Danny08
Grabber, bei schwarzem Bild Blitze
23. Feb 2016, 19:29
Hey,
mir ist aufgefallen das bei einem total schwarzem Bild die LEDs einzeln aufblitzen, und das nur mega kurz.
   /// APA102, Adalight, AmbiLed, Atmo, Hyperion-USBASP-WS2801, Hyperion-USBASP-WS2812, Lightberry, Lightpack, LPD6803, LPD8806, Multi-Lightpack, P9813, Paintpack, PhilipsHUE, PiBlaster, SEDU, Test, ThinkerForge, TPM2, WS2801, WS2812b, None)
      "name"       : "MyPi",
      "rate"     : 250000,
      "colorOrder" : "rbg"
               "saturationGain" : 1.8000,
               "valueGain"      : 1.5000
               "threshold"  : 0.2200,
               "gamma"      : 1.3000,
               "gamma"      : 1.3000,
               "whitelevel" : 0.2400
               "gamma"      : 1.2000,
               "whitelevel" : 0.1200
         "time_ms"         : 250,
         "updateFrequency" : 35.0000,
      "threshold" : 0.15
      "effect" : "Knight rider",
      "duration_ms" : 1000
   //"framegrabber" :
   //   "width" : 64,
   //   "height" : 64,
   //   "frequency_Hz" : 10.0
   //"xbmcVideoChecker" :
   //   "xbmcAddress" : "127.0.0.1",
   //   "xbmcTcpPort" : 9090,
   //   "grabVideo" : true,
   //   "grabPictures" : true,
   //   "grabAudio" : true,
   //   "grabMenu" : true,
   //   "grabScreensaver" : true,
   //   "enable3DDetection" : true
//    "boblightServer" :
//       "port" : 19333
   ///  * priority             : Hyperion priority channel [default=800]
        "sizeDecimation" : 6,
        "cropLeft" : 10,
        "cropRight" : 15,
        "cropTop" : 5,
        "cropBottom" : 5,
        "redSignalThreshold" : 0.22,
        "greenSignalThreshold" : 0.22,
        "blueSignalThreshold" : 0.22
         "hscan" : { "minimum" : 0.7143, "maximum" : 0.7500 },
         "hscan" : { "minimum" : 0.7500, "maximum" : 0.7857 },
         "hscan" : { "minimum" : 0.7857, "maximum" : 0.8214 },
         "hscan" : { "minimum" : 0.8214, "maximum" : 0.8571 },
         "hscan" : { "minimum" : 0.8571, "maximum" : 0.8929 },
         "hscan" : { "minimum" : 0.8929, "maximum" : 0.9286 },
         "hscan" : { "minimum" : 0.9286, "maximum" : 0.9643 },
         "hscan" : { "minimum" : 0.9643, "maximum" : 1.0000 },
         "vscan" : { "minimum" : 0.9333, "maximum" : 1.0000 }
         "vscan" : { "minimum" : 0.8667, "maximum" : 0.9333 }
         "vscan" : { "minimum" : 0.8000, "maximum" : 0.8667 }
         "vscan" : { "minimum" : 0.7333, "maximum" : 0.8000 }
         "vscan" : { "minimum" : 0.6667, "maximum" : 0.7333 }
         "vscan" : { "minimum" : 0.6000, "maximum" : 0.6667 }
         "vscan" : { "minimum" : 0.5333, "maximum" : 0.6000 }
         "vscan" : { "minimum" : 0.4667, "maximum" : 0.5333 }
         "vscan" : { "minimum" : 0.4000, "maximum" : 0.4667 }
         "vscan" : { "minimum" : 0.3333, "maximum" : 0.4000 }
         "vscan" : { "minimum" : 0.2667, "maximum" : 0.3333 }
         "vscan" : { "minimum" : 0.2000, "maximum" : 0.2667 }
         "vscan" : { "minimum" : 0.1333, "maximum" : 0.2000 }
         "vscan" : { "minimum" : 0.0667, "maximum" : 0.1333 }
         "vscan" : { "minimum" : 0.0000, "maximum" : 0.0667 }
         "hscan" : { "minimum" : 0.6786, "maximum" : 0.7143 },
         "hscan" : { "minimum" : 0.6429, "maximum" : 0.6786 },
         "hscan" : { "minimum" : 0.6071, "maximum" : 0.6429 },
         "hscan" : { "minimum" : 0.5714, "maximum" : 0.6071 },
         "hscan" : { "minimum" : 0.5357, "maximum" : 0.5714 },
         "hscan" : { "minimum" : 0.5000, "maximum" : 0.5357 },
         "hscan" : { "minimum" : 0.4643, "maximum" : 0.5000 },
         "hscan" : { "minimum" : 0.4286, "maximum" : 0.4643 },
         "hscan" : { "minimum" : 0.3929, "maximum" : 0.4286 },
         "hscan" : { "minimum" : 0.3571, "maximum" : 0.3929 },
         "hscan" : { "minimum" : 0.3214, "maximum" : 0.3571 },
         "hscan" : { "minimum" : 0.2857, "maximum" : 0.3214 },
         "hscan" : { "minimum" : 0.2500, "maximum" : 0.2857 },
         "hscan" : { "minimum" : 0.2143, "maximum" : 0.2500 },
         "hscan" : { "minimum" : 0.1786, "maximum" : 0.2143 },
         "hscan" : { "minimum" : 0.1429, "maximum" : 0.1786 },
         "hscan" : { "minimum" : 0.1071, "maximum" : 0.1429 },
         "hscan" : { "minimum" : 0.0714, "maximum" : 0.1071 },
         "hscan" : { "minimum" : 0.0357, "maximum" : 0.0714 },
         "hscan" : { "minimum" : 0.0000, "maximum" : 0.0357 },
Anfangs dachte ich, es liegt an der Baudrate, also von 1kk auf 250k runtergesetzt.
Dann dachte ich, es liegt am Smoothing, da ich es etwas schneller haben wollte, aber es kommt immernoch.
Läuft über meine Playstation, im Webbrowser öffne ich ein völlig schwarzes Bild, dann blitzen random verschiedene LEDs wahllos mal mehr oder weniger auf.
Screenshots über den Grabber sehen normal aus.
Das ist mein Screenshot wenn ich nur ein Pechschwarzes Bild auf habe.
Nachtrag: Eine Erhöhung des Threshold auf 0,23 hat geholfen.
Habe das Gefühl, es liegt an der neusten Hyperion Version.
Vielleicht auch an den Kabeln, hatte aber vorher keine Probleme.
