.json
Hyperion Ambilight Deamon
Version : V1.02.0 (brindosch-f4162eb/2d45d51-1462453507
Build Time: May 5 2016 06:07:47
HYPERION INFO: ColorTransform 'default' => [0; 115]
HYPERION INFO: ColorCorrection 'default' => [0; 115]
HYPERION INFO: ColorAdjustment 'default' => [0; 115]
"colorOrder" : "rgb",
"name" : "MyHyperionConfig",
HYPERION (CS) INFO: Created linear-smoothing(interval_ms=40;settlingTime_ms=100; updateDelay=0
EFFECTENGINE ERROR: Effect directory can not be loaded: /opt/hyperion/effects
INFO: Boot sequence 'Rainbow swirl fast' EFFECTENGINE INFO: run effect Rainbow s wirl fast on channel 0
started
KODICHECK INFO: Kodi Message: {"id":666,"jsonrpc":"2.0","result":[{"playerid":1, "type":"video"}]}
KODICHECK INFO: switching to VIDEO mode
KODICHECK INFO: Kodi Message: {"id":668,"jsonrpc":"2.0","result":{"System.Screen SaverActive":false}}
KODICHECK INFO: Kodi Message: {"id":667,"jsonrpc":"2.0","result":{"item":{"file" :"/var/media/Netti-Stick/Ant-Man/Ant-Man.mkv","label":"Ant-Man.mkv","type":"unkn own"}}}
KODICHECK INFO: Kodi Message: {"id":670,"jsonrpc":"2.0","result":{"version":{"ma jor":15,"minor":2,"revision":"02e7013","tag":"stable"}}}
BORDER SWITCH REQUIRED!!
KODICHECK INFO: Kodi Message: {"jsonrpc":"2.0","method":"Player.OnStop","params" :{"data":{"end":false,"item":{"title":"Ant-Man.mkv","type":"movie"}},"sender":"x bmc"}}
KODICHECK INFO: Kodi Message: {"jsonrpc":"2.0","method":"GUI.OnScreensaverActiva ted","params":{"data":null,"sender":"xbmc"}}
OpenELEC:~ # killall hiperiond
killall: hiperiond: no process killed
.json
started
