Ambilight für alle Geräte mit Philips Hue verbinden?
8. Jan 2017, 13:16
Hier noch mal meine Hyperio.config.hue zum Vergleich !
      "name"       : "MyHyperionConfigHue",
      "type"       : "philipshue",
      "output"     : "192.168.178.23",
      "transitiontime"     : 1,
      "switchOffOnBlack"     : true,
      "username"     : "Hu55f-pZhTX6AHFm4HyK91hJ3HtvB********",
      "lightIds"   : [1,5],
               "redChannel"      : 255,
               "greenChannel"      : 255,
               "blueChannel"      : 255
               "threshold"    : 0.1000,
               "gamma"        : 1.0000
               "gamma"        : 1.0000
               "gamma"        : 1.0000
         "type"            : "none",
   // V4L2 GRABBER CONFIG
   // FRAME GRABBER CONFIG
      "frequency_Hz" : 5.0,
      "priority" : 893
      "threshold" : 0.01,
   // KODI CHECK CONFIG
      "grabMenu" : false,
      "grabPause" : true,
      "duration_ms" : 1000,
      "priority" : 701
      "port" : 19446
      "port" : 19447
         "hscan" : { "minimum" : 0.0000, "maximum" : 0.1000 },
         "vscan" : { "minimum" : 0.0000, "maximum" : 1.0000 }
         "hscan" : { "minimum" : 0.9000, "maximum" : 1.0000 },
ParaChris82
8. Jan 2017, 13:55
So, jetzt schmeißt er das aus:
Hyperion Ambilight Deamon (432)
   Version   : V1.03.0 (GitHub-b8f7642/c5d5f2d-1465599599
   Build Time: Jun 11 2016 01:39:39
INFO: Selected configuration file: /storage/.config/hyperionhue.config.json
HYPERION INFO: ColorTransform 'default' => [0; 1]
HYPERION INFO: ColorCorrection 'default' => [0; 1]
HYPERION INFO: ColorAdjustment 'default' => [0; 1]
   "colorOrder" : "rgb",
   "lightIds" : [ 1, 2 ],
   "output" : "192.168.1.75",
   "username" : "ZUIvbv-2Yo47MxdIxFL9uNUHYNzUtm74ddC-dfsc"
HYPERION INFO: Not creating any smoothing
LedDevicePhilipsHue::saveStates(nLights=2): got invalid response from light http://192.168.1.75/api/ZUIvbv-2Yo47MxdIxFL9uNUHYNzUtm74ddC-dfsc/lights/1.
INFO: Json server created and started on port 19446
INFO: Proto server created and started on port 19447
DISPMANXGRABBER INFO: Display opened with resolution: 720x480
BORDER SWITCH REQUIRED!!
Wenn ich den PI neu starte, geht eine von den beiden Lampen für ca. 10 Sek ins Dunkelblaue und danach wieder normales Licht.
8. Jan 2017, 14:31
Google meint, dass es ein Problem in der Hyperion Software im Zusammenspiel mit der Hue-Bridge (API) gibt .
Da werden wir wohl nicht weiterkommen. Ich empfehle das Hyperion Forum daraufhin zu befragen.
Ich habe meine Hue-Lamps im Moment anderweitig genutzt, sodass ich aktuell kein Gegentest machen kann.
8. Jan 2017, 14:42
Jetzt doch der Gegentest, das läßt mit keine Ruhe ! ;)
Habe meine Hue Lampen und die Konfiguration gerade noch mal wieder in Betrieb genommen: Funktioniert tadellos ! Es geht also. Den Fehler musst du also bei dir suchen.
Nimm am besten mal meine Konfiguration und ändere nur das nötigste.
Ich nutze LibreElec 7.0 unter Kodi 16.1. Auf einem RPi3. Lief aber schon unter OpenElec und RPi2.
Hast du die neue Hue-Bridge ? Kannst du über die Webconsole der Hue-Bridge mal die Lampen-Daten auslesen ?
Ich habe den Verdacht, das die Hue-Bridge am Fehler beteiligt ist. Ein Reset der Bridge wäre auch eine Option.
Hier meine Logdatei ohne Fehler. Es fällt auf, dass du eine ältere Hyperion Software benutzt !! Da solltest du mal was tun ! Könnte ein Fehlergrund sein !
Hyperion Ambilight Deamon (388)
   "lightIds" : [ 1, 5 ],
   "username" : "Hu55f-pZhTX6AHFm4HyK91hJ3HtvB*********"
PROTOSERVER INFO: New connection
KODICHECK INFO: switching to VIDEO mode
ParaChris82
8. Jan 2017, 16:15
Sorry, war noch unterwegs. Ja ich habe die neue Hue Bridge. Suche mir gleich mal Befehl raus um die Daten auszulesen...
und wie ich ein Update von Hyperion mache.
ParaChris82
8. Jan 2017, 16:21
   "1": {
      "state": {
         "on": true,
         "bri": 254,
         "hue": 8418,
         "sat": 140,
         "effect": "none",
         "xy": [
            0.4573,
            0.41
         "ct": 366,
         "alert": "none",
         "colormode": "ct",
         "reachable": true
      "type": "Extended color light",
      "name": "Hue color lamp 1",
      "modelid": "LCT010",
      "manufacturername": "Philips",
      "uniqueid": "00:17:88:01:02:77:e6:d1-0b",
      "swversion": "1.15.2_r19181",
      "swconfigid": "F921C859",
      "productid": "Philips-LCT010-1-A19ECLv4"
   "2": {
      "state": {
         "on": true,
         "bri": 254,
         "hue": 8418,
         "sat": 140,
         "effect": "none",
         "xy": [
            0.4573,
            0.41
         "ct": 366,
         "alert": "none",
         "colormode": "ct",
         "reachable": true
      "name": "Hue color lamp 2",
      "uniqueid": "00:17:88:01:02:77:6e:d8-0b",
   "3": {
      "state": {
         "on": true,
         "bri": 254,
         "hue": 8418,
         "sat": 140,
         "effect": "none",
         "xy": [
            0.4573,
            0.41
         "ct": 366,
         "alert": "none",
         "colormode": "ct",
         "reachable": true
      "name": "Hue color lamp 3",
      "uniqueid": "00:17:88:01:02:7d:d0:c8-0b",
ParaChris82
8. Jan 2017, 17:20
Also eben ging es kurz. Werde mich mal die Tage weiter damit beschäftigen. Hyperion ist jetzt auch auf dem neusten Stand. Danke dir auf jeden Fall für deine Mühe Donald
raZilein
14. Jan 2017, 21:20
Hallo zusammen!
Habe nun meine Hue installiert. Leider bekomme ich sie aktuell noch nicht zum leuchten mit meinem Pi.
Hier mal meine hue json:
"name" : "HyperionConfigHue",
"output" : "192.168.1.106",
"switchOffOnBlack" : false,
"username" : "rCgQn5M3jrobe2hYzaQAQtMVKQ5tfRlZRb36noxI",
"lightIds" : [5],
"luminanceGain" : 1.0000,
"gamma" : 1.0000
"gamma" : 1.0000
"gamma" : 1.0000
"type" : "none",
"priority" : 893
"threshold" : 0.01,
"grabMenu" : false,
"grabPause" : true,
"priority" : 701
"port" : 19446
"port" : 19447
"hscan" : { "minimum" : 0.3500, "maximum" : 0.6500 },
"vscan" : { "minimum" : 0.7000, "maximum" : 1.0000 }
Des weiteren habe ich die autostart.sh geändert, den forwarder eingetragen (in die hyperion.config.grabber.json, hyperion.config.json, hyperion.config.kodi.json).
Zu erwähnen, ich möchte erstmal nur einen Hue Stripe einbinden, deswegen nur eine Lampe. Und der klebt mittig unterm Fernseher unter dem TV-Stand. Sollte doch egal sein, obs ein Hue Stripe oder eine Bloom/Iris ist, oder?
Hier noch der Inhalt des Logfiles:
Hyperion Ambilight Deamon (390)
INFO: Selected configuration file: /storage/.config/hyperionhue.config.jsHYPERION INFO: ColorTransform 'default' => [0; 134]
   "colorOrder" : "rbg",
HYPERION INFO: Json forward to 127.0.0.1:19446
HYPERION INFO: Proto forward to 127.0.0.1:19447
PROTOCONNECTION INFO: Connecting to Hyperion: 127.0.0.1:19447
CURRENT BORDER TYPE: unknown=0 hor.size=3 vert.size=2
INFO: Application closed with code 0
Martin.klawitter
9. Mai 2017, 07:47
Nach 3 Tagen config gebastel läuft nun auch mein Ambilight mit HUE zusammen.
Allerdings nicht syncron.
Die LEDs hinterm Fernsehr machen was sie sollen aber die HUEs laufen nach.
Spielereien an der Frequenz vomm 10 bis 1Hz haben nichts gebracht.
Was kann ich den noch einstellen das die Ansteuerung der HUEs klappt.
Habe 4 HUEs eingebunden.
9. Mai 2017, 12:54
Ich habe eine Kombi aus Ambilight und Hue an einem meiner TV am laufen. Ambilight Stripe hinter dem TV und links und rechts vom TV zwei Hue-Lampen. Eine nennenswerte Verzögerung habe ich noch nicht festgestellt. Meine Werte: Framegrabberfrequenz = 5 Hz und Smoothing = none
Habe mal irgendwo gelesen, dass die Hue-Bridge nicht sehr leistungsfähig ist und bei 4 hue-Lampen könnte da schon die Leistungsgrenze überschritten sein. Nimm mal 2 hue Lampen aus der Config und teste das mal.
Martin.klawitter
9. Mai 2017, 23:46
Werde ich Morgen in Angriff nehmen.
Was mich nerft das es ständig die configs zerbröselt.
Bzw die Oberfläche am PC die Config nicht ändert wenn ich von LED auf HUE config wechseln möchte.
Ich schneide mir immer den funktionieren den teil aus und ersetze dies in der config in der ich Änderungen gemacht habe.
etwas umständlich aber so gehts schneller als jedes mal LEDs zählen.
ernestovelverde
10. Mai 2017, 13:41
Das Projekt habe ich mir auch vorgenommen, sobald ich mit dem Ambilight fertig bin. Jedoch wollte ich einen WS2801-Strip hinter dem Sofa über einen Arduino ansteuern. Hat jemand schon Erfahrung mit selbstgebautem "Hue" oder Ähnlichem gemacht?
Chris/si
12. Mai 2017, 21:40
ernestovelverde hat geschrieben:Das Projekt habe ich mir auch vorgenommen, sobald ich mit dem Ambilight fertig bin. Jedoch wollte ich einen WS2801-Strip hinter dem Sofa über einen Arduino ansteuern. Hat jemand schon Erfahrung mit selbstgebautem "Hue" oder Ähnlichem gemacht?
Wenn du das Ganze in Angriff nimmst, berichte mal wie gut das mit DIY Lichterweiterungen funktioniert. Ich habe auch vor weitere Lichter in Hyperion einzubinden, allerdings stehe ich gerade noch am Anfang was die Kommunikation angeht.
Mein Plan sieht vor zwei LED-Lampen/Scheinwerfer via DMX über ein Artnet-Interface in das Ganze einzubinden undndabei bin gerade am Zusammensuchen der passenden Puzzleteile :D
hoaschter
29. Mai 2017, 08:25
wenn ich mein "normales" Ambilight über APA102 fertig habe, möchte ich eventuell noch meine Philips Iris über eine Hue Bridge einbinden. Habe eine Iris im Wohnzimmer, die den ganzen Raum leicht ausleuchtet. Sie steht links oben über dem Sofa und leuchtet gegen die Decke.
Hat schon jemand so etwas umgesetzt, bzw. gibt es Erfahrungen oder Meinungen dazu, ob es überhaupt gescheit funktioniert mit nur einer Iris.
Diese sollte natürlich über die Farben des gesamten Bildschirms angesteuert werden, also quasi einen "Durchschnitt" der Farben errechnen und dann das Wohnzimmer damit beleuchten.
Wäre dankbar über Erfahrungen oder Meinungen bevor ich das Geld in eine Hue Bridge investiere ;)
hoaschter
14. Sep 2017, 09:18
Wo in der App finde ich denn die IDs der Lampen? Unter "Lampeneinstellungen" steht keine ID dabei....
