssh in: DISPMANXGRABBER INFO: Display opened with resolution: 1920x1080
ssh in: INFO: Frame grabber created and started
ssh in: KODICHECK ERROR: Kodi Connection error (0)
ssh in: EFFECTENGINE INFO: effect finished
ssh in: BORDER SWITCH REQUIRED!!
ssh in: CURRENT BORDER TYPE: unknown=0 hor.size=0 vert.size=0
ssh disconnected
ssh connected
ssh in: Hyperion Ambilight Deamon (325)
ssh in: {
ssh in: }
ssh in: started
ssh in: KODICHECK INFO: Kodi Connected
ssh in: KODICHECK INFO: switching to OFF mode
ssh in: JSONSERVER INFO: New connection
ssh in: JSONSERVER INFO: Connection closed
ssh in: EFFECTENGINE INFO: run effect Cinema dim lights on channel 0
ssh in: EFFECTENGINE INFO: run effect UDP multicast listener on channel 0
ssh in: udp.py: Listening on 239.255.28.01:2801
ssh in: ListenIP is a multicast address
ssh in: EFFECTENGINE INFO: run effect UDP listener on channel 0
ssh in: udp.py: closing socket
ssh in: udp.py: Listening on *.*.*.*:2391
ssh in: EFFECTENGINE INFO: run effect Color traces on channel 0
ssh in: EFFECTENGINE INFO: run effect System Shutdown on channel 0
ssh in: EFFECTENGINE INFO: run effect Cinema brighten lights on channel 0
ssh in: INFO: Application closed with code 0
ssh in: KODICHECK INFO: Kodi Disconnected
ssh in: EFFECTENGINE INFO: Cleaning up Python interpreter
sftp Send Hyperion Config - Sourcepath: C:/Users/nico/Desktop/Nico, Targetpath: /storage/.config/, Filename: hyperion.config.json[/code]
Ich weiß weiterhin nicht warum Ambilight nicht richtig funktioniert, nur per App-Steuerung einfarbig.
