moppelmannihase
externe Geräte funktionieren nicht vernünftig
20. Apr 2016, 19:01
das HDMI-Signal wird irgendwie nicht vernünftig umgewandelt. Woran kann das liegen?
Mal funktioniert es, aber zu 90% kommt kein vernünftiges Signal an, woran kann das liegen?
Geräte sind alle an den Strom angeschlossen.
https://www.dropbox.com/sh/5yercmabrevp ... rBSDa?dl=0
Folgende Geräte habe ich
https://www.amazon.de/gp/product/B01AG0 ... UTF8&psc=1
https://www.amazon.de/gp/product/B00ESD ... UTF8&psc=1
https://www.amazon.de/gp/product/B01615 ... UTF8&psc=1
Hyperion-Datei:
// Created with HyperCon V1.01.2 (31.03.2016)
      "rate"     : 250000,
      "colorOrder" : "rbg"
      "correction" :
            "temperatureValues" :
               "saturationGain"   : 1.0500,
               "valueGain"      : 1.0000
               "luminanceGain"   : 1.0000
               "threshold"    : 0.1900,
               "gamma"        : 2.0000,
               "blacklevel"   : 0.0000,
               "whitelevel"   : 0.8800
               "gamma"        : 2.0000,
               "whitelevel"   : 1.0000
               "gamma"        : 2.0000,
               "whitelevel"   : 0.3600
      "threshold" : 0.14,
//    "bootsequence" :
//       "color" : [0,0,0],
//       "effect" : "Random",
//       "duration_ms" : 3000,
//       "priority" : 990
   "forwarder" :
      "proto" : ["127.0.0.1:19447"],
      "json" : ["127.0.0.1:19446"]
   ///   * priority     : The priority of the frame-gabber (Default=890) HINT: lower value result in HIGHER priority!
//    "framegrabber" :
//       "width" : 80,
//       "height" : 45,
//       "frequency_Hz" : 10.0,
//       "priority" : 890
//    "boblightServer" :
//       "port" : 19333,
//       "priority" : 900
   ///  * priority             : Hyperion priority channel [default=900]
      "standard" : "no-change",
         "hscan" : { "minimum" : 0.6800, "maximum" : 0.7200 },
         "hscan" : { "minimum" : 0.7200, "maximum" : 0.7600 },
         "hscan" : { "minimum" : 0.7600, "maximum" : 0.8000 },
         "hscan" : { "minimum" : 0.8000, "maximum" : 0.8400 },
         "hscan" : { "minimum" : 0.8400, "maximum" : 0.8800 },
         "hscan" : { "minimum" : 0.8800, "maximum" : 0.9200 },
         "hscan" : { "minimum" : 0.9200, "maximum" : 0.9600 },
         "hscan" : { "minimum" : 0.9600, "maximum" : 1.0000 },
         "vscan" : { "minimum" : 0.9333, "maximum" : 1.0000 }
         "vscan" : { "minimum" : 0.8667, "maximum" : 0.9333 }
         "vscan" : { "minimum" : 0.8000, "maximum" : 0.8667 }
         "vscan" : { "minimum" : 0.7333, "maximum" : 0.8000 }
         "vscan" : { "minimum" : 0.6667, "maximum" : 0.7333 }
         "vscan" : { "minimum" : 0.6000, "maximum" : 0.6667 }
         "vscan" : { "minimum" : 0.5333, "maximum" : 0.6000 }
         "vscan" : { "minimum" : 0.4667, "maximum" : 0.5333 }
         "vscan" : { "minimum" : 0.4000, "maximum" : 0.4667 }
         "vscan" : { "minimum" : 0.3333, "maximum" : 0.4000 }
         "vscan" : { "minimum" : 0.2667, "maximum" : 0.3333 }
         "vscan" : { "minimum" : 0.2000, "maximum" : 0.2667 }
         "vscan" : { "minimum" : 0.1333, "maximum" : 0.2000 }
         "vscan" : { "minimum" : 0.0667, "maximum" : 0.1333 }
         "vscan" : { "minimum" : 0.0000, "maximum" : 0.0667 }
         "hscan" : { "minimum" : 0.6400, "maximum" : 0.6800 },
         "hscan" : { "minimum" : 0.6000, "maximum" : 0.6400 },
         "hscan" : { "minimum" : 0.5600, "maximum" : 0.6000 },
         "hscan" : { "minimum" : 0.5200, "maximum" : 0.5600 },
         "hscan" : { "minimum" : 0.4800, "maximum" : 0.5200 },
         "hscan" : { "minimum" : 0.4400, "maximum" : 0.4800 },
         "hscan" : { "minimum" : 0.4000, "maximum" : 0.4400 },
         "hscan" : { "minimum" : 0.3600, "maximum" : 0.4000 },
         "hscan" : { "minimum" : 0.3200, "maximum" : 0.3600 },
         "hscan" : { "minimum" : 0.2800, "maximum" : 0.3200 },
         "hscan" : { "minimum" : 0.2400, "maximum" : 0.2800 },
         "hscan" : { "minimum" : 0.2000, "maximum" : 0.2400 },
         "hscan" : { "minimum" : 0.1600, "maximum" : 0.2000 },
         "hscan" : { "minimum" : 0.1200, "maximum" : 0.1600 },
         "hscan" : { "minimum" : 0.0800, "maximum" : 0.1200 },
         "hscan" : { "minimum" : 0.0400, "maximum" : 0.0800 },
         "hscan" : { "minimum" : 0.0000, "maximum" : 0.0400 },
Spegeli
20. Apr 2016, 21:52
Also die Geräte sind schon mal die richtigen.
Änder mal: "standard" : "no-change",
in: "standard" : "PAL",
und ist der Converter auch auf PAL gestellt?
Falls das keine Besserung bringt, versuch es mal bitte mit einer anderen HDMI Quelle (DVD-Player, PlayStation oder so) um raus zu finden ob es evtl. an dem Signal liegt das der Sky Receiver ausgibt.
21. Apr 2016, 10:22
Im Sky Receiver die BILD/HDMI Verbesserungen abschalten wenn vorhanden (TrueColor, 32Bit Farben o.ä.).
Dann wie Spegeli schreibt NTSC/PAL in allen Kombinationen (!) testen
Konverter NTSC; Hyperion PAL
Konverter NTSC; Hyperion NTSC
Konverter PAL; Hyperion NTSC
Konverter PAL; Hyperion PAL
eine der vier Kombinationen sollte das richtige Bild bringen.
moppelmannihase
21. Apr 2016, 19:32
Ok, hab's jetzt mal auf NTSC gestellt und den Converter auf PAL und jetzt scheint zu funktionieren.
Lag auch an den Bildverbesserungen bei der PS4.
Spegeli
21. Apr 2016, 19:34
Stell mal den Converter auf NTSC und in Hyperion auf PAL.
Wenn dort das Bild auch Fehlerfrei angezeigt wird, nim das.
22. Apr 2016, 09:06
Wenn es geht lass es so, PAL ist in Deutschland am verbreitesten ;)
