Zur info. Alle Meine Geräte gehen in meinen AVR von dort geht ein HDMI Kabel in den Splitter usw wie im Tutorial.
1.Welche LEDs du verwendest, ggf. den Link zum gekauften Produkt
APA102 http://www.ebay.de/itm/152209281583?_tr ... EBIDX%3AIT
2.deutliche Fotos deiner Verkabelung, vor allem so das man die Verbindungen vom PI zum Stripe durchgehend (!) erkennen kann
3.deine /boot/config.txt
# http://youresuchageek.blogspot.fr/2012/ ... ec-on.html
# please read: http://elinux.org/RPi_config.txt#Overcl ... figuration
# see also http://www.raspberrypi.org/phpBB3/viewt ... 67&t=15700
hdmi_force_hotplug=1
# mehr USB-Power
max_usb_current=1
4.deine hyperion.config.json
- // Automatically generated configuration file for Hyperion ambilight daemon
"type" : "apa102",
"saturationGain" : 1.0500,
"luminanceGain" : 1.2000,
// V4L2 GRABBER CONFIG
"threshold" : 0.14,
// NO FRAME GRABBER CONFIG
// NO KODI CHECK CONFIG
"vscan" : { "minimum" : 0.9756, "maximum" : 1.0000 }
"vscan" : { "minimum" : 0.9512, "maximum" : 0.9756 }
"vscan" : { "minimum" : 0.9268, "maximum" : 0.9512 }
"vscan" : { "minimum" : 0.9024, "maximum" : 0.9268 }
"vscan" : { "minimum" : 0.8780, "maximum" : 0.9024 }
"vscan" : { "minimum" : 0.8537, "maximum" : 0.8780 }
"vscan" : { "minimum" : 0.8293, "maximum" : 0.8537 }
"vscan" : { "minimum" : 0.8049, "maximum" : 0.8293 }
"vscan" : { "minimum" : 0.7805, "maximum" : 0.8049 }
"vscan" : { "minimum" : 0.7561, "maximum" : 0.7805 }
"vscan" : { "minimum" : 0.7317, "maximum" : 0.7561 }
"vscan" : { "minimum" : 0.7073, "maximum" : 0.7317 }
"vscan" : { "minimum" : 0.6829, "maximum" : 0.7073 }
"vscan" : { "minimum" : 0.6585, "maximum" : 0.6829 }
"vscan" : { "minimum" : 0.6341, "maximum" : 0.6585 }
"vscan" : { "minimum" : 0.6098, "maximum" : 0.6341 }
"vscan" : { "minimum" : 0.5854, "maximum" : 0.6098 }
"vscan" : { "minimum" : 0.5610, "maximum" : 0.5854 }
"vscan" : { "minimum" : 0.5366, "maximum" : 0.5610 }
"vscan" : { "minimum" : 0.5122, "maximum" : 0.5366 }
"vscan" : { "minimum" : 0.4878, "maximum" : 0.5122 }
"vscan" : { "minimum" : 0.4634, "maximum" : 0.4878 }
"vscan" : { "minimum" : 0.4390, "maximum" : 0.4634 }
"vscan" : { "minimum" : 0.4146, "maximum" : 0.4390 }
"vscan" : { "minimum" : 0.3902, "maximum" : 0.4146 }
"vscan" : { "minimum" : 0.3659, "maximum" : 0.3902 }
"vscan" : { "minimum" : 0.3415, "maximum" : 0.3659 }
"vscan" : { "minimum" : 0.3171, "maximum" : 0.3415 }
"vscan" : { "minimum" : 0.2927, "maximum" : 0.3171 }
"vscan" : { "minimum" : 0.2683, "maximum" : 0.2927 }
"vscan" : { "minimum" : 0.2439, "maximum" : 0.2683 }
"vscan" : { "minimum" : 0.2195, "maximum" : 0.2439 }
"vscan" : { "minimum" : 0.1951, "maximum" : 0.2195 }
"vscan" : { "minimum" : 0.1707, "maximum" : 0.1951 }
"vscan" : { "minimum" : 0.1463, "maximum" : 0.1707 }
"vscan" : { "minimum" : 0.1220, "maximum" : 0.1463 }
"vscan" : { "minimum" : 0.0976, "maximum" : 0.1220 }
"vscan" : { "minimum" : 0.0732, "maximum" : 0.0976 }
"vscan" : { "minimum" : 0.0488, "maximum" : 0.0732 }
"vscan" : { "minimum" : 0.0244, "maximum" : 0.0488 }
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0244 }
"hscan" : { "minimum" : 0.9857, "maximum" : 1.0000 },
"hscan" : { "minimum" : 0.9714, "maximum" : 0.9857 },
"hscan" : { "minimum" : 0.9571, "maximum" : 0.9714 },
"hscan" : { "minimum" : 0.9429, "maximum" : 0.9571 },
"hscan" : { "minimum" : 0.9286, "maximum" : 0.9429 },
"hscan" : { "minimum" : 0.9143, "maximum" : 0.9286 },
"hscan" : { "minimum" : 0.9000, "maximum" : 0.9143 },
"hscan" : { "minimum" : 0.8857, "maximum" : 0.9000 },
"hscan" : { "minimum" : 0.8714, "maximum" : 0.8857 },
"hscan" : { "minimum" : 0.8571, "maximum" : 0.8714 },
"hscan" : { "minimum" : 0.8429, "maximum" : 0.8571 },
"hscan" : { "minimum" : 0.8286, "maximum" : 0.8429 },
"hscan" : { "minimum" : 0.8143, "maximum" : 0.8286 },
"hscan" : { "minimum" : 0.8000, "maximum" : 0.8143 },
"hscan" : { "minimum" : 0.7857, "maximum" : 0.8000 },
"hscan" : { "minimum" : 0.7714, "maximum" : 0.7857 },
"hscan" : { "minimum" : 0.7571, "maximum" : 0.7714 },
"hscan" : { "minimum" : 0.7429, "maximum" : 0.7571 },
"hscan" : { "minimum" : 0.7286, "maximum" : 0.7429 },
"hscan" : { "minimum" : 0.7143, "maximum" : 0.7286 },
"hscan" : { "minimum" : 0.7000, "maximum" : 0.7143 },
"hscan" : { "minimum" : 0.6857, "maximum" : 0.7000 },
"hscan" : { "minimum" : 0.6714, "maximum" : 0.6857 },
"hscan" : { "minimum" : 0.6571, "maximum" : 0.6714 },
"hscan" : { "minimum" : 0.6429, "maximum" : 0.6571 },
"hscan" : { "minimum" : 0.6286, "maximum" : 0.6429 },
"hscan" : { "minimum" : 0.6143, "maximum" : 0.6286 },
"hscan" : { "minimum" : 0.6000, "maximum" : 0.6143 },
"hscan" : { "minimum" : 0.5857, "maximum" : 0.6000 },
"hscan" : { "minimum" : 0.5714, "maximum" : 0.5857 },
"hscan" : { "minimum" : 0.5571, "maximum" : 0.5714 },
"hscan" : { "minimum" : 0.5429, "maximum" : 0.5571 },
"hscan" : { "minimum" : 0.5286, "maximum" : 0.5429 },
"hscan" : { "minimum" : 0.5143, "maximum" : 0.5286 },
"hscan" : { "minimum" : 0.5000, "maximum" : 0.5143 },
"hscan" : { "minimum" : 0.4857, "maximum" : 0.5000 },
"hscan" : { "minimum" : 0.4714, "maximum" : 0.4857 },
"hscan" : { "minimum" : 0.4571, "maximum" : 0.4714 },
"hscan" : { "minimum" : 0.4429, "maximum" : 0.4571 },
"hscan" : { "minimum" : 0.4286, "maximum" : 0.4429 },
"hscan" : { "minimum" : 0.4143, "maximum" : 0.4286 },
"hscan" : { "minimum" : 0.4000, "maximum" : 0.4143 },
"hscan" : { "minimum" : 0.3857, "maximum" : 0.4000 },
"hscan" : { "minimum" : 0.3714, "maximum" : 0.3857 },
"hscan" : { "minimum" : 0.3571, "maximum" : 0.3714 },
"hscan" : { "minimum" : 0.3429, "maximum" : 0.3571 },
"hscan" : { "minimum" : 0.3286, "maximum" : 0.3429 },
"hscan" : { "minimum" : 0.3143, "maximum" : 0.3286 },
"hscan" : { "minimum" : 0.3000, "maximum" : 0.3143 },
"hscan" : { "minimum" : 0.2857, "maximum" : 0.3000 },
"hscan" : { "minimum" : 0.2714, "maximum" : 0.2857 },
"hscan" : { "minimum" : 0.2571, "maximum" : 0.2714 },
"hscan" : { "minimum" : 0.2429, "maximum" : 0.2571 },
"hscan" : { "minimum" : 0.2286, "maximum" : 0.2429 },
"hscan" : { "minimum" : 0.2143, "maximum" : 0.2286 },
"hscan" : { "minimum" : 0.2000, "maximum" : 0.2143 },
"hscan" : { "minimum" : 0.1857, "maximum" : 0.2000 },
"hscan" : { "minimum" : 0.1714, "maximum" : 0.1857 },
"hscan" : { "minimum" : 0.1571, "maximum" : 0.1714 },
"hscan" : { "minimum" : 0.1429, "maximum" : 0.1571 },
"hscan" : { "minimum" : 0.1286, "maximum" : 0.1429 },
"hscan" : { "minimum" : 0.1143, "maximum" : 0.1286 },
"hscan" : { "minimum" : 0.1000, "maximum" : 0.1143 },
"hscan" : { "minimum" : 0.0857, "maximum" : 0.1000 },
"hscan" : { "minimum" : 0.0714, "maximum" : 0.0857 },
"hscan" : { "minimum" : 0.0571, "maximum" : 0.0714 },
"hscan" : { "minimum" : 0.0429, "maximum" : 0.0571 },
"hscan" : { "minimum" : 0.0286, "maximum" : 0.0429 },
"hscan" : { "minimum" : 0.0143, "maximum" : 0.0286 },
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0143 },
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0263 }
"vscan" : { "minimum" : 0.0263, "maximum" : 0.0526 }
"vscan" : { "minimum" : 0.0526, "maximum" : 0.0789 }
"vscan" : { "minimum" : 0.0789, "maximum" : 0.1053 }
"vscan" : { "minimum" : 0.1053, "maximum" : 0.1316 }
"vscan" : { "minimum" : 0.1316, "maximum" : 0.1579 }
"vscan" : { "minimum" : 0.1579, "maximum" : 0.1842 }
"vscan" : { "minimum" : 0.1842, "maximum" : 0.2105 }
"vscan" : { "minimum" : 0.2105, "maximum" : 0.2368 }
"vscan" : { "minimum" : 0.2368, "maximum" : 0.2632 }
"index" : 121,
"vscan" : { "minimum" : 0.2632, "maximum" : 0.2895 }
"index" : 122,
"vscan" : { "minimum" : 0.2895, "maximum" : 0.3158 }
"index" : 123,
"vscan" : { "minimum" : 0.3158, "maximum" : 0.3421 }
"index" : 124,
"vscan" : { "minimum" : 0.3421, "maximum" : 0.3684 }
"index" : 125,
"vscan" : { "minimum" : 0.3684, "maximum" : 0.3947 }
"index" : 126,
"vscan" : { "minimum" : 0.3947, "maximum" : 0.4211 }
"index" : 127,
"vscan" : { "minimum" : 0.4211, "maximum" : 0.4474 }
"index" : 128,
"vscan" : { "minimum" : 0.4474, "maximum" : 0.4737 }
"index" : 129,
"vscan" : { "minimum" : 0.4737, "maximum" : 0.5000 }
"index" : 130,
"vscan" : { "minimum" : 0.5000, "maximum" : 0.5263 }
"index" : 131,
"vscan" : { "minimum" : 0.5263, "maximum" : 0.5526 }
"index" : 132,
"vscan" : { "minimum" : 0.5526, "maximum" : 0.5789 }
"index" : 133,
"vscan" : { "minimum" : 0.5789, "maximum" : 0.6053 }
"index" : 134,
"vscan" : { "minimum" : 0.6053, "maximum" : 0.6316 }
"index" : 135,
"vscan" : { "minimum" : 0.6316, "maximum" : 0.6579 }
"index" : 136,
"vscan" : { "minimum" : 0.6579, "maximum" : 0.6842 }
"index" : 137,
"vscan" : { "minimum" : 0.6842, "maximum" : 0.7105 }
"index" : 138,
"vscan" : { "minimum" : 0.7105, "maximum" : 0.7368 }
"index" : 139,
"vscan" : { "minimum" : 0.7368, "maximum" : 0.7632 }
"index" : 140,
"vscan" : { "minimum" : 0.7632, "maximum" : 0.7895 }
"index" : 141,
"vscan" : { "minimum" : 0.7895, "maximum" : 0.8158 }
"index" : 142,
"vscan" : { "minimum" : 0.8158, "maximum" : 0.8421 }
"index" : 143,
"vscan" : { "minimum" : 0.8421, "maximum" : 0.8684 }
"index" : 144,
"vscan" : { "minimum" : 0.8684, "maximum" : 0.8947 }
"index" : 145,
"vscan" : { "minimum" : 0.8947, "maximum" : 0.9211 }
"index" : 146,
"vscan" : { "minimum" : 0.9211, "maximum" : 0.9474 }
"index" : 147,
"vscan" : { "minimum" : 0.9474, "maximum" : 0.9737 }
"index" : 148,
"vscan" : { "minimum" : 0.9737, "maximum" : 1.0000 }
"index" : 149,
"index" : 150,
"index" : 151,
"index" : 152,
"index" : 153,
"index" : 154,
"index" : 155,
"index" : 156,
"index" : 157,
"index" : 158,
"index" : 159,
"index" : 160,
"index" : 161,
"index" : 162,
"index" : 163,
"index" : 164,
"index" : 165,
"index" : 166,
"index" : 167,
"index" : 168,
"index" : 169,
"index" : 170,
"index" : 171,
"index" : 172,
"index" : 173,
"index" : 174,
"index" : 175,
"index" : 176,
"index" : 177,
"index" : 178,
"index" : 179,
"index" : 180,
"index" : 181,
"index" : 182,
"index" : 183,
"index" : 184,
"index" : 185,
"index" : 186,
"index" : 187,
"index" : 188,
"index" : 189,
"index" : 190,
"index" : 191,
"index" : 192,
"index" : 193,
"index" : 194,
"index" : 195,
"index" : 196,
"index" : 197,
"index" : 198,
"index" : 199,
"index" : 200,
"index" : 201,
"index" : 202,
"index" : 203,
"index" : 204,
"index" : 205,
"index" : 206,
"index" : 207,
"index" : 208,
"index" : 209,
"index" : 210,
"index" : 211,
"index" : 212,
"index" : 213,
"index" : 214,
"index" : 215,
"index" : 216,
"index" : 217,
"index" : 218,
"index" : 219,
5.Screenshots des Hyperion GUI Tools womit du deine LEDs konfiguriert hast (von jedem Tab einen)
6.Angabe wo deine erste LED am TV montiert ist (von vorne Betrachtet)
unten rechts
7.Angabe ob die Steuerung von Hyperion mit einer der Apps aus Beitrag #3 in diesem Thema funktionieren
funktioniert leider nicht
8.die Ausgabe der nachfolgenden Befehle mittels SSH(Putty)
killall hyperiond
Hyperion Ambilight Deamon (603)
HYPERION INFO: ColorTransform 'default' => [0; 219]
HYPERION INFO: ColorCorrection 'default' => [0; 219]
HYPERION INFO: ColorAdjustment 'default' => [0; 219]
"colorOrder" : "rgb",
"type" : "apa102"
what(): V4L2GRABBER ERROR: Cannot identify '/dev/video0' ERROR 2, No such file or directory
Aborted (core dumped)
