Hyperion startet nicht automatisch
Verfasst: 19. Mär 2018, 21:36
von Hanimaniac
Hallo Gemeinde,
ich habe ein kleines Problem mit meinem Ambilight.
Beim Start / Hochfahren des PIs (Raspberry PI B+) scheint Hyperion ( V1.03.3) automatisch zu starten,
nur leuchten die LEDs nicht und ich kann über HyperCon nichts ändern.
Ich muss es jedesmal über HyperCon stoppen und dann erneut starten.
Danach funktioniert alles problemlos.
Ich hoffe ihr könnt mir helfen.
Martin
boot/config.txt
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# mehr USB-Power
max_usb_current=1
Hyperion.config.json
      "rate"     : 1000000,
               "redChannel"      : 255,
               "greenChannel"      : 255,
               "blueChannel"      : 255
               "saturationGain"   : 1.2000,
               "gamma"        : 2.5000
               "gamma"        : 2.5000
               "gamma"        : 2.5000
         "time_ms"         : 100,
         "updateFrequency" : 30.0000,
   // V4L2 GRABBER CONFIG
      "sizeDecimation" : 8,
      "cropLeft" : 0,
      "cropRight" : 0,
      "cropTop" : 0,
      "cropBottom" : 0,
      "threshold" : 0.12,
      "duration_ms" : 8000,
   // NO FRAME GRABBER CONFIG
   // NO KODI CHECK CONFIG
         "vscan" : { "minimum" : 0.9421, "maximum" : 1.0000 }
         "vscan" : { "minimum" : 0.8895, "maximum" : 0.9526 }
         "vscan" : { "minimum" : 0.8368, "maximum" : 0.9000 }
         "vscan" : { "minimum" : 0.7842, "maximum" : 0.8474 }
         "vscan" : { "minimum" : 0.7316, "maximum" : 0.7947 }
         "vscan" : { "minimum" : 0.6789, "maximum" : 0.7421 }
         "vscan" : { "minimum" : 0.6263, "maximum" : 0.6895 }
         "vscan" : { "minimum" : 0.5737, "maximum" : 0.6368 }
         "vscan" : { "minimum" : 0.5211, "maximum" : 0.5842 }
         "vscan" : { "minimum" : 0.4684, "maximum" : 0.5316 }
         "vscan" : { "minimum" : 0.4158, "maximum" : 0.4789 }
         "vscan" : { "minimum" : 0.3632, "maximum" : 0.4263 }
         "vscan" : { "minimum" : 0.3105, "maximum" : 0.3737 }
         "vscan" : { "minimum" : 0.2579, "maximum" : 0.3211 }
         "vscan" : { "minimum" : 0.2053, "maximum" : 0.2684 }
         "vscan" : { "minimum" : 0.1526, "maximum" : 0.2158 }
         "vscan" : { "minimum" : 0.1000, "maximum" : 0.1632 }
         "vscan" : { "minimum" : 0.0474, "maximum" : 0.1105 }
         "vscan" : { "minimum" : 0.0000, "maximum" : 0.0579 }
         "vscan" : { "minimum" : 0.0000, "maximum" : 0.0600 }
         "hscan" : { "minimum" : 0.9656, "maximum" : 1.0000 },
         "hscan" : { "minimum" : 0.9344, "maximum" : 0.9719 },
         "hscan" : { "minimum" : 0.9031, "maximum" : 0.9406 },
         "hscan" : { "minimum" : 0.8719, "maximum" : 0.9094 },
         "hscan" : { "minimum" : 0.8406, "maximum" : 0.8781 },
         "hscan" : { "minimum" : 0.8094, "maximum" : 0.8469 },
         "hscan" : { "minimum" : 0.7781, "maximum" : 0.8156 },
         "hscan" : { "minimum" : 0.7469, "maximum" : 0.7844 },
         "hscan" : { "minimum" : 0.7156, "maximum" : 0.7531 },
         "hscan" : { "minimum" : 0.6844, "maximum" : 0.7219 },
         "hscan" : { "minimum" : 0.6531, "maximum" : 0.6906 },
         "hscan" : { "minimum" : 0.6219, "maximum" : 0.6594 },
         "hscan" : { "minimum" : 0.5906, "maximum" : 0.6281 },
         "hscan" : { "minimum" : 0.5594, "maximum" : 0.5969 },
         "hscan" : { "minimum" : 0.5281, "maximum" : 0.5656 },
         "hscan" : { "minimum" : 0.4969, "maximum" : 0.5344 },
         "hscan" : { "minimum" : 0.4656, "maximum" : 0.5031 },
         "hscan" : { "minimum" : 0.4344, "maximum" : 0.4719 },
         "hscan" : { "minimum" : 0.4031, "maximum" : 0.4406 },
         "hscan" : { "minimum" : 0.3719, "maximum" : 0.4094 },
         "hscan" : { "minimum" : 0.3406, "maximum" : 0.3781 },
         "hscan" : { "minimum" : 0.3094, "maximum" : 0.3469 },
         "hscan" : { "minimum" : 0.2781, "maximum" : 0.3156 },
         "hscan" : { "minimum" : 0.2469, "maximum" : 0.2844 },
         "hscan" : { "minimum" : 0.2156, "maximum" : 0.2531 },
         "hscan" : { "minimum" : 0.1844, "maximum" : 0.2219 },
         "hscan" : { "minimum" : 0.1531, "maximum" : 0.1906 },
         "hscan" : { "minimum" : 0.1219, "maximum" : 0.1594 },
         "hscan" : { "minimum" : 0.0906, "maximum" : 0.1281 },
         "hscan" : { "minimum" : 0.0594, "maximum" : 0.0969 },
         "hscan" : { "minimum" : 0.0281, "maximum" : 0.0656 },
         "hscan" : { "minimum" : 0.0000, "maximum" : 0.0344 },
         "vscan" : { "minimum" : 0.9400, "maximum" : 1.0000 }
journalctl -u hyperion
-- Logs begin at Tue 2018-03-20 20:12:03 UTC, end at Tue 2018-03-20 20:13:14 UTC. --
Mar 20 20:12:29 raspberrypi systemd[1]: Started Hyperion Systemd service.
Mar 20 20:12:31 raspberrypi hyperiond[238]: Hyperion Ambilight Deamon (238)
Mar 20 20:12:31 raspberrypi hyperiond[238]:         Version   : V1.03.3 (brindosch-2fbbcff/2f01dfa-1495880388
Mar 20 20:12:31 raspberrypi hyperiond[238]:         Build Time: Jun  3 2017 02:06:37
Mar 20 20:12:32 raspberrypi hyperiond[238]: INFO: Selected configuration file: /etc/hyperion/hyperion.config.
Mar 20 20:12:32 raspberrypi hyperiond[238]: HYPERION INFO: ColorTransform 'default' => [0; 102]
Mar 20 20:12:32 raspberrypi hyperiond[238]: HYPERION INFO: ColorCorrection 'default' => [0; 102]
Mar 20 20:12:32 raspberrypi hyperiond[238]: HYPERION INFO: ColorAdjustment 'default' => [0; 102]
Mar 20 20:12:32 raspberrypi hyperiond[238]: LEDDEVICE INFO: configuration:
Mar 20 20:12:32 raspberrypi hyperiond[238]: {
Mar 20 20:12:32 raspberrypi hyperiond[238]:         "colorOrder" : "rgb",
Mar 20 20:12:32 raspberrypi hyperiond[238]:         "name" : "MyHyperionConfig",
Mar 20 20:12:32 raspberrypi hyperiond[238]:         "output" : "/dev/spidev0.0",
Mar 20 20:12:32 raspberrypi hyperiond[238]:         "rate" : 1000000,
Mar 20 20:12:32 raspberrypi hyperiond[238]:         "type" : "ws2801"
Mar 20 20:12:32 raspberrypi hyperiond[238]: }
Mar 20 20:12:32 raspberrypi hyperiond[238]: Failed to open device('/dev/spidev0.0')
Mar 20 20:12:32 raspberrypi hyperiond[238]: INFO: Creating linear smoothing
Mar 20 20:12:32 raspberrypi hyperiond[238]: HYPERION (CS) INFO: Created linear-smoothing(interval_ms=33;settl
Mar 20 20:12:32 raspberrypi hyperiond[238]: EFFECTENGINE INFO: 27 effects loaded from directory /usr/share/hy
Mar 20 20:12:32 raspberrypi hyperiond[238]: EFFECTENGINE INFO: Initializing Python interpreter
Mar 20 20:12:34 raspberrypi hyperiond[238]: INFO: Hyperion started and initialised
Mar 20 20:12:34 raspberrypi hyperiond[238]: INFO: Boot sequence 'Rainbow swirl fast' EFFECTENGINE INFO: run e
Mar 20 20:12:34 raspberrypi hyperiond[238]: BLACKBORDER INFO: threshold set to 0.12 (31)
Mar 20 20:12:34 raspberrypi hyperiond[238]: BLACKBORDER INFO: mode:default
Mar 20 20:12:34 raspberrypi hyperiond[238]: started
Mar 20 20:12:34 raspberrypi hyperiond[238]: INFO: Json server created and started on port 19444
Mar 20 20:12:34 raspberrypi hyperiond[238]: INFO: Proto server created and started on port 19445
Mar 20 20:12:34 raspberrypi hyperiond[238]: V4L2GRABBER INFO: width=720 height=576
Mar 20 20:12:34 raspberrypi hyperiond[238]: V4L2GRABBER INFO: pixel format=YUYV
Mar 20 20:12:34 raspberrypi hyperiond[238]: V4L2GRABBER INFO: signal threshold set to: {25,25,25}
Mar 20 20:12:34 raspberrypi hyperiond[238]: V4L2GRABBER INFO: started
Mar 20 20:12:34 raspberrypi hyperiond[238]: INFO: V4L2 grabber created and started
Mar 20 20:12:35 raspberrypi hyperiond[238]: BORDER SWITCH REQUIRED!!
Mar 20 20:12:35 raspberrypi hyperiond[238]: CURRENT BORDER TYPE: unknown=0 hor.size=0 vert.size=0
Mar 20 20:12:36 raspberrypi hyperiond[238]: V4L2GRABBER INFO: stopped
Mar 20 20:12:43 raspberrypi hyperiond[238]: EFFECTENGINE INFO: effect finished
Mar 20 20:12:43 raspberrypi hyperiond[238]: V4L2GRABBER INFO: started
sudo service hyperion status
● hyperion.service - Hyperion Systemd service
   Loaded: loaded (/etc/systemd/system/hyperion.service; enabled; vendor preset: enabled)
   Active: active (running) since Tue 2018-03-20 20:20:41 UTC; 2min 39s ago
 Main PID: 240 (hyperiond)
   CGroup: /system.slice/hyperion.service
           └─240 /usr/bin/hyperiond /etc/hyperion/hyperion.config.json
Mar 20 20:20:46 raspberrypi hyperiond[240]: V4L2GRABBER INFO: signal threshold set to: {25,25,25}
Mar 20 20:20:46 raspberrypi hyperiond[240]: V4L2GRABBER INFO: started
Mar 20 20:20:46 raspberrypi hyperiond[240]: INFO: V4L2 grabber created and started
Mar 20 20:20:46 raspberrypi hyperiond[240]: BORDER SWITCH REQUIRED!!
Mar 20 20:20:46 raspberrypi hyperiond[240]: CURRENT BORDER TYPE: unknown=0 hor.size=0 vert.size=0
Mar 20 20:20:47 raspberrypi hyperiond[240]: V4L2GRABBER INFO: stopped
Mar 20 20:20:54 raspberrypi hyperiond[240]: EFFECTENGINE INFO: effect finished
Mar 20 20:20:55 raspberrypi hyperiond[240]: V4L2GRABBER INFO: started
Mar 20 20:20:58 raspberrypi hyperiond[240]: BORDER SWITCH REQUIRED!!
Mar 20 20:20:58 raspberrypi hyperiond[240]: CURRENT BORDER TYPE: unknown=0 hor.size=2 vert.size=2
Verfasst: 21. Mär 2018, 11:44
von Hanimaniac
Ich konnte das Problem lösen.
Nachdem ich alle Möglichkeiten ausgeschöpft hatte, blieb mir noch den PI zu tauschen. Jetzt funktioniert alles problemlos.
