1. apa102
3.
# For more options and information see
# http://rpf.io/configtxtreadme
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# mehr USB-Power
max_usb_current=1
4.
"type" : "apa102",
"colorOrder" : "bgr"
"luminanceGain" : 2.0000,
// V4L2 GRABBER CONFIG
"sizeDecimation" : 8,
"priority" : 900,
"cropLeft" : 30,
"cropRight" : 30,
"cropTop" : 7,
"cropBottom" : 10,
"redSignalThreshold" : 0.0,
"greenSignalThreshold" : 0.0,
"blueSignalThreshold" : 0.0
"threshold" : 0.12,
"effect" : "Rainbow swirl",
// BOBLIGHT SERVER CONFIG
"boblightServer" :
"port" : 19333,
"priority" : 903
// NO FRAME GRABBER CONFIG
// NO KODI CHECK CONFIG
"hscan" : { "minimum" : 0.0165, "maximum" : 0.0343 },
"vscan" : { "minimum" : 0.9700, "maximum" : 1.0000 }
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0174 },
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0200 },
"vscan" : { "minimum" : 0.9689, "maximum" : 1.0000 }
"vscan" : { "minimum" : 0.9386, "maximum" : 0.9705 }
"vscan" : { "minimum" : 0.9083, "maximum" : 0.9402 }
"vscan" : { "minimum" : 0.8780, "maximum" : 0.9098 }
"vscan" : { "minimum" : 0.8477, "maximum" : 0.8795 }
"vscan" : { "minimum" : 0.8174, "maximum" : 0.8492 }
"vscan" : { "minimum" : 0.7871, "maximum" : 0.8189 }
"vscan" : { "minimum" : 0.7568, "maximum" : 0.7886 }
"vscan" : { "minimum" : 0.7265, "maximum" : 0.7583 }
"vscan" : { "minimum" : 0.6962, "maximum" : 0.7280 }
"vscan" : { "minimum" : 0.6659, "maximum" : 0.6977 }
"vscan" : { "minimum" : 0.6356, "maximum" : 0.6674 }
"vscan" : { "minimum" : 0.6053, "maximum" : 0.6371 }
"vscan" : { "minimum" : 0.5750, "maximum" : 0.6068 }
"vscan" : { "minimum" : 0.5447, "maximum" : 0.5765 }
"vscan" : { "minimum" : 0.5144, "maximum" : 0.5462 }
"vscan" : { "minimum" : 0.4841, "maximum" : 0.5159 }
"vscan" : { "minimum" : 0.4538, "maximum" : 0.4856 }
"vscan" : { "minimum" : 0.4235, "maximum" : 0.4553 }
"vscan" : { "minimum" : 0.3932, "maximum" : 0.4250 }
"vscan" : { "minimum" : 0.3629, "maximum" : 0.3947 }
"vscan" : { "minimum" : 0.3326, "maximum" : 0.3644 }
"vscan" : { "minimum" : 0.3023, "maximum" : 0.3341 }
"vscan" : { "minimum" : 0.2720, "maximum" : 0.3038 }
"vscan" : { "minimum" : 0.2417, "maximum" : 0.2735 }
"vscan" : { "minimum" : 0.2114, "maximum" : 0.2432 }
"vscan" : { "minimum" : 0.1811, "maximum" : 0.2129 }
"vscan" : { "minimum" : 0.1508, "maximum" : 0.1826 }
"vscan" : { "minimum" : 0.1205, "maximum" : 0.1523 }
"vscan" : { "minimum" : 0.0902, "maximum" : 0.1220 }
"vscan" : { "minimum" : 0.0598, "maximum" : 0.0917 }
"vscan" : { "minimum" : 0.0295, "maximum" : 0.0614 }
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0311 }
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0300 }
"hscan" : { "minimum" : 0.0335, "maximum" : 0.0513 },
"hscan" : { "minimum" : 0.0504, "maximum" : 0.0682 },
"hscan" : { "minimum" : 0.0674, "maximum" : 0.0852 },
"hscan" : { "minimum" : 0.0843, "maximum" : 0.1021 },
"hscan" : { "minimum" : 0.1013, "maximum" : 0.1191 },
"hscan" : { "minimum" : 0.1182, "maximum" : 0.1360 },
"hscan" : { "minimum" : 0.1352, "maximum" : 0.1530 },
"hscan" : { "minimum" : 0.1521, "maximum" : 0.1699 },
"hscan" : { "minimum" : 0.1691, "maximum" : 0.1869 },
"hscan" : { "minimum" : 0.1860, "maximum" : 0.2038 },
"hscan" : { "minimum" : 0.2030, "maximum" : 0.2208 },
"hscan" : { "minimum" : 0.2199, "maximum" : 0.2377 },
"hscan" : { "minimum" : 0.2369, "maximum" : 0.2547 },
"hscan" : { "minimum" : 0.2538, "maximum" : 0.2716 },
"hscan" : { "minimum" : 0.2708, "maximum" : 0.2886 },
"hscan" : { "minimum" : 0.2877, "maximum" : 0.3055 },
"hscan" : { "minimum" : 0.3047, "maximum" : 0.3225 },
"hscan" : { "minimum" : 0.3216, "maximum" : 0.3394 },
"hscan" : { "minimum" : 0.3386, "maximum" : 0.3564 },
"hscan" : { "minimum" : 0.3555, "maximum" : 0.3733 },
"hscan" : { "minimum" : 0.3725, "maximum" : 0.3903 },
"hscan" : { "minimum" : 0.3894, "maximum" : 0.4072 },
"hscan" : { "minimum" : 0.4064, "maximum" : 0.4242 },
"hscan" : { "minimum" : 0.4233, "maximum" : 0.4411 },
"hscan" : { "minimum" : 0.4403, "maximum" : 0.4581 },
"hscan" : { "minimum" : 0.4572, "maximum" : 0.4750 },
"hscan" : { "minimum" : 0.4742, "maximum" : 0.4919 },
"hscan" : { "minimum" : 0.4911, "maximum" : 0.5089 },
"hscan" : { "minimum" : 0.5081, "maximum" : 0.5258 },
"hscan" : { "minimum" : 0.5250, "maximum" : 0.5428 },
"hscan" : { "minimum" : 0.5419, "maximum" : 0.5597 },
"hscan" : { "minimum" : 0.5589, "maximum" : 0.5767 },
"hscan" : { "minimum" : 0.5758, "maximum" : 0.5936 },
"hscan" : { "minimum" : 0.5928, "maximum" : 0.6106 },
"hscan" : { "minimum" : 0.6097, "maximum" : 0.6275 },
"hscan" : { "minimum" : 0.6267, "maximum" : 0.6445 },
"hscan" : { "minimum" : 0.6436, "maximum" : 0.6614 },
"hscan" : { "minimum" : 0.6606, "maximum" : 0.6784 },
"hscan" : { "minimum" : 0.6775, "maximum" : 0.6953 },
"hscan" : { "minimum" : 0.6945, "maximum" : 0.7123 },
"hscan" : { "minimum" : 0.7114, "maximum" : 0.7292 },
"hscan" : { "minimum" : 0.7284, "maximum" : 0.7462 },
"hscan" : { "minimum" : 0.7453, "maximum" : 0.7631 },
"hscan" : { "minimum" : 0.7623, "maximum" : 0.7801 },
"hscan" : { "minimum" : 0.7792, "maximum" : 0.7970 },
"hscan" : { "minimum" : 0.7962, "maximum" : 0.8140 },
"hscan" : { "minimum" : 0.8131, "maximum" : 0.8309 },
"hscan" : { "minimum" : 0.8301, "maximum" : 0.8479 },
"hscan" : { "minimum" : 0.8470, "maximum" : 0.8648 },
"hscan" : { "minimum" : 0.8640, "maximum" : 0.8818 },
"hscan" : { "minimum" : 0.8809, "maximum" : 0.8987 },
"hscan" : { "minimum" : 0.8979, "maximum" : 0.9157 },
"hscan" : { "minimum" : 0.9148, "maximum" : 0.9326 },
"hscan" : { "minimum" : 0.9318, "maximum" : 0.9496 },
"hscan" : { "minimum" : 0.9487, "maximum" : 0.9665 },
"hscan" : { "minimum" : 0.9657, "maximum" : 0.9835 },
"hscan" : { "minimum" : 0.9826, "maximum" : 1.0000 },
"hscan" : { "minimum" : 0.9800, "maximum" : 1.0000 },
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0293 }
"vscan" : { "minimum" : 0.0279, "maximum" : 0.0579 }
"vscan" : { "minimum" : 0.0564, "maximum" : 0.0864 }
"vscan" : { "minimum" : 0.0850, "maximum" : 0.1150 }
"vscan" : { "minimum" : 0.1136, "maximum" : 0.1436 }
"vscan" : { "minimum" : 0.1421, "maximum" : 0.1721 }
"vscan" : { "minimum" : 0.1707, "maximum" : 0.2007 }
"vscan" : { "minimum" : 0.1993, "maximum" : 0.2293 }
"vscan" : { "minimum" : 0.2279, "maximum" : 0.2579 }
"vscan" : { "minimum" : 0.2564, "maximum" : 0.2864 }
"vscan" : { "minimum" : 0.2850, "maximum" : 0.3150 }
"vscan" : { "minimum" : 0.3136, "maximum" : 0.3436 }
"vscan" : { "minimum" : 0.3421, "maximum" : 0.3721 }
"vscan" : { "minimum" : 0.3707, "maximum" : 0.4007 }
"vscan" : { "minimum" : 0.3993, "maximum" : 0.4293 }
"vscan" : { "minimum" : 0.4279, "maximum" : 0.4579 }
"vscan" : { "minimum" : 0.4564, "maximum" : 0.4864 }
"vscan" : { "minimum" : 0.4850, "maximum" : 0.5150 }
"vscan" : { "minimum" : 0.5136, "maximum" : 0.5436 }
"vscan" : { "minimum" : 0.5421, "maximum" : 0.5721 }
"vscan" : { "minimum" : 0.5707, "maximum" : 0.6007 }
"vscan" : { "minimum" : 0.5993, "maximum" : 0.6293 }
"vscan" : { "minimum" : 0.6279, "maximum" : 0.6579 }
"vscan" : { "minimum" : 0.6564, "maximum" : 0.6864 }
"vscan" : { "minimum" : 0.6850, "maximum" : 0.7150 }
"index" : 121,
"vscan" : { "minimum" : 0.7136, "maximum" : 0.7436 }
"index" : 122,
"vscan" : { "minimum" : 0.7421, "maximum" : 0.7721 }
"index" : 123,
"vscan" : { "minimum" : 0.7707, "maximum" : 0.8007 }
"index" : 124,
"vscan" : { "minimum" : 0.7993, "maximum" : 0.8293 }
"index" : 125,
"vscan" : { "minimum" : 0.8279, "maximum" : 0.8579 }
"index" : 126,
"vscan" : { "minimum" : 0.8564, "maximum" : 0.8864 }
"index" : 127,
"vscan" : { "minimum" : 0.8850, "maximum" : 0.9150 }
"index" : 128,
"vscan" : { "minimum" : 0.9136, "maximum" : 0.9436 }
"index" : 129,
"vscan" : { "minimum" : 0.9421, "maximum" : 0.9721 }
"index" : 130,
"vscan" : { "minimum" : 0.9707, "maximum" : 1.0000 }
"index" : 131,
"index" : 132,
"index" : 133,
"index" : 134,
"index" : 135,
"index" : 136,
"index" : 137,
"index" : 138,
"index" : 139,
"index" : 140,
"index" : 141,
"index" : 142,
"index" : 143,
"index" : 144,
"index" : 145,
"index" : 146,
"index" : 147,
"index" : 148,
"index" : 149,
"index" : 150,
"index" : 151,
"index" : 152,
"index" : 153,
"index" : 154,
"index" : 155,
"index" : 156,
"index" : 157,
"index" : 158,
"index" : 159,
"index" : 160,
"index" : 161,
"index" : 162,
"index" : 163,
"index" : 164,
"index" : 165,
"index" : 166,
"index" : 167,
"index" : 168,
"index" : 169,
"index" : 170,
"index" : 171,
"index" : 172,
"index" : 173,
"index" : 174,
"index" : 175,
"index" : 176,
"index" : 177,
"index" : 178,
"index" : 179,
"index" : 180,
"index" : 181,
"index" : 182,
"index" : 183,
"index" : 184,
"index" : 185,
"index" : 186,
"index" : 187,
"index" : 188,
hyperiond: Kein Prozess gefunden
hyperion status:
● hyperion.service - Hyperion Systemd service
Loaded: loaded (/etc/systemd/system/hyperion.service; enabled)
Active: failed (Result: start-limit) since Mi 2017-11-08 19:30:28 CET; 8min ago
Process: 3644 ExecStart=/usr/bin/hyperiond /etc/hyperion/hyperion.config.json (code=exited, status=1/FAILURE)
Main PID: 3644 (code=exited, status=1/FAILURE)
Nov 08 19:30:28 raspberrypi systemd[1]: hyperion.service: main process exite...E
Nov 08 19:30:28 raspberrypi systemd[1]: Unit hyperion.service entered failed....
Nov 08 19:30:28 raspberrypi systemd[1]: hyperion.service holdoff time over, ....
Nov 08 19:30:28 raspberrypi systemd[1]: Stopping Hyperion Systemd service...
Nov 08 19:30:28 raspberrypi systemd[1]: Starting Hyperion Systemd service...
Nov 08 19:30:28 raspberrypi systemd[1]: hyperion.service start request repea....
Nov 08 19:30:28 raspberrypi systemd[1]: Failed to start Hyperion Systemd ser....
Hint: Some lines were ellipsized, use -l to show in full.
Verkabelung schließe ich mal aus, da es sofwareseitg zu sein scheint und er den hyperion dienst nicht starten kann.
Installiert ist Raspbian Jessie lite
"storage" Ordner ist im root nicht installiert
