habe gerade mein pi gestartet und die start sequenzz kommt aber mehr nicht
hier mal der log
passt da alles ?
ssh disconnected
ssh connected
ssh out: cat /storage/logfiles/hyperion.log
ssh in: Hyperion Ambilight Deamon (428)
ssh in: Version : V1.03.2 (brindosch-99d9396/d3713a8-1469452981
ssh in: Build Time: Jul 25 2016 06:54:40
ssh in: INFO: Selected configuration file: /storage/.config/hyperion.config.json
ssh in: HYPERION INFO: ColorTransform 'default' => [0; 125]
ssh in: HYPERION INFO: ColorCorrection 'default' => [0; 125]
ssh in: HYPERION INFO: ColorAdjustment 'default' => [0; 125]
ssh in: LEDDEVICE INFO: configuration:
ssh in: {
ssh in: "colorOrder" : "rgb",
ssh in: "name" : "hyperion.config.json",
ssh in: "output" : "/dev/spidev0.0",
ssh in: "rate" : 1000000,
ssh in: "type" : "ws2801"
ssh in: }
ssh in: INFO: Creating linear smoothing
ssh in: HYPERION (CS) INFO: Created linear-smoothing(interval_ms=50;settlingTime_ms=250;updateDelay=0
ssh in: EFFECTENGINE INFO: 27 effects loaded from directory /storage/hyperion/effects
ssh in: EFFECTENGINE INFO: Initializing Python interpreter
ssh in: INFO: Hyperion started and initialised
ssh in: INFO: Boot sequence 'Rainbow swirl fast' EFFECTENGINE INFO: run effect Rainbow swirl fast on channel 0
ssh in: BLACKBORDER INFO: threshold set to 0.01 (3)
ssh in: BLACKBORDER INFO: mode:default
ssh in: started
ssh in: INFO: Json server created and started on port 19444
ssh in: INFO: Proto server created and started on port 19445
ssh in: V4L2GRABBER INFO: width=720 height=576
ssh in: V4L2GRABBER INFO: pixel format=YUYV
ssh in: V4L2GRABBER INFO: signal threshold set to: {0,0,0}
ssh in: V4L2GRABBER INFO: started
ssh in: INFO: V4L2 grabber created and started
ssh in: V4L2GRABBER INFO: stopped
ssh in: EFFECTENGINE INFO: effect finished
