Meine Ambilight/ Hyperion Konfiguration läuft unter KODI wunderbar, nur über den USB Grabber noch nicht so.
Schwarz wird als dunkelrot wiedergegeben und die Blackborder Erkennung funktioniert gar nicht. Wahrscheinlich hängt das irgendwie zusammen.
Mein Grabber: EasyCAP USB 2.0 Audio und Video Grabber mit Fushicai UTV007 Chipsatz
Die Grabber-Konfiguration:
"name" : "MyHyperionConfig",
"colorOrder" : "gbr"
"redChannel" : 255,
"greenChannel" : 0,
"blueChannel" : 0
"redChannel" : 0,
"greenChannel" : 230,
"blueChannel" : 0
"redChannel" : 0,
"greenChannel" : 0,
"blueChannel" : 160
"red" : 255,
"green" : 255,
"blue" : 255
"saturationGain" : 5.0000,
"luminanceGain" : 1.0000,
"luminanceMinimum" : 0.0000
"gamma" : 2.5000
"gamma" : 2.5000
"gamma" : 2.5000
"updateFrequency" : 50.0000,
// V4L2 GRABBER CONFIG
"redSignalThreshold" : 0.2,
"greenSignalThreshold" : 0.2,
"blueSignalThreshold" : 0.2
"threshold" : 0.001,
// NO FRAME GRABBER CONFIG
// NO KODI CHECK CONFIG
"vscan" : { "minimum" : 0.9800, "maximum" : 1.0000 }
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0200 },
"vscan" : { "minimum" : 0.9583, "maximum" : 1.0000 }
"vscan" : { "minimum" : 0.9167, "maximum" : 0.9583 }
"vscan" : { "minimum" : 0.8750, "maximum" : 0.9167 }
"vscan" : { "minimum" : 0.8333, "maximum" : 0.8750 }
"vscan" : { "minimum" : 0.7917, "maximum" : 0.8333 }
"vscan" : { "minimum" : 0.7500, "maximum" : 0.7917 }
"vscan" : { "minimum" : 0.7083, "maximum" : 0.7500 }
"vscan" : { "minimum" : 0.6667, "maximum" : 0.7083 }
"vscan" : { "minimum" : 0.6250, "maximum" : 0.6667 }
"vscan" : { "minimum" : 0.5833, "maximum" : 0.6250 }
"vscan" : { "minimum" : 0.5417, "maximum" : 0.5833 }
"vscan" : { "minimum" : 0.5000, "maximum" : 0.5417 }
"vscan" : { "minimum" : 0.4583, "maximum" : 0.5000 }
"vscan" : { "minimum" : 0.4167, "maximum" : 0.4583 }
"vscan" : { "minimum" : 0.3750, "maximum" : 0.4167 }
"vscan" : { "minimum" : 0.3333, "maximum" : 0.3750 }
"vscan" : { "minimum" : 0.2917, "maximum" : 0.3333 }
"vscan" : { "minimum" : 0.2500, "maximum" : 0.2917 }
"vscan" : { "minimum" : 0.2083, "maximum" : 0.2500 }
"vscan" : { "minimum" : 0.1667, "maximum" : 0.2083 }
"vscan" : { "minimum" : 0.1250, "maximum" : 0.1667 }
"vscan" : { "minimum" : 0.0833, "maximum" : 0.1250 }
"vscan" : { "minimum" : 0.0417, "maximum" : 0.0833 }
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0417 }
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0200 }
"hscan" : { "minimum" : 0.9800, "maximum" : 1.0000 },
"index" : 121,
"index" : 122,
