19. Apr 2017, 15:06
Hier die hyperion.config.json
"colorOrder" : "rbg"
"luminanceGain" : 1.0000,
// NO V4L2 GRABBER CONFIG
"threshold" : 0.14,
// BOBLIGHT SERVER CONFIG
"boblightServer" :
"port" : 19333,
"priority" : 900
// JSON/PROTO FORWARD CONFIG
"forwarder" :
"json" : ["127.0.0.1:19446"],
"proto" : ["127.0.0.1:19447"]
// NO FRAME GRABBER CONFIG
// NO KODI CHECK CONFIG
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0400 }
"vscan" : { "minimum" : 0.0400, "maximum" : 0.0800 }
"vscan" : { "minimum" : 0.0800, "maximum" : 0.1200 }
"vscan" : { "minimum" : 0.1200, "maximum" : 0.1600 }
"vscan" : { "minimum" : 0.1600, "maximum" : 0.2000 }
"vscan" : { "minimum" : 0.2000, "maximum" : 0.2400 }
"vscan" : { "minimum" : 0.2400, "maximum" : 0.2800 }
"vscan" : { "minimum" : 0.2800, "maximum" : 0.3200 }
"vscan" : { "minimum" : 0.3200, "maximum" : 0.3600 }
"vscan" : { "minimum" : 0.3600, "maximum" : 0.4000 }
"vscan" : { "minimum" : 0.4000, "maximum" : 0.4400 }
"vscan" : { "minimum" : 0.4400, "maximum" : 0.4800 }
"vscan" : { "minimum" : 0.4800, "maximum" : 0.5200 }
"vscan" : { "minimum" : 0.5200, "maximum" : 0.5600 }
"vscan" : { "minimum" : 0.5600, "maximum" : 0.6000 }
"vscan" : { "minimum" : 0.6000, "maximum" : 0.6400 }
"vscan" : { "minimum" : 0.6400, "maximum" : 0.6800 }
"vscan" : { "minimum" : 0.6800, "maximum" : 0.7200 }
"vscan" : { "minimum" : 0.7200, "maximum" : 0.7600 }
"vscan" : { "minimum" : 0.7600, "maximum" : 0.8000 }
"vscan" : { "minimum" : 0.8000, "maximum" : 0.8400 }
"vscan" : { "minimum" : 0.8400, "maximum" : 0.8800 }
"vscan" : { "minimum" : 0.8800, "maximum" : 0.9200 }
"vscan" : { "minimum" : 0.9200, "maximum" : 0.9600 }
"vscan" : { "minimum" : 0.9600, "maximum" : 1.0000 }
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0222 },
"hscan" : { "minimum" : 0.0222, "maximum" : 0.0444 },
"hscan" : { "minimum" : 0.0444, "maximum" : 0.0667 },
"hscan" : { "minimum" : 0.0667, "maximum" : 0.0889 },
"hscan" : { "minimum" : 0.0889, "maximum" : 0.1111 },
"hscan" : { "minimum" : 0.1111, "maximum" : 0.1333 },
"hscan" : { "minimum" : 0.1333, "maximum" : 0.1556 },
"hscan" : { "minimum" : 0.1556, "maximum" : 0.1778 },
"hscan" : { "minimum" : 0.1778, "maximum" : 0.2000 },
"hscan" : { "minimum" : 0.2000, "maximum" : 0.2222 },
"hscan" : { "minimum" : 0.2222, "maximum" : 0.2444 },
"hscan" : { "minimum" : 0.2444, "maximum" : 0.2667 },
"hscan" : { "minimum" : 0.2667, "maximum" : 0.2889 },
"hscan" : { "minimum" : 0.2889, "maximum" : 0.3111 },
"hscan" : { "minimum" : 0.3111, "maximum" : 0.3333 },
"hscan" : { "minimum" : 0.3333, "maximum" : 0.3556 },
"hscan" : { "minimum" : 0.3556, "maximum" : 0.3778 },
"hscan" : { "minimum" : 0.3778, "maximum" : 0.4000 },
"hscan" : { "minimum" : 0.4000, "maximum" : 0.4222 },
"hscan" : { "minimum" : 0.4222, "maximum" : 0.4444 },
"hscan" : { "minimum" : 0.4444, "maximum" : 0.4667 },
"hscan" : { "minimum" : 0.4667, "maximum" : 0.4889 },
"hscan" : { "minimum" : 0.4889, "maximum" : 0.5111 },
"hscan" : { "minimum" : 0.5111, "maximum" : 0.5333 },
"hscan" : { "minimum" : 0.5333, "maximum" : 0.5556 },
"hscan" : { "minimum" : 0.5556, "maximum" : 0.5778 },
"hscan" : { "minimum" : 0.5778, "maximum" : 0.6000 },
"hscan" : { "minimum" : 0.6000, "maximum" : 0.6222 },
"hscan" : { "minimum" : 0.6222, "maximum" : 0.6444 },
"hscan" : { "minimum" : 0.6444, "maximum" : 0.6667 },
"hscan" : { "minimum" : 0.6667, "maximum" : 0.6889 },
"hscan" : { "minimum" : 0.6889, "maximum" : 0.7111 },
"hscan" : { "minimum" : 0.7111, "maximum" : 0.7333 },
"hscan" : { "minimum" : 0.7333, "maximum" : 0.7556 },
"hscan" : { "minimum" : 0.7556, "maximum" : 0.7778 },
"hscan" : { "minimum" : 0.7778, "maximum" : 0.8000 },
"hscan" : { "minimum" : 0.8000, "maximum" : 0.8222 },
"hscan" : { "minimum" : 0.8222, "maximum" : 0.8444 },
"hscan" : { "minimum" : 0.8444, "maximum" : 0.8667 },
"hscan" : { "minimum" : 0.8667, "maximum" : 0.8889 },
"hscan" : { "minimum" : 0.8889, "maximum" : 0.9111 },
"hscan" : { "minimum" : 0.9111, "maximum" : 0.9333 },
"hscan" : { "minimum" : 0.9333, "maximum" : 0.9556 },
"hscan" : { "minimum" : 0.9556, "maximum" : 0.9778 },
"hscan" : { "minimum" : 0.9778, "maximum" : 1.0000 },
"vscan" : { "minimum" : 0.9565, "maximum" : 1.0000 }
"vscan" : { "minimum" : 0.9130, "maximum" : 0.9565 }
"vscan" : { "minimum" : 0.8696, "maximum" : 0.9130 }
"vscan" : { "minimum" : 0.8261, "maximum" : 0.8696 }
"vscan" : { "minimum" : 0.7826, "maximum" : 0.8261 }
"vscan" : { "minimum" : 0.7391, "maximum" : 0.7826 }
"vscan" : { "minimum" : 0.6957, "maximum" : 0.7391 }
"vscan" : { "minimum" : 0.6522, "maximum" : 0.6957 }
"vscan" : { "minimum" : 0.6087, "maximum" : 0.6522 }
"vscan" : { "minimum" : 0.5652, "maximum" : 0.6087 }
"vscan" : { "minimum" : 0.5217, "maximum" : 0.5652 }
"vscan" : { "minimum" : 0.4783, "maximum" : 0.5217 }
"vscan" : { "minimum" : 0.4348, "maximum" : 0.4783 }
"vscan" : { "minimum" : 0.3913, "maximum" : 0.4348 }
"vscan" : { "minimum" : 0.3478, "maximum" : 0.3913 }
"vscan" : { "minimum" : 0.3043, "maximum" : 0.3478 }
"vscan" : { "minimum" : 0.2609, "maximum" : 0.3043 }
"vscan" : { "minimum" : 0.2174, "maximum" : 0.2609 }
"vscan" : { "minimum" : 0.1739, "maximum" : 0.2174 }
"vscan" : { "minimum" : 0.1304, "maximum" : 0.1739 }
"vscan" : { "minimum" : 0.0870, "maximum" : 0.1304 }
"vscan" : { "minimum" : 0.0435, "maximum" : 0.0870 }
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0435 }
"index" : 121,
"index" : 122,
"index" : 123,
"index" : 124,
"index" : 125,
"index" : 126,
"index" : 127,
"index" : 128,
"index" : 129,
"index" : 130,
"index" : 131,
"index" : 132,
"index" : 133,
"index" : 134,
"index" : 135,
"index" : 136,
"index" : 137,
