toddehawk
Bild zu weit links...
30. Jan 2016, 21:07
Moin Moin,
dank b2un0 hab ich meine Ambilight Grundkonfigurationmässig ja schon einmal hinbekommen ;)
Jetzt habe ich mich dieses Wochenende rangesetzt und die Version für alle HDMI Quellen eingebaut.
Leider ist mein Bild vom Grabber irgendwie zu weit links.
Hier wäre meine Config:
   /// APA102, Adalight, AmbiLed, Atmo, Hyperion-USBASP-WS2801, Hyperion-USBASP-WS2812, Lightberry, Lightpack, LPD6803, LPD8806, Multi-Lightpack, P9813, Paintpack, PhilipsHUE, PiBlaster, SEDU, Test, ThinkerForge, TPM2, WS2801, WS2812b, None)
      "name"       : "MyPi",
      "rate"     : 250000,
      "colorOrder" : "rbg"
               "valueGain"      : 1.0000
               "threshold"  : 0.0000,
               "gamma"      : 1.0000,
               "gamma"      : 1.0000,
               "gamma"      : 1.0000,
      "threshold" : 0.01
//    "framegrabber" :
//       "width" : 64,
//       "height" : 64,
//       "frequency_Hz" : 10.0
      "grabMenu" : false,
//    "boblightServer" :
//       "port" : 19333
   ///  * priority             : Hyperion priority channel [default=800]
         "hscan" : { "minimum" : 0.6053, "maximum" : 0.6316 },
         "hscan" : { "minimum" : 0.6316, "maximum" : 0.6579 },
         "hscan" : { "minimum" : 0.6579, "maximum" : 0.6842 },
         "hscan" : { "minimum" : 0.6842, "maximum" : 0.7105 },
         "hscan" : { "minimum" : 0.7105, "maximum" : 0.7368 },
         "hscan" : { "minimum" : 0.7368, "maximum" : 0.7632 },
         "hscan" : { "minimum" : 0.7632, "maximum" : 0.7895 },
         "hscan" : { "minimum" : 0.7895, "maximum" : 0.8158 },
         "hscan" : { "minimum" : 0.8158, "maximum" : 0.8421 },
         "hscan" : { "minimum" : 0.8421, "maximum" : 0.8684 },
         "hscan" : { "minimum" : 0.8684, "maximum" : 0.8947 },
         "hscan" : { "minimum" : 0.8947, "maximum" : 0.9211 },
         "hscan" : { "minimum" : 0.9211, "maximum" : 0.9474 },
         "hscan" : { "minimum" : 0.9474, "maximum" : 0.9737 },
         "hscan" : { "minimum" : 0.9737, "maximum" : 1.0000 },
         "vscan" : { "minimum" : 0.9545, "maximum" : 1.0000 }
         "vscan" : { "minimum" : 0.9091, "maximum" : 0.9545 }
         "vscan" : { "minimum" : 0.8636, "maximum" : 0.9091 }
         "vscan" : { "minimum" : 0.8182, "maximum" : 0.8636 }
         "vscan" : { "minimum" : 0.7727, "maximum" : 0.8182 }
         "vscan" : { "minimum" : 0.7273, "maximum" : 0.7727 }
         "vscan" : { "minimum" : 0.6818, "maximum" : 0.7273 }
         "vscan" : { "minimum" : 0.6364, "maximum" : 0.6818 }
         "vscan" : { "minimum" : 0.5909, "maximum" : 0.6364 }
         "vscan" : { "minimum" : 0.5455, "maximum" : 0.5909 }
         "vscan" : { "minimum" : 0.5000, "maximum" : 0.5455 }
         "vscan" : { "minimum" : 0.4545, "maximum" : 0.5000 }
         "vscan" : { "minimum" : 0.4091, "maximum" : 0.4545 }
         "vscan" : { "minimum" : 0.3636, "maximum" : 0.4091 }
         "vscan" : { "minimum" : 0.3182, "maximum" : 0.3636 }
         "vscan" : { "minimum" : 0.2727, "maximum" : 0.3182 }
         "vscan" : { "minimum" : 0.2273, "maximum" : 0.2727 }
         "vscan" : { "minimum" : 0.1818, "maximum" : 0.2273 }
         "vscan" : { "minimum" : 0.1364, "maximum" : 0.1818 }
         "vscan" : { "minimum" : 0.0909, "maximum" : 0.1364 }
         "vscan" : { "minimum" : 0.0455, "maximum" : 0.0909 }
         "vscan" : { "minimum" : 0.0000, "maximum" : 0.0455 }
         "hscan" : { "minimum" : 0.5789, "maximum" : 0.6053 },
         "hscan" : { "minimum" : 0.5526, "maximum" : 0.5789 },
         "hscan" : { "minimum" : 0.5263, "maximum" : 0.5526 },
         "hscan" : { "minimum" : 0.5000, "maximum" : 0.5263 },
         "hscan" : { "minimum" : 0.4737, "maximum" : 0.5000 },
         "hscan" : { "minimum" : 0.4474, "maximum" : 0.4737 },
         "hscan" : { "minimum" : 0.4211, "maximum" : 0.4474 },
         "hscan" : { "minimum" : 0.3947, "maximum" : 0.4211 },
         "hscan" : { "minimum" : 0.3684, "maximum" : 0.3947 },
         "hscan" : { "minimum" : 0.3421, "maximum" : 0.3684 },
         "hscan" : { "minimum" : 0.3158, "maximum" : 0.3421 },
         "hscan" : { "minimum" : 0.2895, "maximum" : 0.3158 },
         "hscan" : { "minimum" : 0.2632, "maximum" : 0.2895 },
         "hscan" : { "minimum" : 0.2368, "maximum" : 0.2632 },
         "hscan" : { "minimum" : 0.2105, "maximum" : 0.2368 },
         "hscan" : { "minimum" : 0.1842, "maximum" : 0.2105 },
         "hscan" : { "minimum" : 0.1579, "maximum" : 0.1842 },
         "hscan" : { "minimum" : 0.1316, "maximum" : 0.1579 },
         "hscan" : { "minimum" : 0.1053, "maximum" : 0.1316 },
         "hscan" : { "minimum" : 0.0789, "maximum" : 0.1053 },
         "hscan" : { "minimum" : 0.0526, "maximum" : 0.0789 },
         "hscan" : { "minimum" : 0.0263, "maximum" : 0.0526 },
         "hscan" : { "minimum" : 0.0000, "maximum" : 0.0263 },
Mein HDMI zu AV Konverter ist der aus der Einkaufsliste, der Grabber auch.
dmesg | grep -i video
[ 0.357039] vc-cma: Videocore CMA driver
[ 0.851087] vc-sm: Videocore shared memory driver
[ 11.485081] Linux video capture interface: v2.00
[ 11.909088] usbtv 1-1.2:1.0: Fushicai USBTV007 Audio-Video Grabber
Der Konverter läuft bei mir auch nur mit 5V USB, ohne habe ich nur schwarzes Bild.
Jemand nen Tipp?
Danke !
Todde
toddehawk
30. Jan 2016, 23:48
Ich nochmal,
ich glaube es liegt am Konverter.
Es gibt davon ja 3 Versionen: Cheap - Better - Best
Ich gehe davon aus, das ich die cheap Version erhalten hab..die nicht mit Ambilight läuft.....
Hatte auch nicht direkt von dem Link bestellt (der aktuell auch auf einen VGA-HDMI verweist), sondern diesen:
http://www.amazon.de/gp/product/B00AASZ ... ge_o07_s00
Verkäufer: Tatsang
Jemand nen Tipp wo ich auf die schnelle einen funktionierenden bestellen kann?
TESLA
31. Jan 2016, 12:53
Den habe ich bestellt....bekommen mit dem Teil absolut kein Bild bei externen Quellen egal ob mit und ohne Strom oder PAL und ntsc
Wenn jemand einen Link zu einem 100% funktionierenden hat bitte posten
31. Jan 2016, 14:03
TESLA
1. Feb 2016, 14:49
http://www.amazon.de/gp/product/B01AG0M ... ge_o00_s00
hab ich jetzt mal bestellt mal schauen ob es dann geht...
toddehawk
2. Feb 2016, 17:05
@TESLA: Magst Du bitte Bescheid geben, ob es mit diesem klappte?
Danke!
TESLA
3. Feb 2016, 12:47
klar soll morgen geliefert werden dann teste ich und geb rückmeldung :)
toddehawk
6. Feb 2016, 10:32
Ich habe denselben jetzt auch einmal bestellt und kann sagen das er funktioniert !
Jetzt geht es an das Feintuning .....
