Ambilight erweiterung mit Philips HUE funktioniert nicht
Verfasst: 14. Jan 2017, 23:15
Guten Abend zusammen,
Leider funktioniert es bei mir nicht Philips Hue ansteuern zu lassen.
Die normalen LEDs hinterm TV funktionieren einwandfrei auch bei externen Quellen.
Hier meine hyperionhue.config.json
Und hier die logfile.
"name" : "MyHyperionConfigHue",
"type" : "philipshue",
"output" : "192.168.178.53",
"transitiontime" : 1,
"switchOffOnBlack" : true,
"username" : "vDQ99X*************************",
"lightIds" : [17],
"colorOrder" : "rgb",
"luminanceGain" : 1.0000,
"threshold" : 0.1000,
"gamma" : 1.0000
"gamma" : 1.0000
"gamma" : 1.0000
"type" : "none",
// V4L2 GRABBER CONFIG
// FRAME GRABBER CONFIG
"frequency_Hz" : 2.0,
"priority" : 893
"threshold" : 0.01,
// KODI CHECK CONFIG
"grabMenu" : false,
"grabPause" : true,
"duration_ms" : 1000,
"priority" : 701
"port" : 19447
"port" : 19448
"hscan" : { "minimum" : 0.0000, "maximum" : 0.1000 },
"vscan" : { "minimum" : 0.0000, "maximum" : 1.0000 }
"hscan" : { "minimum" : 0.9000, "maximum" : 1.0000 },
Hyperion Ambilight Deamon (400)
HYPERION INFO: ColorTransform 'default' => [0; 105]
HYPERION INFO: ColorCorrection 'default' => [0; 105]
HYPERION INFO: ColorAdjustment 'default' => [0; 105]
"colorOrder" : "rbg",
HYPERION INFO: Json forward to 127.0.0.1:19446
HYPERION INFO: Proto forward to 127.0.0.1:19447
INFO: Creating linear smoHYPERION INFO: Not creating any smoothing
EFFECTENGINE INFO: 27 effects loaded from directory /storagEFFECTENGINE INFO: 27 effects loaded from directory /storage/hyperion/LedDevicePhilipsHue::saveStates(nLights=2): got invalid response from light http://192.168.178.53/api/vDQ99XUz4y8ieSowVIiyOua+++++++++++++++/lights/16.
LedDevicePhilipsHue::saveStates(nLights=2): got invalid response from light http://192.168.178.53/api/vDQ99XUz4y8ieSowVI+++++++++++++++++++/lights/16.
LedDevicePhilipsHue::saveStates(nLights=2): got invalid response from light http://192.168.178.53/api/vDQ99XUz4y++++++++++++++++++++/lights/16.
what(): JSONSERVER ERROR: could not bind to port
Aborted (core dumped)
=0 vert.size=0
V4L2GRABBER INFO: stopped
V4L2GRABBER INFO: started
BORDER SWITCH REQUIRED!!
CURRENT BORDER TYPE: unknown=0 hor.size=0 vert.size=2
CURRENT BORDER TYPE: unknown=0 hor.size=0 vert.size=3
PROTOCONNECTION INFO: No connection to Hyperion: 127.0.0.1:19447
