piBenni
Ambilight Grabber Probleme
17. Jun 2016, 21:53
1: WS2801 http://de.aliexpress.com/item/colorful- ... 79647.html
2:https://www.amazon.de/clouddrive/share/Ne1btVPv90nTCZj8MU3yuunihwZTeeds4QxWl3GPM1h?ref_=cd_ph_share_link_copy
https://www.amazon.de/clouddrive/share/pgxfKdDgtUW3RkAUASPuD75ZtT48mB8XfA1AIAWFfyV?ref_=cd_ph_share_link_copy
https://www.amazon.de/clouddrive/share/tEm8Ejpfh3rSHRS0uV2AFnHtoiwBLsYq2x6EwzVjKDw?ref_=cd_ph_share_link_copy
ich hoff das reicht so mit den Bildern, sonst muss ich den TV runter nehmen und von hinten Forografieren..
Verkabelung ist zur zeit eh nur provisorisch, das richtige kabel muss ich noch mal neu Löten, ist ein anderes Problem..
3:
# hdmi_force_hotplug=1
// Created with HyperCon V1.02.0 (30.04.2016)
      "rate"     : 1000000,
      "colorOrder" : "rbg"
   ///  * 'channelAdjustment'
   ///  * 'id'   : The unique identifier of the channel adjustments (eg 'device_1')
   ///  * 'leds'   : The indices (or index ranges) of the leds to which this channel adjustment applies
   ///             (eg '0-5, 9, 11, 12-17'). The indices are zero based.
   ///  * 'pureRed'/'pureGreen'/'pureBlue' : The manipulation in the Red-Green-Blue color domain with the
   ///  * 'temperature'
   ///  * 'id'   : The unique identifier of the temperature (eg 'device_1')
   ///  * 'leds'   : The indices (or index ranges) of the leds to which this temperature applies
   ///  * 'red'/'green'/'blue' : The temperature manipulation in the Red-Green-Blue color domain with the
   ///  * 'transform'
   ///  * 'id'   : The unique identifier of the color transformation (eg 'device_1')
   ///  * 'leds' : The indices (or index ranges) of the leds to which this color transform applies
   ///  * 'hsv' : The manipulation in the Hue-Saturation-Value color domain with the following
   ///            - 'luminanceGain'       The gain adjustement of the luminance
               "redChannel"      : 245,
               "blueChannel"      : 10
               "redChannel"      : 180,
               "greenChannel"      : 255,
               "blueChannel"      : 192
            "temperatureValues" :
               "luminanceGain"      : 1.0500
               "gamma"        : 29.4900
               "gamma"        : 2.5100
               "gamma"        : 2.5000
      "threshold" : 0.03,
      "priority" : 990
//    "forwarder" :
//    "framegrabber" :
//       "width" : 64,
//       "height" : 64,
//       "priority" : 890
//    "xbmcVideoChecker" :
//       "grabVideo" : true,
//       "grabAudio" : true,
//       "grabMenu" : true,
//    "boblightServer" :
//       "port" : 19333,
//       "priority" : 900
      "sizeDecimation" : 8,
      "priority" : 900,
      "cropLeft" : 3,
      "cropRight" : 5,
      "cropTop" : 4,
      "cropBottom" : 5,
      "redSignalThreshold" : 0.2,
      "greenSignalThreshold" : 0.2,
      "blueSignalThreshold" : 0.2
https://www.amazon.de/clouddrive/share/qMi8r2USYR1iQKMGi4gBDVUtTnCMt25PxP77cYTPbKY?ref_=cd_ph_share_link_copy
6: Unten mitte rechts
7: nicht getestet
8:
.json
Hyperion Ambilight Deamon
        Version   : V1.02.0 (brindosch-f4162eb/2d45d51-1462453507
        Build Time: May  5 2016 06:07:47
HYPERION INFO: ColorTransform 'default' => [0; 91]
HYPERION INFO: ColorCorrection 'default' => [0; 91]
HYPERION INFO: ColorAdjustment 'default' => [0; 91]
        "colorOrder" : "rbg",
BLACKBORDER INFO: threshold set to 0.03 (8)
V4L2GRABBER INFO: pixel format=UYVY
V4L2GRABBER INFO: signal threshold set to: {51,51,51}
V4L2GRABBER INFO: started
V4L2GRABBER ERROR: Frame too small: 828830 != 829440
V4L2GRABBER ERROR: Frame too small: 828514 != 829440
BORDER SWITCH REQUIRED!!
V4L2GRABBER INFO: stopped
V4L2GRABBER ERROR: Frame too small: 828580 != 829440
V4L2GRABBER ERROR: Frame too small: 828812 != 829440
V4L2GRABBER ERROR: Frame too small: 828670 != 829440
V4L2GRABBER ERROR: Frame too small: 828282 != 829440
V4L2GRABBER ERROR: Frame too small: 828168 != 829440
V4L2GRABBER ERROR: Frame too small: 828210 != 829440
V4L2GRABBER ERROR: Frame too small: 826080 != 829440
V4L2GRABBER ERROR: Frame too small: 827936 != 829440
V4L2GRABBER ERROR: Frame too small: 828322 != 829440
V4L2GRABBER ERROR: Frame too small: 828854 != 829440
V4L2GRABBER ERROR: Frame too small: 828338 != 829440
V4L2GRABBER ERROR: Frame too small: 828430 != 829440
V4L2GRABBER ERROR: Frame too small: 828284 != 829440
V4L2GRABBER ERROR: Frame too small: 828750 != 829440
V4L2GRABBER ERROR: Frame too small: 825812 != 829440
V4L2GRABBER ERROR: Frame too small: 828136 != 829440
V4L2GRABBER ERROR: Frame too small: 827808 != 829440
V4L2GRABBER ERROR: Frame too small: 828172 != 829440
V4L2GRABBER ERROR: Frame too small: 827848 != 829440
V4L2GRABBER ERROR: Frame too small: 828736 != 829440
V4L2GRABBER ERROR: Frame too small: 828218 != 829440
V4L2GRABBER ERROR: Frame too small: 828644 != 829440
V4L2GRABBER ERROR: Frame too small: 828182 != 829440
V4L2GRABBER ERROR: Frame too small: 828848 != 829440
V4L2GRABBER ERROR: Frame too small: 828844 != 829440
V4L2GRABBER ERROR: Frame too small: 828246 != 829440
V4L2GRABBER ERROR: Frame too small: 827268 != 829440
V4L2GRABBER ERROR: Frame too small: 825564 != 829440
V4L2GRABBER ERROR: Frame too small: 828148 != 829440
V4L2GRABBER ERROR: Frame too small: 828270 != 829440
V4L2GRABBER ERROR: Frame too small: 828788 != 829440
V4L2GRABBER ERROR: Frame too small: 828228 != 829440
V4L2GRABBER ERROR: Frame too small: 828822 != 829440
V4L2GRABBER ERROR: Frame too small: 828668 != 829440
V4L2GRABBER ERROR: Frame too small: 828690 != 829440
V4L2GRABBER ERROR: Frame too small: 827626 != 829440
V4L2GRABBER ERROR: Frame too small: 827930 != 829440
V4L2GRABBER ERROR: Frame too small: 828238 != 829440
V4L2GRABBER ERROR: Frame too small: 828276 != 829440
V4L2GRABBER ERROR: Frame too small: 828714 != 829440
V4L2GRABBER ERROR: Frame too small: 824762 != 829440
V4L2GRABBER ERROR: Frame too small: 828746 != 829440
V4L2GRABBER ERROR: Frame too small: 828560 != 829440
V4L2GRABBER ERROR: Frame too small: 828346 != 829440
V4L2GRABBER ERROR: Frame too small: 828704 != 829440
V4L2GRABBER ERROR: Frame too small: 828464 != 829440
V4L2GRABBER ERROR: Frame too small: 828544 != 829440
V4L2GRABBER ERROR: Frame too small: 828624 != 829440
V4L2GRABBER ERROR: Frame too small: 828702 != 829440
V4L2GRABBER ERROR: Frame too small: 828782 != 829440
V4L2GRABBER ERROR: Frame too small: 828862 != 829440
V4L2GRABBER ERROR: Frame too small: 828942 != 829440
V4L2GRABBER ERROR: Frame too small: 828712 != 829440
V4L2GRABBER ERROR: Frame too small: 828222 != 829440
V4L2GRABBER ERROR: Frame too small: 827780 != 829440
V4L2GRABBER ERROR: Frame too small: 827924 != 829440
V4L2GRABBER ERROR: Frame too small: 827270 != 829440
V4L2GRABBER ERROR: Frame too small: 827580 != 829440
V4L2GRABBER ERROR: Frame too small: 828522 != 829440
V4L2GRABBER ERROR: Frame too small: 828602 != 829440
V4L2GRABBER ERROR: Frame too small: 828752 != 829440
V4L2GRABBER ERROR: Frame too small: 828832 != 829440
V4L2GRABBER ERROR: Frame too small: 828910 != 829440
V4L2GRABBER ERROR: Frame too small: 828236 != 829440
V4L2GRABBER ERROR: Frame too small: 827334 != 829440
V4L2GRABBER ERROR: Frame too small: 828376 != 829440
V4L2GRABBER ERROR: Frame too small: 828416 != 829440
V4L2GRABBER ERROR: Frame too small: 827488 != 829440
V4L2GRABBER ERROR: Frame too small: 828856 != 829440
V4L2GRABBER ERROR: Frame too small: 828358 != 829440
V4L2GRABBER ERROR: Frame too small: 828454 != 829440
V4L2GRABBER ERROR: Frame too small: 828748 != 829440
V4L2GRABBER ERROR: Frame too small: 828484 != 829440
V4L2GRABBER ERROR: Frame too small: 828530 != 829440
V4L2GRABBER ERROR: Frame too small: 828260 != 829440
V4L2GRABBER ERROR: Frame too small: 828344 != 829440
V4L2GRABBER ERROR: Frame too small: 828820 != 829440
V4L2GRABBER ERROR: Frame too small: 828398 != 829440
V4L2GRABBER ERROR: Frame too small: 828104 != 829440
V4L2GRABBER ERROR: Frame too small: 828114 != 829440
V4L2GRABBER ERROR: Frame too small: 826032 != 829440
V4L2GRABBER ERROR: Frame too small: 828154 != 829440
V4L2GRABBER ERROR: Frame too small: 827382 != 829440
V4L2GRABBER ERROR: Frame too small: 827500 != 829440
V4L2GRABBER ERROR: Frame too small: 827724 != 829440
V4L2GRABBER ERROR: Frame too small: 827174 != 829440
V4L2GRABBER ERROR: Frame too small: 828868 != 829440
V4L2GRABBER ERROR: Frame too small: 828570 != 829440
V4L2GRABBER ERROR: Frame too small: 828418 != 829440
V4L2GRABBER ERROR: Frame too small: 828498 != 829440
V4L2GRABBER ERROR: Frame too small: 828918 != 829440
V4L2GRABBER ERROR: Frame too small: 828900 != 829440
V4L2GRABBER ERROR: Frame too small: 827694 != 829440
V4L2GRABBER ERROR: Frame too small: 827978 != 829440
V4L2GRABBER ERROR: Frame too small: 828438 != 829440
V4L2GRABBER ERROR: Frame too small: 828290 != 829440
V4L2GRABBER ERROR: Frame too small: 828300 != 829440
V4L2GRABBER ERROR: Frame too small: 827292 != 829440
V4L2GRABBER ERROR: Frame too small: 828350 != 829440
V4L2GRABBER ERROR: Frame too small: 828476 != 829440
V4L2GRABBER ERROR: Frame too small: 828632 != 829440
V4L2GRABBER ERROR: Frame too small: 828866 != 829440
V4L2GRABBER ERROR: Frame too small: 828524 != 829440
V4L2GRABBER ERROR: Frame too small: 828364 != 829440
V4L2GRABBER ERROR: Frame too small: 827624 != 829440
V4L2GRABBER ERROR: Frame too small: 828654 != 829440
V4L2GRABBER ERROR: Frame too small: 828588 != 829440
V4L2GRABBER ERROR: Frame too small: 828036 != 829440
V4L2GRABBER ERROR: Frame too small: 827348 != 829440
V4L2GRABBER ERROR: Frame too small: 828824 != 829440
V4L2GRABBER ERROR: Frame too small: 828374 != 829440
V4L2GRABBER ERROR: Frame too small: 828622 != 829440
V4L2GRABBER ERROR: Frame too small: 828770 != 829440
V4L2GRABBER ERROR: Frame too small: 827960 != 829440
V4L2GRABBER ERROR: Frame too small: 824794 != 829440
V4L2GRABBER ERROR: Frame too small: 828922 != 829440
V4L2GRABBER ERROR: Frame too small: 828318 != 829440
V4L2GRABBER ERROR: Frame too small: 828204 != 829440
V4L2GRABBER ERROR: Frame too small: 828780 != 829440
V4L2GRABBER ERROR: Frame too small: 827630 != 829440
V4L2GRABBER ERROR: Frame too small: 828578 != 829440
V4L2GRABBER ERROR: Frame too small: 827672 != 829440
V4L2GRABBER ERROR: Frame too small: 828404 != 829440
V4L2GRABBER ERROR: Frame too small: 828380 != 829440
V4L2GRABBER ERROR: Frame too small: 828730 != 829440
V4L2GRABBER ERROR: Frame too small: 827424 != 829440
V4L2GRABBER ERROR: Frame too small: 828370 != 829440
V4L2GRABBER ERROR: Frame too small: 828450 != 829440
V4L2GRABBER ERROR: Frame too small: 828600 != 829440
V4L2GRABBER ERROR: Frame too small: 828272 != 829440
V4L2GRABBER ERROR: Frame too small: 828126 != 829440
V4L2GRABBER ERROR: Frame too small: 826716 != 829440
V4L2GRABBER ERROR: Frame too small: 828658 != 829440
V4L2GRABBER ERROR: Frame too small: 828732 != 829440
V4L2GRABBER ERROR: Frame too small: 827100 != 829440
V4L2GRABBER ERROR: Frame too small: 828316 != 829440
V4L2GRABBER ERROR: Frame too small: 828740 != 829440
V4L2GRABBER ERROR: Frame too small: 828328 != 829440
V4L2GRABBER ERROR: Frame too small: 828094 != 829440
V4L2GRABBER ERROR: Frame too small: 828616 != 829440
V4L2GRABBER ERROR: Frame too small: 825826 != 829440
V4L2GRABBER ERROR: Frame too small: 828840 != 829440
V4L2GRABBER ERROR: Frame too small: 827920 != 829440
V4L2GRABBER ERROR: Frame too small: 828638 != 829440
V4L2GRABBER ERROR: Frame too small: 828896 != 829440
V4L2GRABBER ERROR: Frame too small: 828724 != 829440
V4L2GRABBER ERROR: Frame too small: 828944 != 829440
V4L2GRABBER ERROR: Frame too small: 827628 != 829440
V4L2GRABBER ERROR: Frame too small: 827418 != 829440
V4L2GRABBER ERROR: Frame too small: 828518 != 829440
V4L2GRABBER ERROR: Frame too small: 828526 != 829440
V4L2GRABBER ERROR: Frame too small: 828014 != 829440
V4L2GRABBER ERROR: Frame too small: 828646 != 829440
V4L2GRABBER ERROR: Frame too small: 828348 != 829440
V4L2GRABBER ERROR: Frame too small: 828756 != 829440
V4L2GRABBER ERROR: Frame too small: 828762 != 829440
V4L2GRABBER ERROR: Frame too small: 828252 != 829440
V4L2GRABBER ERROR: Frame too small: 828934 != 829440
V4L2GRABBER ERROR: Frame too small: 828310 != 829440
V4L2GRABBER ERROR: Frame too small: 827026 != 829440
V4L2GRABBER ERROR: Frame too small: 828818 != 829440
V4L2GRABBER ERROR: Frame too small: 828190 != 829440
V4L2GRABBER ERROR: Frame too small: 826544 != 829440
V4L2GRABBER ERROR: Frame too small: 828908 != 829440
V4L2GRABBER ERROR: Frame too small: 828232 != 829440
V4L2GRABBER ERROR: Frame too small: 828890 != 829440
V4L2GRABBER ERROR: Frame too small: 828420 != 829440
V4L2GRABBER ERROR: Frame too small: 825440 != 829440
V4L2GRABBER ERROR: Frame too small: 828472 != 829440
V4L2GRABBER ERROR: Frame too small: 828552 != 829440
V4L2GRABBER ERROR: Frame too small: 827498 != 829440
V4L2GRABBER ERROR: Frame too small: 828546 != 829440
V4L2GRABBER ERROR: Frame too small: 828842 != 829440
V4L2GRABBER ERROR: Frame too small: 825456 != 829440
V4L2GRABBER ERROR: Frame too small: 828680 != 829440
V4L2GRABBER ERROR: Frame too small: 826198 != 829440
V4L2GRABBER ERROR: Frame too small: 828630 != 829440
V4L2GRABBER ERROR: Frame too small: 828118 != 829440
V4L2GRABBER ERROR: Frame too small: 828194 != 829440
V4L2GRABBER ERROR: Frame too small: 828274 != 829440
V4L2GRABBER ERROR: Frame too small: 824802 != 829440
V4L2GRABBER ERROR: Frame too small: 825982 != 829440
V4L2GRABBER ERROR: Frame too small: 825388 != 829440
V4L2GRABBER ERROR: Frame too small: 828502 != 829440
V4L2GRABBER ERROR: Frame too small: 826632 != 829440
V4L2GRABBER ERROR: Frame too small: 827932 != 829440
V4L2GRABBER ERROR: Frame too small: 828878 != 829440
V4L2GRABBER ERROR: Frame too small: 827622 != 829440
V4L2GRABBER ERROR: Frame too small: 827958 != 829440
V4L2GRABBER ERROR: Frame too small: 828586 != 829440
V4L2GRABBER ERROR: Frame too small: 828716 != 829440
V4L2GRABBER ERROR: Frame too small: 828582 != 829440
V4L2GRABBER ERROR: Frame too small: 828092 != 829440
V4L2GRABBER ERROR: Frame too small: 828292 != 829440
V4L2GRABBER ERROR: Frame too small: 825450 != 829440
V4L2GRABBER ERROR: Frame too small: 828408 != 829440
V4L2GRABBER ERROR: Frame too small: 828488 != 829440
V4L2GRABBER ERROR: Frame too small: 828442 != 829440
V4L2GRABBER ERROR: Frame too small: 828676 != 829440
V4L2GRABBER ERROR: Frame too small: 828836 != 829440
V4L2GRABBER ERROR: Frame too small: 827434 != 829440
V4L2GRABBER ERROR: Frame too small: 827578 != 829440
V4L2GRABBER ERROR: Frame too small: 828084 != 829440
V4L2GRABBER ERROR: Frame too small: 828510 != 829440
V4L2GRABBER ERROR: Frame too small: 828596 != 829440
V4L2GRABBER ERROR: Frame too small: 828362 != 829440
V4L2GRABBER ERROR: Frame too small: 828718 != 829440
V4L2GRABBER ERROR: Frame too small: 828914 != 829440
V4L2GRABBER ERROR: Frame too small: 828754 != 829440
V4L2GRABBER ERROR: Frame too small: 825212 != 829440
V4L2GRABBER ERROR: Frame too small: 828784 != 829440
V4L2GRABBER ERROR: Frame too small: 827734 != 829440
V4L2GRABBER ERROR: Frame too small: 828244 != 829440
V4L2GRABBER ERROR: Frame too small: 828490 != 829440
V4L2GRABBER ERROR: Frame too small: 828402 != 829440
V4L2GRABBER ERROR: Frame too small: 828482 != 829440
V4L2GRABBER ERROR: Frame too small: 827484 != 829440
V4L2GRABBER ERROR: Frame too small: 828692 != 829440
V4L2GRABBER ERROR: Frame too small: 826812 != 829440
V4L2GRABBER ERROR: Frame too small: 827996 != 829440
V4L2GRABBER ERROR: Frame too small: 828512 != 829440
V4L2GRABBER ERROR: Frame too small: 828916 != 829440
V4L2GRABBER ERROR: Frame too small: 825972 != 829440
V4L2GRABBER ERROR: Frame too small: 824460 != 829440
V4L2GRABBER ERROR: Frame too small: 828816 != 829440
V4L2GRABBER ERROR: Frame too small: 827408 != 829440
V4L2GRABBER ERROR: Frame too small: 828912 != 829440
V4L2GRABBER ERROR: Frame too small: 828884 != 829440
V4L2GRABBER ERROR: Frame too small: 827572 != 829440
V4L2GRABBER ERROR: Frame too small: 828672 != 829440
V4L2GRABBER ERROR: Frame too small: 824046 != 829440
V4L2GRABBER ERROR: Frame too small: 828394 != 829440
V4L2GRABBER ERROR: Frame too small: 828504 != 829440
V4L2GRABBER ERROR: Frame too small: 828584 != 829440
V4L2GRABBER ERROR: Frame too small: 828662 != 829440
V4L2GRABBER ERROR: Frame too small: 828744 != 829440
V4L2GRABBER ERROR: Frame too small: 828072 != 829440
V4L2GRABBER ERROR: Frame too small: 823368 != 829440
V4L2GRABBER ERROR: Frame too small: 828150 != 829440
V4L2GRABBER ERROR: Frame too small: 828758 != 829440
V4L2GRABBER ERROR: Frame too small: 827496 != 829440
V4L2GRABBER ERROR: Frame too small: 828634 != 829440
V4L2GRABBER ERROR: Frame too small: 827246 != 829440
V4L2GRABBER ERROR: Frame too small: 828728 != 829440
V4L2GRABBER ERROR: Frame too small: 828432 != 829440
V4L2GRABBER ERROR: Frame too small: 828326 != 829440
V4L2GRABBER ERROR: Frame too small: 828406 != 829440
V4L2GRABBER ERROR: Frame too small: 825576 != 829440
V4L2GRABBER ERROR: Frame too small: 828088 != 829440
V4L2GRABBER ERROR: Frame too small: 828440 != 829440
V4L2GRABBER ERROR: Frame too small: 828340 != 829440
V4L2GRABBER ERROR: Frame too small: 828500 != 829440
V4L2GRABBER ERROR: Frame too small: 825860 != 829440
V4L2GRABBER ERROR: Frame too small: 828620 != 829440
V4L2GRABBER ERROR: Frame too small: 828598 != 829440
V4L2GRABBER ERROR: Frame too small: 828540 != 829440
V4L2GRABBER ERROR: Frame too small: 828628 != 829440
V4L2GRABBER ERROR: Frame too small: 827640 != 829440
V4L2GRABBER ERROR: Frame too small: 826648 != 829440
V4L2GRABBER ERROR: Frame too small: 827942 != 829440
V4L2GRABBER ERROR: Frame too small: 827126 != 829440
V4L2GRABBER ERROR: Frame too small: 827892 != 829440
V4L2GRABBER ERROR: Frame too small: 828664 != 829440
V4L2GRABBER ERROR: Frame too small: 828902 != 829440
V4L2GRABBER ERROR: Frame too small: 828278 != 829440
V4L2GRABBER ERROR: Frame too small: 828700 != 829440
V4L2GRABBER ERROR: Frame too small: 827376 != 829440
V4L2GRABBER ERROR: Frame too small: 827988 != 829440
V4L2GRABBER ERROR: Frame too small: 828686 != 829440
V4L2GRABBER ERROR: Frame too small: 827938 != 829440
V4L2GRABBER ERROR: Frame too small: 828932 != 829440
V4L2GRABBER ERROR: Frame too small: 828888 != 829440
V4L2GRABBER ERROR: Frame too small: 828696 != 829440
V4L2GRABBER ERROR: Frame too small: 828938 != 829440
V4L2GRABBER ERROR: Frame too small: 828800 != 829440
V4L2GRABBER ERROR: Frame too small: 828682 != 829440
V4L2GRABBER ERROR: Frame too small: 828288 != 829440
V4L2GRABBER ERROR: Frame too small: 828574 != 829440
V4L2GRABBER ERROR: Frame too small: 828898 != 829440
V4L2GRABBER ERROR: Frame too small: 828604 != 829440
V4L2GRABBER ERROR: Frame too small: 827832 != 829440
V4L2GRABBER ERROR: Frame too small: 828008 != 829440
V4L2GRABBER ERROR: Frame too small: 827426 != 829440
V4L2GRABBER ERROR: Frame too small: 828594 != 829440
V4L2GRABBER ERROR: Frame too small: 828674 != 829440
V4L2GRABBER ERROR: Frame too small: 828834 != 829440
V4L2GRABBER ERROR: Frame too small: 827142 != 829440
V4L2GRABBER ERROR: Frame too small: 828656 != 829440
V4L2GRABBER ERROR: Frame too small: 827238 != 829440
V4L2GRABBER ERROR: Frame too small: 824992 != 829440
V4L2GRABBER ERROR: Frame too small: 826728 != 829440
V4L2GRABBER ERROR: Frame too small: 828268 != 829440
V4L2GRABBER ERROR: Frame too small: 828920 != 829440
V4L2GRABBER ERROR: Frame too small: 828534 != 829440
V4L2GRABBER ERROR: Frame too small: 828936 != 829440
V4L2GRABBER ERROR: Frame too small: 828738 != 829440
V4L2GRABBER ERROR: Frame too small: 828880 != 829440
V4L2GRABBER ERROR: Frame too small: 828296 != 829440
V4L2GRABBER ERROR: Frame too small: 828264 != 829440
V4L2GRABBER ERROR: Frame too small: 828852 != 829440
V4L2GRABBER ERROR: Frame too small: 828864 != 829440
V4L2GRABBER ERROR: Frame too small: 828188 != 829440
V4L2GRABBER ERROR: Frame too small: 828196 != 829440
V4L2GRABBER ERROR: Frame too small: 828304 != 829440
V4L2GRABBER ERROR: Frame too small: 826610 != 829440
V4L2GRABBER ERROR: Frame too small: 828860 != 829440
V4L2GRABBER ERROR: Frame too small: 823742 != 829440
V4L2GRABBER ERROR: Frame too small: 828564 != 829440
V4L2GRABBER ERROR: Frame too small: 828642 != 829440
V4L2GRABBER ERROR: Frame too small: 827632 != 829440
V4L2GRABBER ERROR: Frame too small: 828428 != 829440
V4L2GRABBER ERROR: Frame too small: 828508 != 829440
V4L2GRABBER ERROR: Frame too small: 828444 != 829440
V4L2GRABBER ERROR: Frame too small: 828020 != 829440
V4L2GRABBER ERROR: Frame too small: 828352 != 829440
V4L2GRABBER ERROR: Frame too small: 828332 != 829440
V4L2GRABBER ERROR: Frame too small: 828412 != 829440
V4L2GRABBER ERROR: Frame too small: 828124 != 829440
V4L2GRABBER ERROR: Frame too small: 828354 != 829440
V4L2GRABBER ERROR: Frame too small: 828434 != 829440
V4L2GRABBER ERROR: Frame too small: 827712 != 829440
V4L2GRABBER ERROR: Frame too small: 828794 != 829440
V4L2GRABBER ERROR: Frame too small: 828360 != 829440
V4L2GRABBER ERROR: Frame too small: 828446 != 829440
V4L2GRABBER ERROR: Frame too small: 828774 != 829440
V4L2GRABBER ERROR: Frame too small: 828368 != 829440
V4L2GRABBER ERROR: Frame too small: 828314 != 829440
V4L2GRABBER ERROR: Frame too small: 828548 != 829440
V4L2GRABBER ERROR: Frame too small: 828764 != 829440
V4L2GRABBER ERROR: Frame too small: 827736 != 829440
V4L2GRABBER ERROR: Frame too small: 828248 != 829440
V4L2GRABBER ERROR: Frame too small: 828480 != 829440
V4L2GRABBER ERROR: Frame too small: 828342 != 829440
V4L2GRABBER ERROR: Frame too small: 828366 != 829440
V4L2GRABBER ERROR: Frame too small: 827998 != 829440
V4L2GRABBER ERROR: Frame too small: 828422 != 829440
V4L2GRABBER ERROR: Frame too small: 828026 != 829440
V4L2GRABBER ERROR: Frame too small: 827326 != 829440
V4L2GRABBER ERROR: Frame too small: 828234 != 829440
V4L2GRABBER ERROR: Frame too small: 828384 != 829440
V4L2GRABBER ERROR: Frame too small: 825672 != 829440
V4L2GRABBER ERROR: Frame too small: 828666 != 829440
V4L2GRABBER ERROR: Frame too small: 828240 != 829440
V4L2GRABBER ERROR: Frame too small: 828576 != 829440
V4L2GRABBER ERROR: Frame too small: 828170 != 829440
V4L2GRABBER ERROR: Frame too small: 828330 != 829440
V4L2GRABBER ERROR: Frame too small: 828520 != 829440
V4L2GRABBER ERROR: Frame too small: 828554 != 829440
V4L2GRABBER ERROR: Frame too small: 828220 != 829440
V4L2GRABBER ERROR: Frame too small: 828572 != 829440
V4L2GRABBER ERROR: Frame too small: 828212 != 829440
V4L2GRABBER ERROR: Frame too small: 827526 != 829440
V4L2GRABBER ERROR: Frame too small: 828626 != 829440
das geht dann immer so weiter bis zum Sanktnimmerleinstag, hab den Pi dann "ausgeschaltet"
Jetzt zum Problem,
Meiner meinung nach ist die Verkabelung in ordung, Hab so auch schon über das Farbrad im SSH Tab problemlos alle Farben einstellen können.
Wenn ich jetzt aber ein Viedeosignal über den Grabber einspeise, funktioniert es nicht, die LED bleiben einfach aus.
Das Problem ist warscheinlich der schwarze rand um das bild das vom Grabber kommt?
https://www.amazon.de/clouddrive/share/7tHLp8IhrIYgXljoshvEtfOhlE8lluSbd5TeG87Oik9?ref_=cd_ph_share_link_copy
Daher dann schön die Pixel gemessen, die weg sollen. Dann im Hyperion entsprechend eingegeben, auf den Pi geladen und siehe da.. Nix, schwarze Balken immer noch da.
Hab jetzt schon ne weile gesucht, aber außer aussagen man soll doch im Google nach dem Problem suchen nix gefunden..
Jetzt hoffe ich voll und ganz auf eure Hilfe, bin jedem Dankbar der mich weiter bringt, ich seh inzwischen glaub den Wald vor lauter Bäume nimmer..
18. Jun 2016, 23:58
Was hast du den für einen Grabber? Das sieht nach einem nicht unterstützten aus.
Du brauchst einen Grabber mit Fushicai (UTV) Chipsatz, wenn du so nen 8€ Billig Teil genommen hast wird da der falsche Chipsatz drin sein.
Von außen sehen die Grabber ja fast alle gleich aus.
Siehe z.B. diesen hier: https://www.amazon.de/LogiLink-Audio-Vi ... B0013BXFLG
der Funktioniert zu 100% (siehe auch die Kundenfragen + Antworten).
piBenni
19. Jun 2016, 13:18
Ja danke für die Antwort! Dann wirds das wohl sein, schade..
Gut danke für den Link, dann bestell ich mir den und werde Berichten obs dann funktioniert
piBenni
21. Jun 2016, 19:20
Neuer Grabber kam grad an, natürlich sofort getstet. Gleiches Spiel.. Kann die Ränder nicht entfernen und es sind noch streifen im screenshot
22. Jun 2016, 07:11
wie versuchst du den die Ränder zu entfernen?
Das im Screenshot mal ein, zwei streifen sind, ist völlig normal und in Ordnung.
Die Fehlermeldung "V4L2GRABBER ERROR: Frame too small: 828168 != 829440" darf halt nicht mehr aufkommen.
piBenni
24. Jun 2016, 17:41
.json
INFO: Boot sequence 'Rainbow mood' EFFECTENGINE INFO: run effect Rainbow mood on channel 0
ne "V4L2GRABBER ERROR: Frame too small: 828168 != 829440" kommt nicht mehr, das past natürlich
OpenELEC:~ # lsusb
Bus 001 Device 005: ID 1b71:3002 Fushicai USBTV007 Video Grabber [EasyCAP]
Das müsste ja jetzt der Chipsatz sein mit dem es funktioniert? Oder ist mir da schon wieder der falsche angdreht worden? :shock:
https://www.amazon.de/clouddrive/share/sCgOJyiBy3CP65tWBjc9MA5iXtvA3pFS88OMxpukXKq?ref_=cd_ph_share_link_copy
Über den Reiter Grabber, entsprechend die Pixel weg, die schwarz sind. Wird auch entsprechend so in die config rein geschrieben.
Oder hab ich da irgendwo nen Denkfehler drin?
      "rate"     : 1000000,
   ///  * 'temperature'
   ///  * 'transform'
               "redChannel"      : 245,
               "blueChannel"      : 10
               "redChannel"      : 180,
               "blueChannel"      : 192
               "gamma"        : 29.4900
               "gamma"        : 2.5100
               "gamma"        : 2.5000
      "enable" : false,
      "threshold" : 0.03,
      "effect" : "Rainbow mood",
      "priority" : 990
//    "forwarder" :
//    "framegrabber" :
//       "width" : 64,
//       "height" : 64,
//       "priority" : 890
//       "port" : 19333,
//       "priority" : 900
      "priority" : 900,
      "cropLeft" : 5,
      "cropRight" : 3,
      "cropTop" : 7,
      "cropBottom" : 1,
piBenni
24. Jun 2016, 18:56
Ok, Komando zurück, Sorry. Balken sind weg. Funktioniert aber immer noch nicht so ganz..
Die Led blinken noch recht wild rum, man könnte erahnen das die farbe passt aber ist halt zu viel geblinke..
//Edit: ganz vergessen, das Geblinke ist nur bei benutzung des grabbers. Wenn ich zum Beispiel über HyperCon die Farben sende weden die einwandfrei angezeigt.
27. Jun 2016, 07:57
Beim Besten willen, deine config gefällt mir gar nicht.
"blackborderdetector" ist z.B. aus,
"transform" die Werte sind Katastrohpal.
Dein geblinke kommt von den extrem hohen Werten.
An deiner Stelle würde ich HyperCon reseten so das für alles (!) die default Werte neu drin sind.
Dann nur den Grabber aktivieren + Crop Werte, deine LEDs korrekt hinterlegen und xbmcVideo Checker sowie den internen Frame Grabber deaktiveren.
Dann mit genau dieser default config mal testen.
So nen wildes geblinke hab ich immer dann gehabt wenn ich an den transform werten zu viel rum gespielt hatte.
piBenni
27. Jun 2016, 21:12
Vielen Dank, hab die konfig wie von dir beschrieben neu aufgesetzt und ja an der alten hab ich wohl bissle viel rum gespielt..
Aber das problem ist wohl doch ein anderes..
https://www.amazon.de/clouddrive/share/JCK3SVNBF4aKjtHhZMiPgbotbu8YRJBIfwYifBe811V?ref_=cd_ph_share_link_copy
das sieht für mich als neuling schon recht kacke aus, denk mal da hab ich mir iwo ne defekte Hardware verbaut, ich werd mich sobald ich zeit finde mal da dahinter klemmen..
27. Jun 2016, 21:24
Hast du mal den Grabber wie im Hilfetthread hier im Support Bereich beschrieben geöffnet?
30. Jun 2016, 09:23
Den Konverter meinte ich natürlich - sorry :)
Der Konverter sieht eigentlich in Ordnung aus & sollte 1080p können.
Was hängt eigentlich an dem HDMI2AV Konverter für ein Gerät dran was das Bild liefert?
piBenni
30. Jun 2016, 18:34
Dachte ich mir :D
Ja sieht gut aus, hat am anfang au sauber Funktioniert. Aber scheinbar hat der jetzt das Zeitliche gesegnet. Habs geprüft der gibt immer nur das Streifen Bild raus.
Ist wohl ein fall für die Tonne.
Bild liefert ein FireTV Stick, der ist an nem Splitter dran.
piBenni
6. Jul 2016, 18:21
Also neuer HDMI Wandler ist da, angechlossen und ich bekomm wieder ein sauberes Bild. Nur hat sich das geblinke nicht verbessert. Während dem Regenbogen beim Start ist es gut, wenn ich manuell eine Farbe sende auch. Nur sobald der Grabber das bild bekommt und daraus das Ambilight, ist es sofort. Auch wenn das Bild angehalten wird
EDIT:
So, habs wohl in griff bekommen. Es kamen vom Netzeil ned 5,00V sondern 5,63V. Runter gedreht und schon hat es sich beruhigt. Ist mir bissle peinlich, dass es doch an so was einfachem Lag :?
Trotzdem vielen Dank für die Tips und die Hilfe b2un0, ich würd dir au ein Bier dafür ausgeben!
