So weit so gut.... Es gibt ein letztes Problem
Verfasst: 5. Feb 2016, 11:38
von Philipp;)
Hallo Community,
nach vielem hin und her habe ich nun mein ambilight zum laufen bekommen. es macht alles was es soll und diefarben stimmen auch.
ABER... ich kann einstellen was ich will ich habe ambilight auch immer im menü.
ich benutze das dualboot system kodi/recalbox
und das ist meine hyperion.config
"colorOrder" : "rbg"
/// tuning parameters:
/// (else zero)
/// parameters:
"saturationGain" : 1.2000,
"valueGain" : 1.2000
"threshold" : 0.1000,
"gamma" : 2.0000,
"gamma" : 2.0000,
"whitelevel" : 0.8000
"gamma" : 2.0000,
"whitelevel" : 0.7000
"time_ms" : 100,
"updateFrequency" : 25.0000
/// being the first led.
"hscan" : { "minimum" : 0.6000, "maximum" : 0.6286 },
"hscan" : { "minimum" : 0.6286, "maximum" : 0.6571 },
"hscan" : { "minimum" : 0.6571, "maximum" : 0.6857 },
"hscan" : { "minimum" : 0.6857, "maximum" : 0.7143 },
"hscan" : { "minimum" : 0.7143, "maximum" : 0.7429 },
"hscan" : { "minimum" : 0.7429, "maximum" : 0.7714 },
"hscan" : { "minimum" : 0.7714, "maximum" : 0.8000 },
"hscan" : { "minimum" : 0.8000, "maximum" : 0.8286 },
"hscan" : { "minimum" : 0.8286, "maximum" : 0.8571 },
"hscan" : { "minimum" : 0.8571, "maximum" : 0.8857 },
"hscan" : { "minimum" : 0.8857, "maximum" : 0.9143 },
"hscan" : { "minimum" : 0.9143, "maximum" : 0.9429 },
"hscan" : { "minimum" : 0.9429, "maximum" : 0.9714 },
"hscan" : { "minimum" : 0.9714, "maximum" : 1.0000 },
"hscan" : { "minimum" : 0.5714, "maximum" : 0.6000 },
"hscan" : { "minimum" : 0.5429, "maximum" : 0.5714 },
"hscan" : { "minimum" : 0.5143, "maximum" : 0.5429 },
"hscan" : { "minimum" : 0.4857, "maximum" : 0.5143 },
"hscan" : { "minimum" : 0.4571, "maximum" : 0.4857 },
"hscan" : { "minimum" : 0.4286, "maximum" : 0.4571 },
"hscan" : { "minimum" : 0.4000, "maximum" : 0.4286 },
"hscan" : { "minimum" : 0.3714, "maximum" : 0.4000 },
"hscan" : { "minimum" : 0.3429, "maximum" : 0.3714 },
"hscan" : { "minimum" : 0.3143, "maximum" : 0.3429 },
"hscan" : { "minimum" : 0.2857, "maximum" : 0.3143 },
"hscan" : { "minimum" : 0.2571, "maximum" : 0.2857 },
"hscan" : { "minimum" : 0.2286, "maximum" : 0.2571 },
"hscan" : { "minimum" : 0.2000, "maximum" : 0.2286 },
"hscan" : { "minimum" : 0.1714, "maximum" : 0.2000 },
"hscan" : { "minimum" : 0.1429, "maximum" : 0.1714 },
"hscan" : { "minimum" : 0.1143, "maximum" : 0.1429 },
"hscan" : { "minimum" : 0.0857, "maximum" : 0.1143 },
"hscan" : { "minimum" : 0.0571, "maximum" : 0.0857 },
"hscan" : { "minimum" : 0.0286, "maximum" : 0.0571 },
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0286 },
"threshold" : 0.02
"effect" : "Knight rider",
"duration_ms" : 10000
"frequency_Hz" : 10.0
"grabMenu" : false,
// "port" : 19333
habe schon nach versteckten ordnern gesucht und das system neu aufgesetzt, aber ich kann einstellen was ich will das menü wird auch immer angesteuert.
bitte um hilfe
philipp
Verfasst: 5. Feb 2016, 11:44
von Squizzy
Gleiche Problem hatte ich gestern auch als ich alles aus dem Kopf aufgesetzt habe.
Du musst in Kodi einstellen, dass Programme von extern Kodi steuern dürfen ;) Dann neustarten und es fluppt. Definitiv! :D
was man nämlich nicht sieht ist die ausgabe von hyperion und wenn man es manuell ausführt dann steht da cannot connect to xbmc (0) oder so ähnlich ;) das sorgt dafür, dass hyperion diese abfrage nicht machen kann, in welchem menü und unterpunkt kodi sich befindet.
Verfasst: 5. Feb 2016, 11:51
von Philipp;)
Du meinst Einstellungen-> Dienste-> Fernsteuerung ?
Laut Akis Tutorial soll man es Ausschalten, aber es ist egal was ich mache, es bleibt an :?
Verfasst: 5. Feb 2016, 11:54
von Squizzy
Richtig. Dort beides aktivieren.
edit: was heißt bleibt an?
edit2: Also im Tutorial steht eindeutig
Wichtig ist, dass beide Dienste aktiviert sind.
edit3: wenn das mit komplettem neustart trotzdem nicht geht. check mal ob deine config ihm richtigen ordner ".config" ist und du nicht ausversehen ganze zeit im hyperion ordner die config überschreibst ;)
Ansonsten kill mal per ssh den prozess und starte ihn neu mit
guck mal ob da fehler gelistet werden ;)
Verfasst: 5. Feb 2016, 11:59
von Philipp;)
OMFG wer lesen kann ist klar im Vorteil ;(
Beide aktiviert und nun geht es.
Vielen Dank für die schnelle Hilfe. Das Forum ist MEGA.
Lg Philipp
