brhymes125
Ambilight per Grabber TV funktioniert nicht
16. Feb 2016, 17:06
Hallo Zusammen,
Ambilight über Kodi funktioniert über grabber leider nicht. Habe ein Samsung TV welcher so eine art Kombibuchse hat welcher video,audio ausgegeben soll (klinke auf 3x chinch) dort habe ich meinen grabber angeschlossen ( Easier Cap angebich mit Fushicai Chipsatz) und dann eben per USB an den raspi.
Config der hyperion.config.grabber sieht wie folgt aus:
"colorOrder" : "bgr"
/// tuning parameters:
/// (else zero)
/// parameters:
"saturationGain" : 1.2500,
"valueGain" : 1.8000
"threshold" : 0.1000,
"gamma" : 2.0000,
"whitelevel" : 0.6500
"gamma" : 2.0000,
"gamma" : 2.0000,
"whitelevel" : 0.6800
"updateFrequency" : 25.0000
/// being the first led.
"hscan" : { "minimum" : 0.4333, "maximum" : 0.4667 },
"hscan" : { "minimum" : 0.4000, "maximum" : 0.4333 },
"hscan" : { "minimum" : 0.3667, "maximum" : 0.4000 },
"hscan" : { "minimum" : 0.3333, "maximum" : 0.3667 },
"hscan" : { "minimum" : 0.3000, "maximum" : 0.3333 },
"hscan" : { "minimum" : 0.2667, "maximum" : 0.3000 },
"hscan" : { "minimum" : 0.2333, "maximum" : 0.2667 },
"hscan" : { "minimum" : 0.2000, "maximum" : 0.2333 },
"hscan" : { "minimum" : 0.1667, "maximum" : 0.2000 },
"hscan" : { "minimum" : 0.1333, "maximum" : 0.1667 },
"hscan" : { "minimum" : 0.1000, "maximum" : 0.1333 },
"hscan" : { "minimum" : 0.0667, "maximum" : 0.1000 },
"hscan" : { "minimum" : 0.0333, "maximum" : 0.0667 },
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0333 },
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0700 },
"hscan" : { "minimum" : 0.4667, "maximum" : 0.5000 },
"hscan" : { "minimum" : 0.5000, "maximum" : 0.5333 },
"hscan" : { "minimum" : 0.5333, "maximum" : 0.5667 },
"hscan" : { "minimum" : 0.5667, "maximum" : 0.6000 },
"hscan" : { "minimum" : 0.6000, "maximum" : 0.6333 },
"hscan" : { "minimum" : 0.6333, "maximum" : 0.6667 },
"hscan" : { "minimum" : 0.6667, "maximum" : 0.7000 },
"hscan" : { "minimum" : 0.7000, "maximum" : 0.7333 },
"hscan" : { "minimum" : 0.7333, "maximum" : 0.7667 },
"hscan" : { "minimum" : 0.7667, "maximum" : 0.8000 },
"hscan" : { "minimum" : 0.8000, "maximum" : 0.8333 },
"hscan" : { "minimum" : 0.8333, "maximum" : 0.8667 },
"hscan" : { "minimum" : 0.8667, "maximum" : 0.9000 },
"hscan" : { "minimum" : 0.9000, "maximum" : 0.9333 },
"hscan" : { "minimum" : 0.9333, "maximum" : 0.9667 },
"hscan" : { "minimum" : 0.9667, "maximum" : 1.0000 },
"hscan" : { "minimum" : 0.9300, "maximum" : 1.0000 },
"threshold" : 0.14
"duration_ms" : 7000
// "xbmcVideoChecker" :
// "xbmcTcpPort" : 9090,
// "grabVideo" : true,
// "grabPictures" : true,
// "grabAudio" : true,
// "grabMenu" : false,
// "grabScreensaver" : true,
// "enable3DDetection" : true
// "port" : 19333
Umschalten tue ich per Kodi.
Habe laut diesen Link: http://powerpi.de/forum/viewtopic.php?p=5308#p5308 dann folgenden Befehl eingegeben:
cd /storage/.config
killall hyperiond
LD_LIBRARY_PATH=/storage/hyperion/bin /storage/hyperion/bin/hyperion-v4l2 --screenshot --frame-decimator 2 --size-decimator 4
und bekomme folgendes Bild :
Das bedeutet ja das bild ist zu gut.... Ich schaue hdtv kann dies daran liegen?
Was kann ich machen ?
Danke im vorraus
brhymes125
16. Feb 2016, 17:16
Hier mal Bild vom chip:
16. Feb 2016, 17:21
Eigentlich ist es egal ob SD oder HD TV.
Womit hast du den die Verbindung vom TV zum Grabber genau hergestellt?
Welches TV Model ist das genau? War dieses Kabel dabei worüber du das OUT Signal vom TV bekommst?
Foto von der Verkabelung sollte ebenfalls helfen.
Der Grabber selber ist in Ordnung.
Die Aussage "Das Bild ist zu Gut" bezieht sich nur auf die Kombination mit einem HDMI2AV Konverter - nicht auf deine Art von Verkabelung :)
Bei dir ist die Ursache eine andere.
brhymes125
16. Feb 2016, 17:29
Handelt sich um ein samsung ue48j6250 und kabel war dabei. Buchse ist zwar die "kopfhörerbuchse" aber ist die einzige wo der Stecker passt.
Anbei paar Bilder ( TV hängt an wand daher gehts net besser )
16. Feb 2016, 18:45
Das Kabel ist für Camcorder und Co um diese am AV Eingang anzuschließen..
Am Kopfhörer Ausgang bekommst du mit Garantie kein TV Signal ;)
Ich hab den Samsung-UE48JU6450 und Samsung-UE40JU6050 hier stehen - die sehen hinten alle zu 90% gleich aus.
Die Samsung UHD Geräte der JU6er reihe haben keinen AV Ausgang - erst wieder im 7er Bereich.
brhymes125
16. Feb 2016, 18:49
Na das hört sich ja scheiße an :D
Also muss ich en externen Receiver nehmen dann noch en HDMI Splitter ...... Eigentlich gar keine Lust auf so viel kabel.
Ist es möglich über rasbi netflix zu streamen ? Das Würd mir langen... Auf TV könnt ich dann verzichten
Übrigens verkaufen einen videograbber :lol:
16. Feb 2016, 19:07
Nope, Netflix, Amazon Prime & co funktionieren seit einigen Monaten nicht mehr auf dem PI.
