Hallo habe folgendes Problem:
Bin mit Putty auf dem RASPI und hab auch den curl lt. Beschreibung durchgeführt.
curl -L --output install_hyperion.sh --get https://raw.githubusercontent.com/tvdzw ... yperion.sh
Jedoch beim ausführen des Skripts kommt folgende Meldung:
This script will install/update Hyperion Ambient Light
Created by brindosch - hyperion-project.org - the official Hyperion source.
---> Stop Hyperion, if necessary
---> Downloading the appropriate Hyperion release
---> Downloading Hyperion OpenELEC/LibreELEC release
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
tar: invalid magic
tar: short read
---> Downloading Hyperion OpenELEC/LibreELEC dependencies
tar: can't change directory to '/storage/hyperion/bin': No such file or directory
chmod: /storage/hyperion/bin: No such file or directory
rm: can't remove '/storage/hyperion/services': No such file or directory
---> Starting Hyperion
Hyperion Installation/Update finished!
Please download the latest HyperCon version to benefit from new features!
To create a config, follow the HyperCon Guide at our Wiki (EN/DE)!
Wiki: wiki.hyperion-project.org Webpage: http://www.hyperion-project.org
# OpenELEC #
# http://openelec.tv #
OpenELEC (official) Version: 7.0.1
OpenELEC:~ #
Kann mir da einer einen Tip geben, wie ich das ssh dazu bekomme mir den curl bei der Installation durchzuführen?
DANKE und Gruß ANdy
