URI3L
Ambilight über HDMI geht nicht mehr
16. Mär 2018, 22:48
Hallo liebe Community,
Folgende Konstellation:
1. LED´s: APA102
2. Bild der Verkabelung geht leider nicht, da es im Schrank verbaut wurde. Zumindest würde man nichts erkennen
3. deine /boot/config.txt:
#      This file is part of LibreELEC - http://www.libreelec.tv
#      Copyright (C) 2016 Team LibreELEC
#  LibreELEC is free software: you can redistribute it and/or modify
#  LibreELEC is distributed in the hope that it will be useful,
#  along with LibreELEC.  If not, see <http://www.gnu.org/licenses/>.
# Default GPU memory split (do not change if you do not know what you are doing)
# Configure GPU memory based on SDRAM size - overrides above setting
# For overclocking and various other settings, see:
# https://www.raspberrypi.org/documentation/configuration/config-txt.md
# Set 'force_turbo=1' to disable dynamic overclocking and enable overclocking always.
# Note that the overscan settings only affect the splash screen and not Kodi.
# If you experience overscan/underscan issues the best solution is to adjust
# your TV settings ("full pixel", "1-1 pixel" etc.). Alternatively, there is a
# calibration menu in the Kodi GUI.
# hdmi_force_hotplug=1
# Include distribution specific config file if it exists.
[all]
include distroconfig.txt
#USB Ausgänge Strom erhöhen
max_usb_current=1
4: deine hyperion.config.json:
      "type"       : "apa102",
      "rate"     : 1000000,
      "colorOrder" : "bgr"
               "redChannel"      : 255,
               "greenChannel"      : 15,
               "blueChannel"      : 12
               "redChannel"      : 60,
               "greenChannel"      : 160,
               "redChannel"      : 35,
               "blueChannel"      : 170
               "gamma"        : 2.4300
               "gamma"        : 2.0000
               "gamma"        : 2.0000
   // V4L2 GRABBER CONFIG
      "frameDecimation" : 5,
      "sizeDecimation" : 11,
      "priority" : 900,
      "cropLeft" : 9,
      "cropRight" : 19,
      "cropTop" : 18,
      "cropBottom" : 17,
      "redSignalThreshold" : 0.0,
      "greenSignalThreshold" : 0.0,
      "blueSignalThreshold" : 0.0
      "threshold" : 0.07,
      "duration_ms" : 5000,
   // NO FRAME GRABBER CONFIG
   // NO KODI CHECK CONFIG
         "hscan" : { "minimum" : 0.4531, "maximum" : 0.4688 },
         "vscan" : { "minimum" : 0.9100, "maximum" : 1.0000 }
         "hscan" : { "minimum" : 0.4688, "maximum" : 0.4844 },
         "hscan" : { "minimum" : 0.4844, "maximum" : 0.5000 },
         "hscan" : { "minimum" : 0.5000, "maximum" : 0.5156 },
         "hscan" : { "minimum" : 0.5156, "maximum" : 0.5313 },
         "hscan" : { "minimum" : 0.5313, "maximum" : 0.5469 },
         "hscan" : { "minimum" : 0.5469, "maximum" : 0.5625 },
         "hscan" : { "minimum" : 0.5625, "maximum" : 0.5781 },
         "hscan" : { "minimum" : 0.5781, "maximum" : 0.5938 },
         "hscan" : { "minimum" : 0.5938, "maximum" : 0.6094 },
         "hscan" : { "minimum" : 0.6094, "maximum" : 0.6250 },
         "hscan" : { "minimum" : 0.6250, "maximum" : 0.6406 },
         "hscan" : { "minimum" : 0.6406, "maximum" : 0.6563 },
         "hscan" : { "minimum" : 0.6563, "maximum" : 0.6719 },
         "hscan" : { "minimum" : 0.6719, "maximum" : 0.6875 },
         "hscan" : { "minimum" : 0.6875, "maximum" : 0.7031 },
         "hscan" : { "minimum" : 0.7031, "maximum" : 0.7188 },
         "hscan" : { "minimum" : 0.7188, "maximum" : 0.7344 },
         "hscan" : { "minimum" : 0.7344, "maximum" : 0.7500 },
         "hscan" : { "minimum" : 0.7500, "maximum" : 0.7656 },
         "hscan" : { "minimum" : 0.7656, "maximum" : 0.7813 },
         "hscan" : { "minimum" : 0.7813, "maximum" : 0.7969 },
         "hscan" : { "minimum" : 0.7969, "maximum" : 0.8125 },
         "hscan" : { "minimum" : 0.8125, "maximum" : 0.8281 },
         "hscan" : { "minimum" : 0.8281, "maximum" : 0.8438 },
         "hscan" : { "minimum" : 0.8438, "maximum" : 0.8594 },
         "hscan" : { "minimum" : 0.8594, "maximum" : 0.8750 },
         "hscan" : { "minimum" : 0.8750, "maximum" : 0.8906 },
         "hscan" : { "minimum" : 0.8906, "maximum" : 0.9063 },
         "hscan" : { "minimum" : 0.9063, "maximum" : 0.9219 },
         "hscan" : { "minimum" : 0.9219, "maximum" : 0.9375 },
         "hscan" : { "minimum" : 0.9375, "maximum" : 0.9531 },
         "hscan" : { "minimum" : 0.9531, "maximum" : 0.9688 },
         "hscan" : { "minimum" : 0.9688, "maximum" : 0.9844 },
         "hscan" : { "minimum" : 0.9844, "maximum" : 1.0000 },
         "vscan" : { "minimum" : 0.9737, "maximum" : 1.0000 }
         "vscan" : { "minimum" : 0.9474, "maximum" : 0.9737 }
         "vscan" : { "minimum" : 0.9211, "maximum" : 0.9474 }
         "vscan" : { "minimum" : 0.8947, "maximum" : 0.9211 }
         "vscan" : { "minimum" : 0.8684, "maximum" : 0.8947 }
         "vscan" : { "minimum" : 0.8421, "maximum" : 0.8684 }
         "vscan" : { "minimum" : 0.8158, "maximum" : 0.8421 }
         "vscan" : { "minimum" : 0.7895, "maximum" : 0.8158 }
         "vscan" : { "minimum" : 0.7632, "maximum" : 0.7895 }
         "vscan" : { "minimum" : 0.7368, "maximum" : 0.7632 }
         "vscan" : { "minimum" : 0.7105, "maximum" : 0.7368 }
         "vscan" : { "minimum" : 0.6842, "maximum" : 0.7105 }
         "vscan" : { "minimum" : 0.6579, "maximum" : 0.6842 }
         "vscan" : { "minimum" : 0.6316, "maximum" : 0.6579 }
         "vscan" : { "minimum" : 0.6053, "maximum" : 0.6316 }
         "vscan" : { "minimum" : 0.5789, "maximum" : 0.6053 }
         "vscan" : { "minimum" : 0.5526, "maximum" : 0.5789 }
         "vscan" : { "minimum" : 0.5263, "maximum" : 0.5526 }
         "vscan" : { "minimum" : 0.5000, "maximum" : 0.5263 }
         "vscan" : { "minimum" : 0.4737, "maximum" : 0.5000 }
         "vscan" : { "minimum" : 0.4474, "maximum" : 0.4737 }
         "vscan" : { "minimum" : 0.4211, "maximum" : 0.4474 }
         "vscan" : { "minimum" : 0.3947, "maximum" : 0.4211 }
         "vscan" : { "minimum" : 0.3684, "maximum" : 0.3947 }
         "vscan" : { "minimum" : 0.3421, "maximum" : 0.3684 }
         "vscan" : { "minimum" : 0.3158, "maximum" : 0.3421 }
         "vscan" : { "minimum" : 0.2895, "maximum" : 0.3158 }
         "vscan" : { "minimum" : 0.2632, "maximum" : 0.2895 }
         "vscan" : { "minimum" : 0.2368, "maximum" : 0.2632 }
         "vscan" : { "minimum" : 0.2105, "maximum" : 0.2368 }
         "vscan" : { "minimum" : 0.1842, "maximum" : 0.2105 }
         "vscan" : { "minimum" : 0.1579, "maximum" : 0.1842 }
         "vscan" : { "minimum" : 0.1316, "maximum" : 0.1579 }
         "vscan" : { "minimum" : 0.1053, "maximum" : 0.1316 }
         "vscan" : { "minimum" : 0.0789, "maximum" : 0.1053 }
         "vscan" : { "minimum" : 0.0526, "maximum" : 0.0789 }
         "vscan" : { "minimum" : 0.0263, "maximum" : 0.0526 }
         "vscan" : { "minimum" : 0.0000, "maximum" : 0.0263 }
         "vscan" : { "minimum" : 0.0000, "maximum" : 0.0900 }
         "hscan" : { "minimum" : 0.4375, "maximum" : 0.4531 },
         "hscan" : { "minimum" : 0.4219, "maximum" : 0.4375 },
         "hscan" : { "minimum" : 0.4063, "maximum" : 0.4219 },
         "hscan" : { "minimum" : 0.3906, "maximum" : 0.4063 },
         "hscan" : { "minimum" : 0.3750, "maximum" : 0.3906 },
         "hscan" : { "minimum" : 0.3594, "maximum" : 0.3750 },
         "hscan" : { "minimum" : 0.3438, "maximum" : 0.3594 },
         "hscan" : { "minimum" : 0.3281, "maximum" : 0.3438 },
         "hscan" : { "minimum" : 0.3125, "maximum" : 0.3281 },
         "hscan" : { "minimum" : 0.2969, "maximum" : 0.3125 },
         "hscan" : { "minimum" : 0.2813, "maximum" : 0.2969 },
         "hscan" : { "minimum" : 0.2656, "maximum" : 0.2813 },
         "hscan" : { "minimum" : 0.2500, "maximum" : 0.2656 },
         "index" : 121,
         "hscan" : { "minimum" : 0.2344, "maximum" : 0.2500 },
         "index" : 122,
         "hscan" : { "minimum" : 0.2188, "maximum" : 0.2344 },
         "index" : 123,
         "hscan" : { "minimum" : 0.2031, "maximum" : 0.2188 },
         "index" : 124,
         "hscan" : { "minimum" : 0.1875, "maximum" : 0.2031 },
         "index" : 125,
         "hscan" : { "minimum" : 0.1719, "maximum" : 0.1875 },
         "index" : 126,
         "hscan" : { "minimum" : 0.1563, "maximum" : 0.1719 },
         "index" : 127,
         "hscan" : { "minimum" : 0.1406, "maximum" : 0.1563 },
         "index" : 128,
         "hscan" : { "minimum" : 0.1250, "maximum" : 0.1406 },
         "index" : 129,
         "hscan" : { "minimum" : 0.1094, "maximum" : 0.1250 },
         "index" : 130,
         "hscan" : { "minimum" : 0.0938, "maximum" : 0.1094 },
         "index" : 131,
         "hscan" : { "minimum" : 0.0781, "maximum" : 0.0938 },
         "index" : 132,
         "hscan" : { "minimum" : 0.0625, "maximum" : 0.0781 },
         "index" : 133,
         "hscan" : { "minimum" : 0.0469, "maximum" : 0.0625 },
         "index" : 134,
         "hscan" : { "minimum" : 0.0313, "maximum" : 0.0469 },
         "index" : 135,
         "hscan" : { "minimum" : 0.0156, "maximum" : 0.0313 },
         "index" : 136,
         "hscan" : { "minimum" : 0.0000, "maximum" : 0.0156 },
         "index" : 137,
         "vscan" : { "minimum" : 0.0000, "maximum" : 0.0256 }
         "index" : 138,
         "vscan" : { "minimum" : 0.0256, "maximum" : 0.0513 }
         "index" : 139,
         "vscan" : { "minimum" : 0.0513, "maximum" : 0.0769 }
         "index" : 140,
         "vscan" : { "minimum" : 0.0769, "maximum" : 0.1026 }
         "index" : 141,
         "vscan" : { "minimum" : 0.1026, "maximum" : 0.1282 }
         "index" : 142,
         "vscan" : { "minimum" : 0.1282, "maximum" : 0.1538 }
         "index" : 143,
         "vscan" : { "minimum" : 0.1538, "maximum" : 0.1795 }
         "index" : 144,
         "vscan" : { "minimum" : 0.1795, "maximum" : 0.2051 }
         "index" : 145,
         "vscan" : { "minimum" : 0.2051, "maximum" : 0.2308 }
         "index" : 146,
         "vscan" : { "minimum" : 0.2308, "maximum" : 0.2564 }
         "index" : 147,
         "vscan" : { "minimum" : 0.2564, "maximum" : 0.2821 }
         "index" : 148,
         "vscan" : { "minimum" : 0.2821, "maximum" : 0.3077 }
         "index" : 149,
         "vscan" : { "minimum" : 0.3077, "maximum" : 0.3333 }
         "index" : 150,
         "vscan" : { "minimum" : 0.3333, "maximum" : 0.3590 }
         "index" : 151,
         "vscan" : { "minimum" : 0.3590, "maximum" : 0.3846 }
         "index" : 152,
         "vscan" : { "minimum" : 0.3846, "maximum" : 0.4103 }
         "index" : 153,
         "vscan" : { "minimum" : 0.4103, "maximum" : 0.4359 }
         "index" : 154,
         "vscan" : { "minimum" : 0.4359, "maximum" : 0.4615 }
         "index" : 155,
         "vscan" : { "minimum" : 0.4615, "maximum" : 0.4872 }
         "index" : 156,
         "vscan" : { "minimum" : 0.4872, "maximum" : 0.5128 }
         "index" : 157,
         "vscan" : { "minimum" : 0.5128, "maximum" : 0.5385 }
         "index" : 158,
         "vscan" : { "minimum" : 0.5385, "maximum" : 0.5641 }
         "index" : 159,
         "vscan" : { "minimum" : 0.5641, "maximum" : 0.5897 }
         "index" : 160,
         "vscan" : { "minimum" : 0.5897, "maximum" : 0.6154 }
         "index" : 161,
         "vscan" : { "minimum" : 0.6154, "maximum" : 0.6410 }
         "index" : 162,
         "vscan" : { "minimum" : 0.6410, "maximum" : 0.6667 }
         "index" : 163,
         "vscan" : { "minimum" : 0.6667, "maximum" : 0.6923 }
         "index" : 164,
         "vscan" : { "minimum" : 0.6923, "maximum" : 0.7179 }
         "index" : 165,
         "vscan" : { "minimum" : 0.7179, "maximum" : 0.7436 }
         "index" : 166,
         "vscan" : { "minimum" : 0.7436, "maximum" : 0.7692 }
         "index" : 167,
         "vscan" : { "minimum" : 0.7692, "maximum" : 0.7949 }
         "index" : 168,
         "vscan" : { "minimum" : 0.7949, "maximum" : 0.8205 }
         "index" : 169,
         "vscan" : { "minimum" : 0.8205, "maximum" : 0.8462 }
         "index" : 170,
         "vscan" : { "minimum" : 0.8462, "maximum" : 0.8718 }
         "index" : 171,
         "vscan" : { "minimum" : 0.8718, "maximum" : 0.8974 }
         "index" : 172,
         "vscan" : { "minimum" : 0.8974, "maximum" : 0.9231 }
         "index" : 173,
         "vscan" : { "minimum" : 0.9231, "maximum" : 0.9487 }
         "index" : 174,
         "vscan" : { "minimum" : 0.9487, "maximum" : 0.9744 }
         "index" : 175,
         "vscan" : { "minimum" : 0.9744, "maximum" : 1.0000 }
         "index" : 176,
         "index" : 177,
         "index" : 178,
         "index" : 179,
         "index" : 180,
         "index" : 181,
         "index" : 182,
         "index" : 183,
         "index" : 184,
         "index" : 185,
         "index" : 186,
         "index" : 187,
         "index" : 188,
         "index" : 189,
         "index" : 190,
         "index" : 191,
         "index" : 192,
         "index" : 193,
         "index" : 194,
         "index" : 195,
         "index" : 196,
         "index" : 197,
         "index" : 198,
         "index" : 199,
         "index" : 200,
         "index" : 201,
         "index" : 202,
         "index" : 203,
         "index" : 204,
4. Screenshots von Hypercon liefere ich nach (wenn notwendig)
5. Angabe wo deine erste LED am TV montiert ist (von vorne Betrachtet):
Unten Mitte; gegen Uhrzeigersinn
6. Angabe ob die Steuerung von Hyperion mit einer der Apps aus Beitrag #3 in diesem Thema funktionieren -> siehe unten...
die Ausgabe der nachfolgenden Befehle mittels SSH(Putty)
Hyperion Ambilight Deamon (659)
   Version   : V1.03.3 (brindosch-2fbbcff/2f01dfa-1495880388
   Build Time: Jun  3 2017 02:06:37
HYPERION INFO: ColorTransform 'default' => [0; 204]
HYPERION INFO: ColorCorrection 'default' => [0; 204]
HYPERION INFO: ColorAdjustment 'default' => [0; 204]
   "colorOrder" : "bgr",
   "type" : "apa102"
BLACKBORDER INFO: threshold set to 0.07 (18)
V4L2GRABBER INFO: started
V4L2GRABBER INFO: stopped
_____________________________________________________________________________________________
So. Nun zu meinem Problem:
Habe mittels dieser Anleitung http://powerpi.de/jetzt-wirds-bunt-ambilight-software-hyperion-in-openelec-installieren-teil-2/ mein Ambilight erfolgreich fertiggestellt. Ich habe nur statt Openelec Libreelec genommen. Es funktionierte bisher alles:
a) Ambilight über ext. HDMI,
b) Ambilight über Kodi
c) Ambilight über iPhone-App
Vor ein paar Tagen musste ich feststellen, dass es über ext. HDMI nicht mehr funktioniert. Die LED´s bleiben schwarz. b) und c) funktioniert weiterhin problemlos. Somit habe ich meinen Verdacht entweder auf den HDMI-Converter bzw. auf den Videograbber gelegt. Wenn ich in Hypercon ein Bild vom Grabber holen will, stürzte mein RasPi ab und Hypercon war eingefroren.
1. Test: habe den Grabber an meinen Laptop angesteckt und mittels Software getestet. Hier kommt das Bild einwandfrei an. Somit funktioniert der Converter und der Grabber inkl USB-Verlängerungskabel.
Habe Hyperion deinstalliert und wieder installiert; Kodi "auf Werkseinstellungen zurückgesetzt" usw. Letzten Endes habe ich die SD-Karte komplett platt gemacht und Libreelec, Kodi und Hyperion erneut frisch mit den neuesten Softwareständen wieder draufgezogen. Anschließend noch die alten json-Files und die Favoriten draufkopiert. Aber leider immer noch das gleiche Phänomen. Alle LED´s bleiben NUR bei ext. HDMI komplett dunkel.
Hier noch ein Hinweis:
Ausgabe vom Sticky-Thread:
LibreELEC (official): 8.2.4 (RPi2.arm)
URI3LPi:~ # cd /storage/.config
URI3LPi:~/.config # killall hyperiond
URI3LPi:~/.config # LD_LIBRARY_PATH=/storage/hyperion/bin /storage/hyperion/bin/
hyperion-v4l2 --screenshot --frame-decimator 2 --size-decimator 4
hyperion-v4l2:
   version   : V1.03.3 (brindosch-2fbbcff/2f01dfa-1495880388
   build time: Jun  3 2017 02:06:37
"Grabber stopped" kommt leider nicht.
Da der Grabber und Converter ja noch funktionieren, bin ich mit meinem Latein am Ende.
Habt ihr noch eine Idee an was es liegen kann? Zumal es ja ca. 8 Monate ohne Probleme funktioniert hat?
Vielen Dank
Heiko
URI3L
2. Apr 2018, 09:19
Ich bin leider immer noch ratlos. Hat niemand eine Idee woran das liegen kann?
URI3L
10. Mai 2018, 20:15
Habe letzte Woche einen Raspberry Pi 3 für eine Smarthome-Steuerung gekauft. Bevor ich damit allerdings angefangen habe, hab ich die SD-Karte vom RasPi2 (Libreelec + Hyperion) in den neuen RasPi3 eingesteckt -> gleiches Problem.
Somit habe ich mir Ende letzter Woche einen neuen Grabber gekauft (LogiLink Audio und Video Grabber USB 2.0). Leider ohne Erfolg. Hab jetzt zum dritten mal die SD-Karte komplett formatiert und sogar eine neue Hypercon-Datei erstellt.
Es funktioniert mit internem Grabber (sprich mit Kodi) und ich kann die LED´s mit der iPhone App steuern. Beim externen HDMI-Signal bleiben allerdings die LED´s dunkel...
Marci_Marc
15. Mai 2018, 08:20
Du kannst doch in Hypercon mit Rechter Maustaste auf das bunte Vorschaubild -> Hole Bild von Grabber , prüfen, was der Grabber empfängt. es wundert mich sowieso, wieso Ambilight für Kodi bei dir funktioniert, denn in deiner Config ist der interne Grabber für Kodi garnicht konfiguriert. Nur der Externe. Oder hast du den Raspberry und alle anderen Zuspieler über einen AVR laufen?
URI3L
15. Mai 2018, 12:35
Marci_Marc hat geschrieben:Du kannst doch in Hypercon mit Rechter Maustaste auf das bunte Vorschaubild -> Hole Bild von Grabber , prüfen, was der Grabber empfängt. es wundert mich sowieso, wieso Ambilight für Kodi bei dir funktioniert, denn in deiner Config ist der interne Grabber für Kodi garnicht konfiguriert. Nur der Externe. Oder hast du den Raspberry und alle anderen Zuspieler über einen AVR laufen?
Hey Danke, dass sich wenigstens einer meldet ;)
Ich habe drei .json files. Einmal die normale mit der Kodi arbeitet. Dann zwei weitere: einmal für internen Grabber und einmal für externen Grabber. Diese werden mittels Favouritenmenü per Script auf die normale Datei überschrieben. So, wie es in dem einen Tutorial beschrieben ist. Hatte damals alles einwandfrei funktioniert. Die Umschaltung zwischen normaler und externer Datei geht auch weiterhin - nur bleiben bei externem Grabber die LEDs komplett dunkel...
Ich habe auch mal testweise eine komplett neue Datei mit HyperCon erstellt (mit externem Grabber) - leider ebenso ohne Erfolg.
Ich bin immernoch ratlos, da es ja weiterhin mit der iPhone App und mit dem internen Grabber über Kodi funktioniert.
Ich bin für jeden hilfreichen Tipp sehr dankbar...
Grüße
Heiko
Marci_Marc
15. Mai 2018, 13:00
Den Fall hatte ich auch schonmal. Hst du evtl am HDMI2AV Converter vergessen Strom per USB einzuspeisen? Hatte ich nachm Umzug auch vergessen und mich gewundert. Nachdem ich das USB Kabel wieder an den USB Port vom TV gesteckt hatte, ging auch das Ambilight bei externen Quellen wieder.
Ich weiß, dass manche Converter auch ohne extra Strom auskommen, aber falls das bei dir gerade auch so sein sollte, probier es mal bitte aus
URI3L
15. Mai 2018, 17:33
Ich habe den HDMI Konverter direkt am RasPi angeschlossen.
Wenn ich den Grabber am Laptop anschließe, bekomme ich auch ein Bild.
Wenn ich in Hypercon ein Bild vom Grabber holen will, hängt sich das Programm auf und ich muss es über Task-Manager abschießen.
mihatu
20. Mai 2018, 12:45
welchen Converter benutzt du?
URI3L
20. Mai 2018, 13:31
Einen silbernen Tendak. Mehr steht nicht drauf. Hatte aber gut ein halbes Jahr seinen Dienst verrichtet und scheint auch weiterhin zu funktionieren, da ein Bild auf dem Laptop ankommt.
sMode
22. Mai 2018, 18:25
Guten Tag,
hast du mir mittlerweile eine Lösung für das Problem gefunden ?
Stehe vor einem ähnlichen Fall.
Schalte ich auf externe Quellen, erscheint der Regenbogeneffekt und Signalton, nur gelegentlich! Am Wochenende ging es, davor hackte es, und jetzt geht wieder nichts mehr.
Screenshot vom Grabber führt manchmal zum Absturz von Hypercon und manchmal nicht. Ziemlich kurios.
Hatte mich bislang noch nicht auf Fehlersuche begeben können.
Viele Grüße
mihatu
22. Mai 2018, 21:57
Ich tippe immer noch auf den Converter.
Schalter des Tendak steht auf PAL?
sMode
26. Mai 2018, 11:15
Guten Tag,
der Konverter steht auf PAL, konnte die Fehler fast beheben. Ursache war das ich den Grabber sowie Konverter über USB an dem Pi dran hatte.
Scheinbar konnte dieser nicht genug Strom liefern, oder aber die Geräte haben zuviel Strom verbraucht, sodass der PI ziemlich instabil lief.
Habe den Konverter an den USB Anschluss vom TV angeschlossen.
Jetzt kann ich ohne weiteres zwischen den Quellen umstellen, allerdings stürtzt wohl Hyperion mit der Zeit ab, da die LEDs "einfrieren".
Mal sehen woran dies jetzt liegt. :|
URI3L
26. Mai 2018, 21:58
mein Problem konnte auch behoben werden. Woran es lag, kann ich allerdings immer noch nicht sagen. Hatte im Keller noch einen alten HDMI-Splitter mit dem es dann gelaufen ist. Wie ich aber wieder den vorherigen angeschlossen habe war das Problem nicht mehr. Es geht jetzt komischerweise. Was ich allerdings sehr seltsam fand: mit dem Splitter bekam ich ja ein Signal am TV und konnte mit dem Konverter direkt am Laptop angeschlossen ebenfalls das TV Bild sehen. Nur am Raspi ging es nicht.
sMode
28. Mai 2018, 17:44
Hmm so in etwa ist mein Problem auch, in Hypercon kann ich weiter Screenshots aufnehme, und sehe auch das es Aktuell ist. Allerdings frieren die LEDs ein.
Bin am überlegen ob ich das System konplettt neu aufsetzten soll, samt neusten Libreelec und Hyperion?!
Mfg
URI3L
28. Mai 2018, 18:10
komplettes Aufsetzen hatte ich auch schon zweimal hinter mir. Erfolglos. Erst nachdem der Splitter eine Weile vom Stromnetz getrennt war, klappte es. Beim Versuch einen Screenshot vom Grabber in Hypercon zu holen stürzte das Programm ab...
Wünsche dir viel Glück...
Heiko
