/// APA102, Adalight, AmbiLed, Atmo, Hyperion-USBASP-WS2801, Hyperion-USBASP-WS2812, Lightberry, Lightpack, LPD6803, LPD8806, Multi-Lightpack, P9813, Paintpack, PhilipsHUE, PiBlaster, SEDU, file, ThinkerForge, TPM2, WS2801, WS2812b, None)
/// tuning parameters:
/// (else zero)
/// parameters:
"correction" :
"red" : 255,
"green" : 255,
"blue" : 255
"temperatureValues" :
"red" : 255,
"green" : 255,
"blue" : 255
"valueGain" : 1.0000
"luminanceGain" : 1.0000
"gamma" : 1.0000,
"gamma" : 1.0000,
"gamma" : 1.0000,
"updateFrequency" : 20.0000,
"threshold" : 0.0,
/// * priority : The priority of the selected effect/static color (default=0)
"priority" : 990
// "forwarder" :
"width" : 80,
"height" : 45,
"priority" : 900
// "xbmcVideoChecker" :
// "xbmcTcpPort" : 9090,
// "grabVideo" : true,
// "grabPictures" : true,
// "grabAudio" : true,
// "grabMenu" : false,
// "grabScreensaver" : true,
// "enable3DDetection" : true
// "boblightServer" :
// "port" : 19333,
// "priority" : 900
// "grabber-v4l2" :
// "device" : "/dev/video0",
// "input" : 0,
// "standard" : "no-change",
// "width" : -1,
// "height" : -1,
// "frameDecimation" : 2,
// "sizeDecimation" : 8,
// "priority" : 800,
// "mode" : "2D",
// "cropLeft" : 0,
// "cropRight" : 0,
// "cropTop" : 0,
// "cropBottom" : 0,
// "redSignalThreshold" : 0.0,
// "greenSignalThreshold" : 0.0,
// "blueSignalThreshold" : 0.0
/// being the first led.
"hscan" : { "minimum" : 0.5000, "maximum" : 0.5625 },
"hscan" : { "minimum" : 0.4375, "maximum" : 0.5000 },
"hscan" : { "minimum" : 0.3750, "maximum" : 0.4375 },
"hscan" : { "minimum" : 0.3125, "maximum" : 0.3750 },
"hscan" : { "minimum" : 0.2500, "maximum" : 0.3125 },
"hscan" : { "minimum" : 0.1875, "maximum" : 0.2500 },
"hscan" : { "minimum" : 0.1250, "maximum" : 0.1875 },
"hscan" : { "minimum" : 0.0625, "maximum" : 0.1250 },
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0625 },
"hscan" : { "minimum" : 0.5625, "maximum" : 0.6250 },
"hscan" : { "minimum" : 0.6250, "maximum" : 0.6875 },
"hscan" : { "minimum" : 0.6875, "maximum" : 0.7500 },
"hscan" : { "minimum" : 0.7500, "maximum" : 0.8125 },
"hscan" : { "minimum" : 0.8125, "maximum" : 0.8750 },
"hscan" : { "minimum" : 0.8750, "maximum" : 0.9375 },
"hscan" : { "minimum" : 0.9375, "maximum" : 1.0000 },
"index" : 32,a
"name" : "MyHyperionConfig",
"redChannel" : 255,
"greenChannel" : 0,
"blueChannel" : 0
"redChannel" : 0,
"greenChannel" : 255,
"blueChannel" : 0
"redChannel" : 0,
"greenChannel" : 0,
"blueChannel" : 255
"red" : 255,
"green" : 255,
"blue" : 255
"luminanceGain" : 1.0000,
"luminanceMinimum" : 0.0000
"gamma" : 2.5000
"gamma" : 2.5000
"gamma" : 2.5000
"time_ms" : 100,
// NO V4L2 GRABBER CONFIG
// FRAME GRABBER CONFIG
"threshold" : 0.0,
// KODI CHECK CONFIG
"xbmcAddress" : "192.168.178.29",
"xbmcTcpPort" : 8080,
"grabMenu" : false,
"grabPause" : false,
"port" : 22
"port" : 22
"hscan" : { "minimum" : 0.5789, "maximum" : 0.6053 },
"hscan" : { "minimum" : 0.4211, "maximum" : 0.4474 },
"hscan" : { "minimum" : 0.3947, "maximum" : 0.4211 },
"hscan" : { "minimum" : 0.3684, "maximum" : 0.3947 },
"hscan" : { "minimum" : 0.3421, "maximum" : 0.3684 },
"hscan" : { "minimum" : 0.3158, "maximum" : 0.3421 },
"hscan" : { "minimum" : 0.2895, "maximum" : 0.3158 },
"hscan" : { "minimum" : 0.2632, "maximum" : 0.2895 },
"hscan" : { "minimum" : 0.2368, "maximum" : 0.2632 },
"hscan" : { "minimum" : 0.2105, "maximum" : 0.2368 },
"hscan" : { "minimum" : 0.1842, "maximum" : 0.2105 },
"hscan" : { "minimum" : 0.1579, "maximum" : 0.1842 },
"hscan" : { "minimum" : 0.1316, "maximum" : 0.1579 },
"hscan" : { "minimum" : 0.1053, "maximum" : 0.1316 },
"hscan" : { "minimum" : 0.0789, "maximum" : 0.1053 },
"hscan" : { "minimum" : 0.0526, "maximum" : 0.0789 },
"hscan" : { "minimum" : 0.0263, "maximum" : 0.0526 },
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0263 },
"hscan" : { "minimum" : 0.4474, "maximum" : 0.4737 },
"hscan" : { "minimum" : 0.4737, "maximum" : 0.5000 },
"hscan" : { "minimum" : 0.5000, "maximum" : 0.5263 },
"hscan" : { "minimum" : 0.5263, "maximum" : 0.5526 },
"hscan" : { "minimum" : 0.5526, "maximum" : 0.5789 },
"hscan" : { "minimum" : 0.6053, "maximum" : 0.6316 },
"hscan" : { "minimum" : 0.6316, "maximum" : 0.6579 },
"hscan" : { "minimum" : 0.6579, "maximum" : 0.6842 },
"hscan" : { "minimum" : 0.6842, "maximum" : 0.7105 },
"hscan" : { "minimum" : 0.7105, "maximum" : 0.7368 },
"hscan" : { "minimum" : 0.7368, "maximum" : 0.7632 },
"hscan" : { "minimum" : 0.7632, "maximum" : 0.7895 },
"hscan" : { "minimum" : 0.7895, "maximum" : 0.8158 },
"hscan" : { "minimum" : 0.8158, "maximum" : 0.8421 },
"hscan" : { "minimum" : 0.8421, "maximum" : 0.8684 },
"hscan" : { "minimum" : 0.8684, "maximum" : 0.8947 },
"hscan" : { "minimum" : 0.8947, "maximum" : 0.9211 },
"hscan" : { "minimum" : 0.9211, "maximum" : 0.9474 },
"hscan" : { "minimum" : 0.9474, "maximum" : 0.9737 },
"hscan" : { "minimum" : 0.9737, "maximum" : 1.0000 },
