Profixd
Grabber Screenshoot mit grünstich
20. Mär 2016, 21:29
Hallo
Habe einen Screenshoot gemach ind das Bild hat einen festen Grünstich.
An was Könnte das liegen?
Sir_Vival
21. Mär 2016, 07:02
Magst du uns deine Config und Aufbau dazu auch erklären oder sollen wir darauf losraten?
Profixd
21. Mär 2016, 08:39
Ich habe den empfohlenen Grabber.
Ich habe den Grabber am Cinch Ausgang meines Recivers angsteckt.(Hdmi geht zum Tv). Die config stelle ich gleich hinein
Profixd
21. Mär 2016, 09:39
      "name"       : "MyPi",
      "rate"       : 250000,
               "saturationGain" : 1.0500,
               "valueGain"      : 1.0000
               "threshold"  : 0.1900,
               "gamma"      : 2.0000,
               "gamma"      : 2.0000,
               "whitelevel" : 0.8000
               "gamma"      : 2.0000,
         "updateFrequency" : 25.0000
         "hscan" : { "minimum" : 0.7097, "maximum" : 0.7419 },
         "hscan" : { "minimum" : 0.7419, "maximum" : 0.7742 },
         "hscan" : { "minimum" : 0.7742, "maximum" : 0.8065 },
         "hscan" : { "minimum" : 0.8065, "maximum" : 0.8387 },
         "hscan" : { "minimum" : 0.8387, "maximum" : 0.8710 },
         "hscan" : { "minimum" : 0.8710, "maximum" : 0.9032 },
         "hscan" : { "minimum" : 0.9032, "maximum" : 0.9355 },
         "hscan" : { "minimum" : 0.9355, "maximum" : 0.9677 },
         "hscan" : { "minimum" : 0.9677, "maximum" : 1.0000 },
         "hscan" : { "minimum" : 0.6774, "maximum" : 0.7097 },
         "hscan" : { "minimum" : 0.6452, "maximum" : 0.6774 },
         "hscan" : { "minimum" : 0.6129, "maximum" : 0.6452 },
         "hscan" : { "minimum" : 0.5806, "maximum" : 0.6129 },
         "hscan" : { "minimum" : 0.5484, "maximum" : 0.5806 },
         "hscan" : { "minimum" : 0.5161, "maximum" : 0.5484 },
         "hscan" : { "minimum" : 0.4839, "maximum" : 0.5161 },
         "hscan" : { "minimum" : 0.4516, "maximum" : 0.4839 },
         "hscan" : { "minimum" : 0.4194, "maximum" : 0.4516 },
         "hscan" : { "minimum" : 0.3871, "maximum" : 0.4194 },
         "hscan" : { "minimum" : 0.3548, "maximum" : 0.3871 },
         "hscan" : { "minimum" : 0.3226, "maximum" : 0.3548 },
         "hscan" : { "minimum" : 0.2903, "maximum" : 0.3226 },
         "hscan" : { "minimum" : 0.2581, "maximum" : 0.2903 },
         "hscan" : { "minimum" : 0.2258, "maximum" : 0.2581 },
         "hscan" : { "minimum" : 0.1935, "maximum" : 0.2258 },
         "hscan" : { "minimum" : 0.1613, "maximum" : 0.1935 },
         "hscan" : { "minimum" : 0.1290, "maximum" : 0.1613 },
         "hscan" : { "minimum" : 0.0968, "maximum" : 0.1290 },
         "hscan" : { "minimum" : 0.0645, "maximum" : 0.0968 },
         "hscan" : { "minimum" : 0.0323, "maximum" : 0.0645 },
         "hscan" : { "minimum" : 0.0000, "maximum" : 0.0323 },
      "threshold" : 0.14
//    "xbmcVideoChecker" :
//       "grabVideo" : true,
//       "grabAudio" : true,
//       "grabMenu" : false,
//    "boblightServer" :
//       "port" : 19333
Profixd
21. Mär 2016, 09:44
Habe es jetzt behoben, aber das Ambilight geht trotzdem nicht.
Obwohl beim Screenshot ein bild kommt.
Sir_Vival
21. Mär 2016, 09:50
Okay wie behoben?
Ambilight geht trotzdem nicht bedeutet das es nur über den Grabber nicht geht aber per APP und über Kodi funktioniet?
viewtopic.php?f=8&t=836
Profixd
21. Mär 2016, 10:24
Hallo
Ich habe im Config auf PAL gestellt, jetzt funktioniert das Ambiight, aber die App nicht.
Sir_Vival
21. Mär 2016, 10:29
Na ja mit APP funktioniert nicht kann dir keiner Helfen... Du solltest dich erstmal einlesen und mit den sachen beschäftigen/auseinandersetzen....
PS: Trag mal die IP (ADD-Server) vom RPI in den Settings vom Hyperion APP ein...
Profixd
21. Mär 2016, 10:36
Habe ich schon,gestern hat sie funktioniert heute nicht
21. Mär 2016, 10:38
Dann hat dein RPI wohl eine neue IP bekommen ;)
Bilder kannst du Anhängen wenn du hier unten mal auf "Vollständiger Editor" klickst..
Profixd
21. Mär 2016, 11:00
Nein das glaube ich eher nicht, denn SSH funktioniert mit der IP
