Kann mir jemand dabei helfen wie ich Steam via Kodi zum laufen bekomme?
1000 Anleitungen die mir zeigen wie ich das Add-On installiere. Kein Problem bis hier hin. Allerdings lässt sich Steam nicht auf dem RP2 starten.
Log gibt folgendes zurück:
00:03:00 37.421844 T:1554285632 NOTICE: script.steam.launcher: ****Running Steam-Launcher v3.1.2....
00:03:00 37.422146 T:1554285632 NOTICE: script.steam.launcher: running on osAndroid, osOsx, osLinux, osWin: 0 0 1 0
00:03:00 37.422325 T:1554285632 NOTICE: script.steam.launcher: System text encoding in use: ANSI_X3.4-1968
00:03:00 37.422462 T:1554285632 NOTICE: script.steam.launcher: usr scripts are set to be checked for updates...
00:03:00 37.422600 T:1554285632 NOTICE: script.steam.launcher: usr scripts are not set to be deleted, running version check
00:03:00 37.426952 T:1554285632 NOTICE: script.steam.launcher: sys "steam.launcher.script.revision=": 014
00:03:00 37.429012 T:1554285632 NOTICE: script.steam.launcher: usr "steam.launcher.script.revision=": 014
00:03:00 37.429291 T:1554285632 NOTICE: script.steam.launcher: userdata script are up to date
00:03:00 37.429543 T:1554285632 NOTICE: script.steam.launcher: skipping deleting userdata scripts, option disabled: delUserScriptSett = false
00:03:00 37.430946 T:1554285632 NOTICE: script.steam.launcher: script file already exists, skipping copy to userdata: /storage/.kodi/userdata/addon_data/script.steam.launcher/scripts/steam-launch.sh
00:03:00 37.455215 T:1554285632 NOTICE: script.steam.launcher: ERROR: System program "wmctrl" not present, install it via you system package manager or if you are running the SteamOS compositor disable the addon option "Check for program wmctrl" (ONLY FOR CERTAIN USE CASES!!)
00:03:00 37.457790 T:1554285632 DEBUG: LocalizeStrings: no translation available in currently set gui language, at path /storage/.kodi/addons/script.steam.launcher/resources/language/German
00:03:00 37.459278 T:1554285632 DEBUG: LocalizeStrings: no strings.po file exist at /storage/.kodi/addons/script.steam.launcher/resources/language/English, fallback to strings.xml
00:03:00 37.462337 T:1554285632 INFO: CPythonInvoker(2, /storage/.kodi/addons/script.steam.launcher/default.py): script aborted
00:03:00 37.472324 T:1554285632 INFO: Python script stoppedWas hat das genau zu bedeuten und wie kannich das Problem lösen?
ERROR: System program "wmctrl" not present, install it via you system package manager or if you are running the SteamOS compositor disable the addon option "Check for program wmctrl" (ONLY FOR CERTAIN USE CASES!!)Viele Grüße
