habe heute mal den N64 Emulator probiert, jedoch komme ich nach dem Starten des Games wieder zurück in die Spieleliste und die Auflösung ändert sich dann.
Habe den Fix schon probiert, jedoch ohne Erfolg:
https://github.com/recalbox/recalbox-os ... -to-ES-(EN)
Getestete Spiele: MarioKart64, SuperMario64 and Donkey Kong 64
Raspberry PI 1 Model B
Recalbox 4.0
Hier meine Recalbox.conf:
System Variable
You can configure your recalbox from here
To set a variable, remove the first ; on the line
------------ A - System Options -----------
Uncomment the system.power.switch you use
;system.power.switch=ATX_RASPI_R2_6 # http://lowpowerlab.com/atxraspi/#installation
;system.power.switch=MAUSBERRY # http://mausberry-circuits.myshopify.com/pages/setup
;system.power.switch=REMOTEPIBOARD_2003 # http://www.msldigital.com/pages/support-for-remotepi-board-2013
;system.power.switch=REMOTEPIBOARD_2005 # http://www.msldigital.com/pages/support-for-remotepi-board-plus-2015
;system.power.switch=PIN56ONOFF # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
;system.power.switch=PIN56PUSH # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
;system.power.switch=PIN356ONOFFRESET # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
Recalbox Manager (http manager)
system.manager.enabled=1
Recalbox API (REST)
system.api.enabled=0
EmulationStation menu style
default -> default all options menu
none -> no menu except the game search menu
bartop -> less menu, only needed for bartops
system.es.menu=default
Emulator special keys
default -> default all special keys
nomenu -> cannot popup the emulator menu
none -> no special keys in emulators
system.emulators.specialkeys=default
Show or hide kodi in emulationstation (0,1)
kodi.enabled=1
Start kodi at launch (0,1)
kodi.atstartup=0
set x button shortcut (0,1)
kodi.xbutton=1
Kodi can wait for a network component before starting
waithost is the ip or hostname that must answer to a ping to validate the availability
waittime is the maximum time waited when kodi boots
if waitmode is required, kodi will not start if the component is not available
if waitmode is wish, kodi will start if the component is not available
if waitmode is not set or has another value, kodi will start immediately
;kodi.network.waitmode=required
;kodi.network.waittime=10
;kodi.network.waithost=192.168.0.50
------------ B - Network ------------
Set system hostname
system.hostname=RECALBOX
Activate wifi (0,1)
wifi.enabled=1
Wifi SSID (string)
wifi.ssid=C:\Keylogger.exe
Wifi KEY (string)
Escape your special chars (# ; $) with a backslash : $ => $
wifi.key=dg6P_47iR.173Gw,MBtui9+
Samba share
system.samba.enabled=1
VIRTUAL GAMEPADS
system.virtual-gamepads.enabled=1
SSH
system.ssh.enabled=1
------------ C - Audio ------------
Set the audio device (auto, hdmi, jack)
audio.device=auto
Set system volume (0..100)
audio.volume=90
Enable or disable system sounds in ES (0,1)
audio.bgmusic=1
-------------- D - Controllers -----------------
Enable support for standard bluetooth controllers
controllers.bluetooth.enabled=1
Please enable only one of these
-------------- D1 - PS3 Controllers ------------
##Enable PS3 controllers support
controllers.ps3.enabled=1
Choose an driver between official (for official and gasia) or shanwan if you have dualshock clones (official,gasia)
controllers.ps3.driver=official
------------ D2 - XBOX Controllers ------------
Xbox controllers are already supported, but xboxdrv can solve some compatibility issues
Enable xboxdrv driver, disable this if you enabled ps3 controllers (0,1)
controllers.xboxdrv.enabled=0
Set the amount of controllers to use with xboxdrv (0..4)
controllers.xboxdrv.nbcontrols=2
------------ D3 - GPIO Controllers ------------
GPIO Controllers
enable controllers on GPIO with mk_arcarde_joystick_rpi (0,1)
controllers.gpio.enabled=0
mk_gpio arguments, map=1 for one controller, map=1,2 for 2 (map=1,map=1,2)
controllers.gpio.args=map=1,2
DB9 Controllers
Enable DB9 drivers for atari, megadrive, amiga controllers (0,1)
controllers.db9.enabled=0
db9 arguments
controllers.db9.args=map=1
Gamecon controllers
Enable gamecon controllers, for nes, snes psx (0,1)
controllers.gamecon.enabled=0
gamecon_args
controllers.gamecon.args=map=1
XGaming's XArcade Tankstik and other compatible devices
controllers.xarcade.enabled=1
------------ F - Language and keyboard ------------
Set the language of the system (fr_FR,en_US,en_GB,de_DE,pt_BR,es_ES,it_IT,eu_ES,tr_TR,zh_CN)
system.language=de_DE
set the keyboard layout (fr,en,de,us,es)
;system.kblayout=us
Set you local time
Select your timezone from : ls /usr/share/zoneinfo/ (string)
;system.timezone=Europe/Paris
------------ G - UPDATES ------------
Automatically check for updates at start (0,1)
updates.enabled=1
default : stable ; set to beta to get the next version currently being tested. set to unstable at your own risk to get the development version.
updates.type=stable
------------ H - HERE IT IS - GLOBAL EMULATOR CONFIGURATION ------------
The global value will be used for all emulators, except if the value
is redefined in the emulator
Set game resolution for emulators
select your mode from the command : tvservice -m [MODE]
CEA 5 HDMI : 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
CEA 4 HDMI : 1280x720 @ 60Hz 16:9, clock:74MHz progressive
use 'default' for using the default resolution
(string)
global.videomode=CEA 4 HDMI
Shader set
Automatically select shaders for all systems
## (none, retro, scanlines)
global.shaderset=none
Once enabled, your screen will be cropped, and you will have a pixel perfect image (0,1)
global.integerscale=0
Set gpslp shader for all emulators (prefer shadersets above). Absolute path (string)
global.shaders=
Set ratio for all emulators (auto,4/3,16/9,16/10,custom)
global.ratio=auto
Set smooth for all emulators (0,1)
global.smooth=1
Set rewind for all emulators (0,1)
global.rewind=0
Set autosave/load savestate for all emulators (0,1)
global.autosave=0
Enable retroarchievements (0,1)
Set your www.retroachievements.org username/password
global.retroachievements=0
global.retroachievements.username=
global.retroachievements.password=
Set retroarch input driver (auto, udev, sdl2)
If you don't have issues with your controllers, let auto
global.inputdriver=auto
If you do not want recalboxOS to generate the configuration for all emulators (string)
;global.configfile=/path/to/my/configfile.cfg
------------ I - EMULATORS CHOICES -----------
You can override the global configuration here
Here is the snes example
;snes.videomode=CEA 4 HDMI
snes.core=pocketsnes
;snes.shaders=/recalbox/share/shaders/shaders_glsl/mysnesshader.gplsp
;snes.ratio=16/9
;snes.smooth=0
;snes.rewind=1
;snes.autosave=0
;snes.emulator=libretro
;snes.integerscale=0
If you do not want recalboxOS to generate the configuration for the emulator :
;snes.configfile=/path/to/my/configfile.cfg
Default cores for RPi1
gba.core=gpsp
mame.core=imame4all
nes.core=fceumm
NeoGeo emulator
You can use pifba or a libretro core (fba2x,libretro)
neogeo.emulator=fba2x
If you set libretro as neogeo.emulator, uncomment the line below and set the retroarch core (fba,imame4all)
;neogeo.core=fba
N64 emulator is configured to display a screen with a 640x480 resolution (native n64 resolution)
So you must use one of these video modes (DMT 4 HDMI,CEA 1 HDMI).
If your screen is not compatible with one of these video modes, please check the recalbox's wiki.
n64.videomode=DMT 4 HDMI
If you are using a CRT screen, please change the setting above with this one :
n64.videomode=default
Configurations generated by Recalbox
Habe die N64 Einstellung selber eingetragen, da Recalbox von sich selber nichts gemacht hat.
Hier die Tv-Service Ergebnisse aus der Konsole:
Ich hoffe einer von euch kann mir helfen
Danke schonmal
